Loyale 2.7 Turbo
    238
Everything posted by Loyale 2.7 Turbo
  1. Another Question: How is the Oil Pressure at Idle? if it is too low -near zero- I think it`s time to reseal or -better- change the oil pump... I strongly suggest it specially if it is the original one, with those 377K miles and still workin` is a Miracle! If it`s the original one... I know that can be a "Part" of the Problem... Also I suggest you to Check the vacuum lines... and change any damaged / worn hoses... Good Luck!
  2. I started drivin` my dad`s white EA82 Wagon at 14 years old... it was Long time Ago... ...Only short trips with him... ...
  3. Look this Nice Pic: is on Turbone`s Gallery: http://usmb.net/gallery/album14/cleanengine1 Also check this Great Page of Miles Fox: http://www.economysuperstar.com/milesfox/subaru/service/glossary.htm
  4. Yes! EA81 did came with Power Steerin` as an option Here. I drove one of a Friend`s Fiance about two year ago, it was a 1984 EA81-T (turbo) with the option package GL-10 AWD... it got power steerin` wheel along with power windows, etc... you know, and the digital dashboard... It was fine, just got a trouble with the Clutch`s Main Bearing and Disc... I was checkin` that to help my friend, and I liked that car too much. Also I saw another versions of the EA81 GL with power sterring... (without a turbo) I think it was an option.
  5. You must be Carefull with it... You Know... Maybe it belongs to someone that is on a long term trip or somethin` like that. Did you ask to other people at the building? No body knows... ?
  6. Nice Job!!! I`ll love to see more Pics... I Like your Loyale
  7. Yes, I Agree... It happens to a friend`s Subie Long time ago... Same Issue, Same fix. Good Luck!
  8. Oh My God! I hate "Big Bangs" on Engines... Well... I`m Almost sure that it wasn`t a timin` belt, due to the fact that the engine starts... I`m almost sure that your engine got a valve problem... but there is a small chance to that to be a Head Problem too... Long time ago, my dad did "Blow" one head, accidentally crackin` it by puttin fresh -very Fresh- Water on the engine that was overheatin` due to a blown head gasket that was evaporatin` the water out from the engine... A Cracked Head do exactly the same situation that you have... but I hope that is not your engine situation... I think it`s just a Valve`s Issue. I Suggest stop tryin` to run that engine like that, and check valve system... Good Luck!
  9. I Agree... But also I suggest to clean the Fuel System... I got same situation long time ago, and it was due to dirty gasoline... you know: Water, etc. on fuel system... I used to refill the gas tank at the cheapest gas station, and it was the oldest gas station, with its underground fuel tanks with filtration... gettin` worse on rainy days... the gas was dirty. I switched to other gas station & Cleaned the fuel system, and it fix the hesitation. Maybe it can Help. Good Luck!
  10. OH! Thank You... I`ll check it now... Did you Read your Messages today? I Sent one to you, just to Thank you So Much... Best Regards.
  11. Yes, My EA82 White Wagon had similar problem about two years ago... Same Solution.
  12. Maybe this... Or Maybe a burnt Distribuitor Module... I Suggest to Check them, but if "Plenty Spark" you got, Have you Checked the Fuel Pump and Hoses / Connections?
  13. So... Have you Tried the New ECU? It Was the Problem?
  14. Hey... There are adaptor plates for webers here: www.webercarburetors.com
  15. ...Well... Back to the Roots of This, I just wanna tell as "INFO" to contribute to the Gas Economy, That when my white subie wagon was using the Hitachi Crap. (Carb) I Disconnected and closed the vacuum line that activates it`s secondary stage... And I got around 50 MPG on it... You Know... but that leads your subie to be a more "Grandmother Drivin` Car" (I Mean, the Engine feels Anemic, so the Car is Slowest, but Very Economic to Drive) ... But is Driveable... Don`t you wanna Try? it`s Simple... Good Luck!
  16. Nice Pair of Subies... I`ll Love to have a Brat... Here they are very difficult to obtain, owners know them as a "Very Special Cars" so here in Honduras, both the Subaru Brat and the Toyota 1000 are the only cars that people don`t sell. Never... Maybe one day I can Find one... Congratulations!
  17. Yes, I Agree... I spent Three months of Suffering with the Craptachi of my EA82... I tried to resurect it whith the original rebuilt kit... it won`t work at all... even with a friend mechanic specialized in carburetors that was helpin` me... Then I used a Nissan`s sentra 1,600 Hitachi crap. to run my white wagon, untill I got the Weber... Believe me: if you "Weberize" your subie, you`ll Never want to run a Craptachi Carb. Again... I Strongly suggest to Weberize Yours... but be careful with emisions regulations... Good Luck!
  18. Yes, I Agree... Originals... It happens to my White Wagon at almost the same 220K`s ... it`s Good Idea to do a "Routine Maintenance" Now.
  19. Did you check the Hoses that activate the Idle Actuator of the Air Conditioneer? Those are two: one comin´ from the engine (3/16") to the Passenger´s side of the hood (Near the Glass) where the Relays of the A/C are Located... The second one comes from there to the Accelerator linkage, and it "Pulls" it a li´l bit to make your engine´s Idle speed increases when you turn on the A/C. If one or both of them are Unplugged or damaged, the simptoms are like that you describe... See this thread, maybe it can Help: http://www.ultimatesubaru.org/forum/showthread.php?t=56060 Good Luck!
