Loyale 2.7 Turbo
    238
Everything posted by Loyale 2.7 Turbo
  1. As I Said, there goes the Complementary Pics... I do not have internet at home, so I went in the afternoon to a Cybercafé and the internet was down... Well, anyway; I hope those pics may help you... Best Regards.
  2. Long time ago... in 1995; my dad drive the EA82 with a partially damaged head gasket that makes the water / coolant mix, slowly go away from the engine at normal temp.s, and then get hotter, and hotter ... He was in the middle of a Highway when engine´s temp go to So much Hot, almost redline; so he did pull the car aside from the road, near to a wild cold mountain spring water font, and takin´ some fresh water from it, with the engine still running in idle, he did open the Radiator (with his T Shirt on his Hands as a protective Shield) and put straight in, a half gallon of that fresh cool mountain water... I will never forget that Horrible "CráCk" Sound commin´ from the engine... one of the two Heads did broke in Two pieces, just between the valve holes from one cilider to another... Miracly the engine didn´t stop runnin´ just one side was Kickin´ Literally, but two pistons was enough to my dad, to came back home, cruisin´ like that almost 77 Miles! Really, I Love that EA82... I just changed the broken head and it did work perfectly! and still runnin´ today. So: Please, don´t drop fresh water in a hot EA82... NEVER!
  3. yes I agree. But let me tell ya Somethin´: The Oil Pump on the Subaru´s EA82 is moved by one of the Timin´ Belts, instead of the main axle of the engine, as used in almost all other engine designs, so it make an oil pump to rev. at double speed than the pistons (Valves Speed) so it only last about 100,000 Miles (About 10 Years of Use). So, I just changed the Core of the Oil Pump (Oil pump Kit) and the noise did go. That´s All. But in the other hand, I did help a friend with a Hatchback EA82 that was too noisy, and the previous owner did drive it like that for two or three years! ... So, Along with the Oil pump change, we did that Subarian Said: Clean Them Up!, and that got fixed any noisy lifter. But, due to the serious wear on it´s lifters, my friend´s subie always is noisy when it is first started first time on the day. Or when it´s cold. then in few minutes, noise is gone. Good Luck!
  4. Yesterday I Didn´t got a Camera with me, so I made that Drawin´ to help you... But I think that maybe I can got my camera back today afternoon, just to take a pic of my Subie´s Hoses Config, to show a better image. Best Regards.
  5. Well... I really think that bad connections on Vacuum lines can´t make any engine to unstart, due to the fact that vacuum only exist with a running engine. But in the other hand, bad connections on electrical cables can do that. I sugest to: First: Check the main electrical Lines. The ones flowin´ from the Battery. Also a Rusty Fuses Links can do that too. Check for burnt / Corroed Fuses. False contact in any main cable. Also, if you wanna put all your vacuum lines in correct order, I think that is a Good Idea to send us a Image of those lines actually config. to tell wich ones are exactly the bad connected ones. Good Luck!
  6. First of all, let me tell ya that subies did came with many various climate control versions... even the same year model, did came sometimes with "Panasonic" or "Hitachi" Systems... etc... and even it may vary from state to state. If your car is a Loyale, and by the pics I saw I can tell ya that your Climate Control Config is Almost the same of my 1985 EA82 Loyale, so let me exoplain you how to fix it up: Also you need to know that if your A/C Compressor is Hitachi, the Whole System uses Three Realys: One at the Back Side of the Main Fuses Box (Inside the Car) And another two, in the Engine Compartment (See my Drawin´ for Details). I must tell ya that if the whole system didn´t work, Replace them with Bosch ones, they are way better. I Done that and climate control works fine. Like new. Bosch Relay + Socket: Bosch Relay Wirin´ Diagram: (Remember, pin 87a, if avaliable, is unused in Subarus) Good Luck!
  7. Really I Didn´t seen (Or Heard) About 450 Subies... But here are 360´s and 500´s and 600´s and 650´s (In some markets, they called them the Subaru "Rex") Even 700, 800 and 1,000.CC this is very nice Li´l Car... heritage of the 360... Maybe the 450 is in the middle way between the 360 to the 600... Also, I found this Info about the 450 in: http://www.histomobile.com/1/Subaru/1960/450_.htm?lan=1 it seems to be a more powerfull 360! Here Some Pics: Also see this Link, Very Explained: http://www.xs4all.nl/~mjs/subaruk.html
  8. ...This is True... Some Aditional Info: When my "Weberized" EA82 gets the lower end of the Red mark in the "E" of Empty, it still have about one Gallon. Enough just to Take it to the Nearest Gas Station... I know it because I always use to Drive near the Red Line... You Know...
  9. Well... I know Loyale`s EA82 Loves Redline, but if yours is Carbed, you can do somethin` to fix this situation ( A little at Least )... Let me Explain: Normally Carbed Subies got the CrapTachi (Hitachi) Carb on them... it has two stages, low (Mecanically Powered by the Cable) and High (Powered by a Suction Vacuum Valve, that depends on the Engine`s Rpm`s ...) So, My EA82 is now "Weberized". Weber Carbs goth Both Stages activated Mecanically, but the Second is Progressive (in 32/36 Models, in 38/38 they`re Sychcronous) The Second opens at the First`s Half opening. Believe me: It`s a Enormous Difference between them (Second Stage by Vacuum and Mecanically) Specially in the Lower Range, so if you`r Subie is Carbed, and you want still to use it`s Hitachi Carb, you can "Unplug" the Vacuum valve from the Carb, Cap the hose and do a "Link" Between the First and the Second Stages, using a piece of Solid Iron Wire. There are a lot of info of it on internet... Also I did help doin` this to two Friend`s Loyales, and they claim their cars Feels way Better, accelerates very Faster, even comparing when they where new... Also mine with the Weber, Accelerates Very Faster than when it was New. Maybe this Idea could Help you... Good Luck!
