Everything posted by subiemech85
Brat Bed Panels
for easier access remove the taillights gen1 has full length panels removed the left one to clean out "bird nest" from around gas pipe and gravel from wheel well thought about stashing "air conditioning" lifted from http://p201.ezboard.com/quotWho-Here-Smokes-the-Green-sTuffquot-part-2/ffoxheadnetworkfrm13.showMessage?topicID=5.topic good times
! replaced '78 BRAT EA71 oilpan gasket with engine in frame done!
thanks for the tip it wouldn't be a true restoration WITHOUT the gasket :-\ perhaps a ea82t I am rebuilding will get the goo last pan gasket I did on the ea81 brat engine which is in the '86 gl-10 turbowagon has not leaked in over 5 years!!
Motorcyles, what are you riding?
'01? HONDA rebel 250cc '01? SUZUKI RM80 86cc
SMALL hands AMAZING patience HEATED garage all-nighter with sirius-xm 60's on 6 good things WILL happen
I am fairly familiar with pulling engines, have done 5+ different cars in various ways x-mem is 4 bolts plan of attack is set on 4 jackstands, remove engine mount nuts from x-mem, remove 4 x-mem bolts and A-bar, then remove 12? oilpan bolts
could I also LOWER the crossmember?
YES, it is the oilpan gasket leaking tightened the bolts, but it still leaks about 2 qt in 300 miles is it possible to replace the oilpan gasket without pulling the engine?
1979 GL 4X4 Wagon, Full Restoration Starting soon - Need HELP!
TTIWWOP!! what's the build date? 5/78 BRAT 11/79 ski wagon
need vw resources
start here! http://www.partsplaceinc.com/catalog/vw-air-cooled-beetle-ghia-bentley-manuals135.shtml http://www.partsplaceinc.com are good people and for the diesels http://www.vwdieselparts.com/
ea71 engine re-seal parts list, and sparkplug wires, etc.
if these part numbers are bad, please help oil seal front crankshaft 38 x 55 x 9 806738040 oil seal rear crankshaft 70 x 87 x 8.5 806770013 seal washer rocker cover 812764110 gasket oil pan 811606100 11121AA011 11121AA011 gasket oil drain 11126AA000 gasket oil pump body 824206100 oil filter cp 15208AA000 o-ring 10.8 x 2.4 806910050 o-ring 47.5 x 2.0 806947020 o-ring 15.5 x 1.5 806915050 cord cp s/plug 3 420737110 cord cp s/plug 420587110 cord cp s/plug 4 420747110 cord cp s/plug 2 420727110 cord cp distr 420777310 clip clutch fork 30539AA000
HTKYSA pdf.
read post #4 of http://www.ultimatesubaru.org/forum/showthread.php?t=97767&highlight=ea22
NEW body panels
http://www.nor-as.dk/uk/OnlineCatalogue/Onlineshop/tabid/1039/Default.aspx 6705 = g2 6706 = g3 still looking for gen1 BRAT body panels :-\
Maybe a dumb question but........Gen1 EA81 stuff....
YES and TURN OFF YOUR CAPS LOCK
Phewwww
subiemech85 replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit will be come time to change the sparkplugs! who wants to help me remove ea71?
Iowa MudCoast Road Rally
pics uploaded http://public.fotki.com/subiemech85/mudcoast/
that is SLOW!! camera drive mode is 3 frames/sec stop motion video slowest is 3 frames/sec other choices are 6, 10, 15
only needed a little bit of assist to back out of the subaru swallowing hole got home, finished washing in the rain ttiwwop
zzz no more, just woke up actually didn't sleep good b called, en-route
my shopping is also done new memory card 2gb sandisk ultra 2 camera remote control and a propeller
looking for NEW engine-driven propeller belt driven fan 10" 5 blade
I am in the beginning of a multi-year restoration http://www.theymightberacing.com/Restoration/InSituPlanning.aspx a/c works, fan stays when done, I want it to look like you just stepped off the way back macnine set to 1979
Rite Fit Oil Pump Wrenches
don't bother, there is no torque spec just put them on tight as possible by hand and remove with filter pliers wv 1.6 diesel requires a torque wrench to prevent leakage
More choke wires things....
charge relay contact points
Could use some help with identification
in '78 fsm there is a sketch of one for when removing headliner from coupe, remove windshield Attn. POOPARU: I would also like a set of decals that say four wheel drive in the style of front wheel drive fender badges
502 messages in box you are correct, SENIOR prom in the mud was funner!! just recently registered as team subiemech85 that's what my nikon d60 does best over 1,000 pictures on one charge, no second battery necessary hopefully will have a new installed for the event
not sure how to create a poll but do you use your Hiil Holder
of my past and present..... '84 wagon YES '84 BRAT YES '85 wagon YES '89 3door RX disconnected by previous owner, never bothered to hook it up 11/79 SKI wagon N/A 5/78 BRAT N/A '86 TURBOWAGON yes, but severely out of adjustment as if cable is too long due to ea81 engine swap but will be fixed to work correctly when turbo engine is in 6/92 loyale... it's a crap-o-matic
