Everything posted by junkyardgabe
I'm thinking this is VERY bad
dang that looks like someone took a ballpeen hammer to it
EA82T No start
sounds like the ignition module quit
More progress and pics from the body shop
its almost there :cool:
cap lift shocks
for those of you with that have the high top cap like mine the rear door shocks are the same from an s-10 blazer rear glass just to let you know my cap
Gen2 brat waterpump replacement?
they are easy to change nothing special needed to know and nice brat
Transporting an 86 GL-10
what are you looking to spend i'm going to maryland next month and i could probably tow it back for you if the price is right!
pics of my new wagon finally
what did someone back into something and just slapped in a new taillight but that is in pretty good condtion for what you paid cool:cool:
clever electric fan override
to make this even easier just buy this fan relay it's easy to install fairly cheap and you can run daul fan with different temp setting this is what i use on my v-8 s-10 blazer and works great fan relay
headlight covers
PHATBRAT- '84-'88 ss.
TONS of oil in intake- what else to check?
how many miles are on the subaru it sounds like blow by
Carb swap completed. Need help.
have you tried spraying carb cleaner around to see if you have any vacuum leaks
check out what i found at the j/y today
they are 13" by 5.5"
A small score today
i just put a set of four of these in the market place last night
headlight covers
if you can find a set for a monte SS they are the same exact as the brat one's and will fit any EA81
pole:[who has power steering]?
no no
its not to bad i shipped two 14" pugs to McBRAT in iowa and it was only $40 and a extra $10 for boxing
i was running around this new j/y i found a couple of month a go going through their bus's and trailer's have full of stuff i was in this one trailer i went down to the empty end of it just to look and out of the corner of my eye i seen something chrome so i looked under the shelf and found these http://usmb.net/gallery/Subafied/000_0181 http://usmb.net/gallery/Subafied/000_0182 http://usmb.net/gallery/Subafied/000_0184 cool huh?
one more reason
it to bad every one else couldn't make rear brakes that simple to change
disty swap
i thought you had miss read that miles!slow down:D
can a 6ft4in guy fit in a sube?
i'm 6'2" and i like how i fit in any subaru i think theres more room in a rx over a xt and i'm 325lb so if that isn't an example for ya i'd don't know what would be
Who has a JDM ej20t?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=46098&item=2458487455
headlight covers
does any one run headlight covers on there ea81 and ea82 with out composit headlights were can you get them
Connector for Clock
if you keep pulling it should come up but if not if you pull your glove box out you should be able to reach the plug the led is probably messed up alot of mine have done that to
Disty rotor won't come off
come on you know better!:-p :-p
Anyone Do this conversion...?
junkyardgabe replied to mudrat79's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you do this you have to also change the rear diff because of gearing is different the only one's that will interchange with a 91 is a 90 or 91 . 92 they changed the gearing
