Everything posted by dmanaenk
I disagree. I think clutch grinds when cable is too loose, and pedal down does not disengage it completely. If the cable it too tight (because of clutch wearing down and thinning) it is always a little disengaged and might slip. If not taken care of quick - it will kill the clutch, but if loosened quickly - it might last for some time.. So I think there is a slight chance that loosening few nuts will help. Or at least will give him time to properly shop for clutch job.
There were no 96 auto outbacks with ej22. If you only need outback for ground clearance - I would not discount regular legacies with 5spd and ej22. Around 100k suspension will need replacing anyway and you can put new outback suspension on legacy and gain the ground clearance. Apart from that - there's a common problem with 96 5spd - some spacer in shifter linkage rattles.
If the clutch was slipping - you'd smell it when accelerating hard (make sure your cabin vent sucks air from outside) or going uphill in high gear. If it does not smell -it sounds more like clutch being slow to engage for some reason. See if your car jumps and stalls when you put it in first and drop the clutch pedal.
