Everything posted by Meeky Moose
well Jack, i see your point.. and I don't purposely hit animals for the fun of it.. just happens the owner of that chihuahua and 3 other dogs sit on thier porch, turn the dogs loose, and let them run in teh middle of the street.. the other 3 dogs stay outa the road, but the chihuahua like to jump out in the middle of the road just as you get to thier house.. so i drive over him.. he knows to duck when he sees my hatch, lol and on another note, i had a what looked to be, mutt run out in front of me in the ole ford.. i locked all 4 up, and a 30 year old truck doesn't slide straight, so off in a ditch i went, about a 8' drop 70 degree drop off.. took out a few trees and ended up in someones yard.. scratched my truck, broke my mirror.. the dog was abandoned.. looked like a little brown lab or a miniture golden retriever.. hair was matted, notted.. i caught the dog, took it home.. tied it to my porch.. gave it some water, etc.. and called animal control.. while waitin for him to show up, i sat out front, and my daughter (16mo. old) and I played with the dog.. it was the friendliest dog i have ever seen.. especially bein around my baby.. if i woulda had a place to keep it i prolly woulda cleaned him up and kept him.. i felt bad that he went to the pound, and has prolly been put to sleep by now.. but the point is, i don't enjoy hitting any kind of animal, but if the damn thing try's to defy death twice a day everyday, then it has no sympathy from me...
? driving fast/looks
Meeky Moose replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and if it doesn't matter what make of vehicle.. 78' Ford F-150, speedo says 85mph. can wrap it back around to the 40mph and still have pedal.. heh guess this ole truck is faster than an STI muuahaha :moon: -
Broken carb mounting stud
Meeky Moose replied to Goatboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
go get an easy out.. they're only a couple bucks.. drill the hole 1/4" in and use the easy out to get the stud out.. just did 4 out of 6 on my ea81 block and heads.. and these were rusted in there from sitting for several years.. -
HELP, New to Sub's...random engine shutdown
Meeky Moose replied to Highway 101's topic in Old Gen.: 80's GL/DL/XT/Loyales...
fuel pump, fuel filter, deffinitely not the alternator... electronic module in the distributor a good possibility.. if the alternator was the culprit you'd have a dead battery... i'd start with the cheap fixes, fuel filter first.. then the electronic module in the distributor, then the fuel pump.. its bound to be one of those -
well, i've had my turbo wagon up to 110 on the flats.. she had more pedal but with 290k i didn't wanna push her too far.. on another note, i had my xt6 up to 145, when i was headin to salem from grants pass.. :moon: -
Lower compression - less power?
Meeky Moose replied to viceversa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i'd say pop the radiator out, pull the timing belt covers and check the timing yourself.. its fairly easy.. and never hurts to double check.. -
anyone have that link to where they "lightened that nissan sentra" that suddenly pops to mind. chop the top, use temporary donuts as tires, remove the dash, etc.. basically have a rolling chassis with an engine.. i know you wouldn't do that Dennis, the thought just popped into my head for some reason lol...
how hard would it be to???anyone tried??
Meeky Moose replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, some pics would be great... can send them to tsinclair@avspec.com no limit on size... -
ahh, its an idea that'll prolly wait awhile(no green stuff). i think it might be one of those summer projects... -
hmm thats wierd.... i took the one outa my hydraulic motor and stuck it in my pushrod motor no problem.. they were the same size.. one disty was a hitachi (out of hydraulic motor) the other was a nipondenso (out of pushrod motor) so not sure why one would be bigger than the other...
heh, theres this little chihuahua, on my back road. runs out right when ya start to go by, twice i've dodged or stopped.. in the hatch, i just run over it.. and the damn thing is so small it just ducks and never gets hurt
"Lola" needs your help please
Meeky Moose replied to Twowagons's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if that fuse doesn't fix her, take the blower motor assembly out, disassemble the motor itself and just do a thorough cleaning. thats all that was wrong with my hatch.. after it was put back together it works like new again.. it showed the same symptoms as you describe... -
How to install AC Condenser
i don't know much about the loyales, but i'm sure they're close to my wagon,, anyways, when i took mine out i had to take the front grill off, unbolt it, and it slid out the bottm, between teh radiator and the bumper.. had to jack the car up a little bit tho.. -
i just went through that with my hatch.. although mine was a loose ground where the neg. cable bolts to teh front of the engine... after fixin that i can turn everything on that there is to turn on, even the flashers, and the guage never sees anything below 13
Strip-a-thon,Parting Party 11/15 in CT
Meeky Moose replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hey moosens, when ya get that engine outa there, those tranny mounts are pretty easy from that point hint hint -
yeah, i put one up awhile back, and about 30 seconds afterwards it was removed for discussion.. and never put back... guess ya gotta say nice things or it gets removed.. doesn't matter if the bad things said are for everyones benefit and knowledge..
whats my 4x good up too????
Meeky Moose replied to subawoohoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
heh, ohh yeah i got 26mpg in 4low on that 300 mile drive.. -
funky oil pressure??
well, i was diggin through my FSM... found this 1800cc engine, 50psi, 500rpm, 167-185 temperature 1800cc engine, 57psi, 2500rpm, 167-185 temperature pressure relief valve starts to open at 64psi oil bypass valve opens at 21 psi -
as for doin is safely no more than 45 is what the factory booklet says.. although i drove mine in 4low 60-65mph 300 miles on dry pavement, no ill effects i noticed..