  10. My Accord Front Springs Came with both ends Flat. Maybe try another year model... Mines where in a `92. In Front, I put it on a Ford Tempo Front Springs. They got exactly the same turns and thick of the Original Subie ones, but also they got two aditional turns with a +/- 1.5 MM less thicker material... This "Extra" part, is designed to Add more "Confort" to the normal ride, absorbing better the small movements of a good road... Also I installed along with them (I mean in Front) a "Donut" You Know... Good Luck!
  11. If it gets Open Air (Not Correctly "Sealed"), Bassically: Your Engine will breath high amounts of Dust, and it`s too bad for it. Dust in the Engine works to wear it like sandpaper. Why you wanna Cut it?
  12. Very Nice & Clean Subies! 10X for the Pics! Why not Fram?
  13. Well... Just as Info: I got big problems with a Luber Finer Filter, in it´s reference chart, it say aplicable to Subaru EA82 engine, but due to it´s low rise thread (It´s too lower than the border gasket) it only reaches the first one or two turns of the engine threads, so; when tou are drivin´ and engine gets´about it´s normal operatin´ temp, the filter "Explode Out" with a huge "BOOM!" throwin´ all the new oil on the road... Lettin´ engine without oil at high RPM´s It´s Too Dangerous!... So, they at Luber Finer, did Change the Filter Specs, to Rise up the Thread... I got that problem on my EA82 long time Ago... Since that, I Always check the new filter with the old one, to see if they match.
  14. Well... I think So... I sugest to pull it out, and check if bad, and replace it... Good Luck!
  15. I never Heard anything like that but I wish it won´t be so hard to fix... Good Luck!
  16. ...Maybe here... http://www.jcwhitney.com/autoparts/Browse/tf-Browse/s-10101/showAll-0/showCustom-0/N-111+20004539+600001657/c-10101 Good Luck!
  17. Yes! I Think So... Check for Short-Circuited Loose Cable or Somethin´ like That. If he attach the Back Window Brake Light Cable to the Tail Light itself, it´s almost for sure that is the origin of the Trouble... ...But there´s another Weird Possibility: if the Left and the Right break lights Aren´t of the Same Ressistance... Let me Explain: As a Example: in the Directional lights, if you got all the bulbs of the same ressistance (Ohms / Watts) when you pull the stick to left or right, they will flash at the same speed in Right or Left position. If one of the bulbs gets burnt, for example the Left, then in the Left circuit will be Less Ressistance, so the Speed of the Flashing action will be double fast or so for the Left, compared with the right side. The same occurs when in Front you have a much brighter light than in the Rear of one side circuit, and in the other side both are the same; then one side would be Faster than the Other in Flashin´... So, if you got in the Brake lights, different ressistance bulbs, for example: Left with normal 32CP ( 7 / 15 Watts ) and in the Right 21CP ( 5 / 10 Watts ) maybe -Just Maybe- that is the Origin of the Problem. Check this, maybe it´s a Easy Fix... Try to buy a Pair of identical bulbs for both tail lights... Good Luck!
  18. I´m Very Happy to know that you got fix the Power Windows problem. If there is Anything I can do for you or any other member, I´m glad to help you. Also, this was My Nº 100 Post And Keep it goin´
  19. I got the 8145 Accel SuperStock Coil about two years ago, from www.jcwhitney.com and this Delivers 45,000 volts, and is NOT oil Cooled. it´s a Special Designed Coil for the Off road Use. I Recommend that.
  20. First of All... if it is an EA82... Check the Seal of the Main Pulley of the Timin´ Belts... And do it NOW! Because oil in the Timin´ Belts, drive ´em to Break...
  21. Some time Ago, I readed a Full Article about the Low and High Octane Fuels... It`s All About Detonation, since low Octane detonates more.... But it can be traduced in More Power, Let me Explain: The main coil of the Regular EA82 is of 27,000 Volts Output, but this isn`t enough power to combat the detonation due to misfires, so, if You put in a more powerfull Coil (I got the Accel SuperStock Solid Coil -Off Road Use- that delivers over 45,000 Volts) and do "Clean" from carbon deposits your engine (Those that make Dieseling in Weberized Subies) You`ll have More Power from the overtimed engine. But just a Little Overtiming. about 20º. How to Clean Carbon Deposits in your Engine? There are many chemical things that claim to do that, but the easier is this: when the engine gets it`s normal operating Temp. Just open the Air filter Box, and with the Engine revving about @ 2,500 RPM`s, let drop right on the Carb a Small Amount of Clean Water, ( one or two onces ) You`ll notice a "Blackened" exhaust smoke coming from behind the car... Repeat this untill the "Blackened" fumes gone... And that`s it! Good Luck!
  22. Look at This! Japan I4020-53221 Subaru Leone-Loyale Clutch Cable Make: Subaru Model: Leone Loyale Brand: Japan Chassis: A10/A11 Engine: EA82 Chassis: A10/A11 Price: $22.73 As Seen on: http://www.1motormart.com/subaru~leone_loyale~clutch_cable_year.html Hope it will Help...
