237
Everything posted by Loyale 2.7 Turbo
I Have a .pdf File about the EndWrench's Review of the Subaru EJ Engines, you can Download it by Doing a Click on my Avatar and you'll see it on the List of Manuals I Posted "Ready to Download" on my USMB's Public Profile. Please: Let me Know what do you Think about that Endwrech's EJ Engine Review. Kind Regards.
The Electrical problem you Described is Related to a Bad Grounding... so I Kindly Suggest to do one of this Two things: Remove the Grounding Wires from all its Terminals, Clean Both Surfaces and reinstall. Run a New Parallel Ground Wire. I Did Both Long Time Ago... I Hope this can Help, Good Luck! Kind Regards.
Central America ... ... and Not so Rural! ... ... See: http://www.ultimatesubaru.org/forum/showthread.php?t=90606&page=8 Well, the 55W / 5000K Kit I have on my Wagon is Bi-Xenon, so it has Low Beam with an extremly Low & Sharp Cutoff and High Beam, wich makes think to the Driver / Passenger that you're Driving Behind a Stadium Reflector Lights. For my Many Many Rural / Off Road Trips (Almost every Weekend) that High Beam has Saved my Life at least two Times, once it was a Black Horse crossing the Road Side by Side, the other time it was a Bridge that just Fell off from one side and I am more than Sure that Driving with the Original Halogens I wouldn't noticed that on time to preven a Huge Fat Crash. I Know that is Hard to Believe how those H.I.D.'s Perform on Real Life but there is another USMB Member, Mark (SUPERU) which is a Great Friend, he came from USA to my Li'l Country some time ago and I took Him to a Night Ride on my Subie across the Capital City and a Mountain nearby; he Liked how those H.I.D.'s performed on my Wagon. (Check Post Nº 24 http://www.ultimatesubaru.org/forum/showthread.php?t=93529&page=3 ) You can Ask him about How the Low Beam has a Sharp edge that Doesn't Disturb the incoming Drivers' eyes. (High Beam is Amazing Long Reaching) That was my First Concern when I Obtained that H.I.D.'s = Safety. Kind Regards.
General Carburetor question
Loyale 2.7 Turbo replied to crazyman03's topic in Non Soob Cars and Bikes Discussion
Yes, Swap a Manual Transmission there; Also a Better Carburetor will Help but the Gas Eater is the Automatic Trans for Sure. Kind Regards. -
Seems to be Fixable... and seems like it Worth it! Nice Rims has on the rear.
Me Too! ... Your Subie illuminates Great with Those H.I.D.'s I Run mine with a Yellowish 5000K and 55W Because I Travel too much during Night times and here in my Crazy Country our Roads are pretty Bad, Also here Rains 2/3 of the Year. Plus certain animals might cross the Road without notice, like Cows, Horses, etc... Blueish Lights' illumination trend to be "Eaten" by Wet Pavements. I Wanted More illumination 'cos it makes my Night Trips Safer... I'll Never go Back to Halogens anymore. Kind Regards.
Two Things: That "Horrible Cutoff" is in part due to the Camera's sensibility to the illuminated Darkness of the Night while Taking the Picture without Flash and using a Very Low Speed Exposure. That Special H.I.D. Kit I Used is intended to Retrofit it to the Subaru's Headlamp's Mirrors, and believe me: it isn't any Cheap at all. So, let me Tell you that the Pics aren't giving the Real Idea; only if you take a Ride on my Subie you'll Understand. Kind Regards.
88 spfi gl doggy, no power
Loyale 2.7 Turbo replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...well, Mine too; Specially since the Weber Swap; So there's Something Wrong with that Subie. Maybe a Tune-Up can help... I Mean New Spark Plugs, set the Timing Right, Check for Worn Vacuum Hoses, etc... Kind Regards. -
Working room in the engine bay.
Loyale 2.7 Turbo replied to Dirk's topic in Historic Subaru Forum: 50's thru 70's
Thank you for your Kind Answer... ...it Looks Even Nicer Now!!! Kind Regards. -
Do I need the ECU?
Loyale 2.7 Turbo replied to Lachlan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you for your Kind Answer... Best Regards. -
Do I need the ECU?
Could I Ask What is... ...? Kind Regards. -
1984 subaru brat oil leak fixed itself?
Loyale 2.7 Turbo replied to superbrat84's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...Some old Oil Sludge went to the Leakin' area and Clogged its Way out? -
EA81 into wild VW trike
Loyale 2.7 Turbo replied to tweety's topic in Meet n' Greet. Your USMB Welcome Center
it Looks Wonderful! Could I Ask more info about the Weber Air Filter Adaptor? Kind Regards. -
Looks Nice & Clean! ... I Like it! Coud I Ask more info about the Carburetor and the Air Filter? Kind Regards. -
lifter tick solved? fingers crossed.
Loyale 2.7 Turbo replied to Carl B.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those Engines Needs to be Accelerated for long time periods in order to Sustain a High Oil Pressure for enough time to Fill the Hydro lifters; Specially if those had dirt inside. If your EA82 was singin' the "T.O.D." Song for long time, then those Hydro lifters could be Worn enough to make that noise come back again soon, as pressure goes down... then it can dissappear again on Trips... and so on... Kind Regards. -
What about a Thick cover of Anti-Gravel Paint? http://www.emulzer.com.tr/emulzer/urunler.php?cat=2&lang=eng&id=62 That not only will help as an Anti-Rust but also will help to isolates noises. Here in my Country is Widely used on Car's interiors. I Have used it on my Wagons and my Wife's Kia. Kind Regards.
Cooling fan constantly on
Loyale 2.7 Turbo replied to 81EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I must say Yes. I Used it on those kind of Threads. -
It's A Great Time . . .
Loyale 2.7 Turbo replied to Olnick's topic in Meet n' Greet. Your USMB Welcome Center
Done! I Really Like this Site and the Family of Friends here! ... I Hope I will continue Helping much more. Kind Regards. -
Very Nice Trike, I Like it! ... ... also I Like the Model! The EA81 Already came with a Weber Carb, That So Nice!!! I Really want to Know how does the Performace Change with the EA81, keep us Posted! Kind Regards. -
Loyale Front bumper
Loyale 2.7 Turbo replied to SoobDood05's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Whole Front Bumper only has Four Screws that Attach it to the Car's Frame, Two each side. Just Look the Side of the Frame that Faces each engine Head's Cover and you'll find Two Holes each side. if you unbolt those Screws, be sure to Disconnect each side Marker Light on the Bumper Before Sliding it out. Kind Regards. -
I Believe Not, but if the "Click" Sounds came from around That Area, let me ask This: Have you Checked for Worn Fusible Links? Also there could be (Hiding Around) a Worn Relay, Did your subie has had an Alarm? Kind Regards.
best winter wipers
Well... No Snow here at All, but Huge Rainstorms. I Use These: Those 18" Curvy Silicone Wipers Works very Smooth. Kind Regards. -
Loyale Front bumper
Yes, you Can't due to the Fact that the Whole Headlamp is a one piece unit, No disassemble is Possible. About Fixing the Bumper... Have you ever Tried the FiberGlass? Look Here, it could be Helpful: http://ultimatesubaru.org/forum/showthread.php?t=75156 Kind Regards.
