Everything posted by backwoodsboy
Bucky needs a fuel pump?
Hey all, I finally got the 'ol Buckster inspected, insured, registered, and on the road, BUT..... I think hes throwing his first fit for me. I hope he's not homesick. SYMPTOMS: -lack of power on acceleration, (almost feels like MAF)... but idles smoothly (accel problem is better w/warm engine, but still there.) -fuel pump noisy enough to be heard from the driver's seat w/engine running -has failed to start on two seperate occasions now. WILL start after some begging.....but not right away. I would USUALLY suspect tune up/fuel filter etc as the root of the problem, but Connie has replaced all that already! NEW RELEVANT PARTS: -plugs/wires -cap/rotor -timing and acc belts From my quick search, I have gathered that the ea82 "outside of tank" pumps DO go bad sometimes. ? (Sorry, I havent owned a Loyale in a few years here, folks) Am I missing something? If no.... anybody have a pump for sale?
Having a problem going up hills
Tune that baby up! EA 82s ARE underpowered...... but you should be able to take *most* hills in at least 3rd gear. Change your: -Plugs -Air/fuel filters -wires -cap/rotor etc. Could also be a plugged cat converter (check 'er at night after going for a drive - make sure its not glowing red) Hows your cooling system / temp gauge? Edit: Is it carbed or F/I ? If its carbed.... give it a good cleaning/spraying
Wont shift to OD when cold??
backwoodsboy replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is correct. My 93 would always do the same thing (they all do) Just how the car is built.
95 Legacy fuel pump dead??
backwoodsboy replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. Behind the rear seats are your (2) access panels. The pass side panel comes off to reveal the fuel pump top and nuts that hold it to the tank.
backwoodsboy replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPassenger side panel
Bouncing tach...yea i kno what your thinking
For a quick-fix on that throttle cable, Ive had very good luck with just about any spray lube that contains TEFLON. Give the cable a good shot at both ends during a warm time of day, and repeat as necesssary. It wont take long to free that baby up. (also will work for hood-latch cables sticking.... or manual choke cables)
frozen weatherstripping
I was thinking of your PAM post from last year, the other day. I must buy some of this PAM, of which you speak.
Sometimes ABS sucks
backwoodsboy replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just put a blown fuse in the holder, and wrapped a wire over each blade. The other end of the wire was connected to a switch in the ashtray with the wires loosely threaded in. If I was to be in an accident, one quick pull on the wire would yank out the switch, wire, and blown fuse. ....and a spare (good) fuse left in the ashtray was there handy to slide right in.
Sometimes ABS sucks
backwoodsboy replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had ABS in my BAJA. I hated it when stopping in the snow. With the antilock, the snow tires never get a chance to "bite down" into the snow when stopping, and greatly increases your stop-distance. It IS nice when someone is braking WHILE turning (#1 sin of winter driving) Like Nipper says..... it helps most people maintain control.
tire studs where and how?
backwoodsboy replied to MilesFox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know if the guy at Autozone knows anything about studs, or is just "throwing this out there" ....but I dont believe you will have lasting luck with screws. While they ARE made of hardened metal, they dont have tungsten carbide pins in the center like real studs do.... and will not hold up long. I know youre gonna try it anyway... so let us know how you make out, I will be very interested
steps?
The steps came standard with jumpseats. My brat is an '86 as well, and I wondered the same thing for about 6 months
backwoodsboy replied to MilesFox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you get lots of ice in the winter? Not picking here, but I hope you werent serious about the sheet metal screws. Complicated little suckers, studs are. http://images.google.com/imgres?imgurl=http://www.tirerack.com/images/tires/tiretech/winter_tire_studs_pile.jpg&imgrefurl=http://www.tirerack.com/winter/tech/techpage.jsp%3Ftechid%3D151%26autoModClar%3D&h=185&w=250&sz=9&hl=en&start=2&um=1&tbnid=j5PkzF5UeSNNKM:&tbnh=82&tbnw=111&prev= I used to run studs, but now actually prefer to drive without them. I bought a set of the Hankook winter iPike snows, and have put them though their paces already. Mine do wonderfully without studs.
New Pics Of the Imp
backwoodsboy replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlookin good! Almost too pretty for mud..... almost The tint really makes 'er stand out
New to USMB
Hey Bret! Welcome to the USMB. Looks like you are only a couple hours south of Darlingchip and I.... and less than an hour from Harry's U-PULL-IT in Hazleton! If you need help/advice with your loyale, just ask. I grew up driving one.... and Im now a proud owner of a second
Mold Smell in Cabin
backwoodsboy replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as it is mold.... and not mouse-nest Lysol does NOT work on mouse nests!
Hankook tires
I just tossed my 14" hankook winters on yesterday. They are great on-pavement and off. I cant wait till winter really sets in!
Rocky picked up something...Rodents. Think its Fixed
I took the field to go next door. After all the rain.... there were foot deep muddy ruts! Not really an "offroad trip" ...but LOTS of MUD!!!
Check as many wires as you possibly can. I have seen rodents do some strange things to wiring harnesses, and they always seem to chew just a *few* wires that will make your car run like crap..... instead of the whole bundle, which could be easily spotted! .....its hard to believe its time to put our summer rides away already! My brat got put up this past sunday after a good mud run.
bad news about rust from the body shop
Steve, .......back the bus up for just a second. This is far from terminal. If they are saying your car is dead from rust, then mine must be a zombie, cause yours is NEW in comparison. I honestly think you should get a second opinion. Really. Any shop CAN do the work for you. It sounds to me like they are just tired of your vehicle coming there. Your sedan is one of THE NICEST condition ea81s I have seen lately on this coast. I have been underneath your car, and you are YEARS away from "hard to fix" rust ..... and not even CLOSE to "not worth it to fix" rust. Im SERIOUS. I would take that thing off your hands in a second. The only thing Im not sure about is how inspections work in your state....but I got my brat to pass NYS insp. (and they are picky about rusty frames) ...and my brat doesnt even HAVE those front panels anymore that are rusty on your car. If you cant find anyone to help ya, then I would suggest that you need some redneck involvement! I would be happy to do a welding get-together this spring. Your car will be CAKE to fix.
To toyota or not toyota
Toyotas are great vehicles (Ive seen 'em with 600,000 miles and still going) Either a sube or a toyota will last you just as long with proper care...... BUT, youre on a subie board asking if you should buy a sube or a toy. I would hafta say unless you want to REALLY offroad with this thing..... go for the subie, and enjoy all the attention you will get.
Replacing upper rad. hose
backwoodsboy replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont bother to catch the little bit that spills either.....but I always have been at the shop when I do this work. I dont dare spill coolant at the house. Too dangerous for the pets.
EA81 Typical Oil Leaks
Being a "non-timing belt" motor, the only places Ive ever seen an EA81 leak oil are from the valve cover gaskets, the oil pump, pressure sender, pan...and the mains. EDIT : oops! McBrat beat me to it!
blinker switch question
Yes. With the exception of rear defrost and rear wiper controls for the wagons, the dash and controls are IDENTICAL. Im actually running my 86 brat with the dash out of my 83 wagon as we speak!
GCK half shafts
I hate to post this..... but I have my first BAD thing to say about GCK, albeit minor. :-\ I was wheeling the other day (pretty hard -deep ruts, and suspension travel maxed out) I get home, and the DOJ boot clamp had slipped off! Just your usual "grease everywhere" situation and whatnot.... and I was able to repair (the clamp wasnt BROKEN, just slid-off) Anybody else have this trouble?!
Using a Sub in sub -22F
backwoodsboy replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI only offered some suggestions for (trouble free) driving. I think the key point is that the vehicle will be going "suddenly" into colder climates, from what I understood. I HAVE been frozen out of my subaru before (both doors and hood) by dampness in the rubber seals. Same as if you were going wheeling, or getting ready to drive through the desert. You probably wont NEED it, but.....being prepared is way better than being stuck.
