Everything posted by camosuba
The Cost of An Illusion
camosuba replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi know these guys have an alloy sump guard for the forester not sure about getting them to the US though http://www.users.bigpond.com/subaxtreme/
Radio mute for nokia car kit
Does the stock head unit for a 92 liberty/legacy have a radio mute wire fitted? this is for the std cark 126 nokia kit regards camo
the Paris auto show
camosuba replied to vic/se's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAussie B Spec It appears we have them here already
Wheel Bearings - Finished!
camosuba replied to joeo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood pics it'd be nice if all the things we want to do are set out like that for us:)
Do "Legacy"s Bend Valves When Timing Belt breaks?
camosuba replied to NorthWet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif theres no damage you should go and buy a lottery ticket its nearly 100% garanteed to do damage if they break on anything except the 2.2Lt engine So in reference to the eg33 engine a la svx are they the same as the ej22's? non interference? regard camo
Need help diagnosing cooling system stuff
camosuba replied to davidv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you bleed the radiator when you refilled it ? the bleeder should be on the left side of the radiator at the top (looking from the front ) the are known for erratic behavoir if they arent bled. and your cap may be past its use by date.The temp gauge should not move once the car has warmed up, thats how i know something is wrong with mine if the gauge is up at all from the normal spot there is something a miss and i check why :-\
Missing 93 Legacy
camosuba replied to handson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry the igintor its on the firewall in the centre of the car i had one fail and two plugs wern't firing :-\ or your coil pack ?regards camo
EJ22 Rev Limit differences
camosuba replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy ej22 redlines at 6500 and goes brarp brarp brarp at 6750 i would assume its a fuel cut?
Suspension Clonk 91 Legacy
camosuba replied to AussieIan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that'd be the first place i'd look you learn something new everyday!
2 cylinders out?
camosuba replied to tothetune's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your igniter its on the firewall in the centre if its a legacy i had mine go and thats what it was for me. se if you can borrow one to try regards camo
Problems up the ying yang
maybe the idle cut off solenoid is dodgy that would make it not idle the wire could have come off or there is some crud in the system?
Welded Differencial
When i did mine i used cast iron rods and pre heated the centre it was originally in a 76 wagon running 13's and uni driveshafts, it was unstopable (almost got up a hill that was so steep it nearly wanted to tip over backwards ) it was then put into a 83 wagon and has broken an output stub axle, bear in mind the larger the tyres the more leverage they have on your shafts expect breakages:banghead: , so carry spares and you'll need to keep buying tyres , I did a set on the rear in ONE DAY ! (but i got up that hill!)
Front wheel bearing replacement Legacy
Can any one give an aftermarket part number for a front bearing on a 92 awd legacy(and approx cost) , also is there any trick to changing them ?
The Backyard Boys at play - BIG Air
Having shown the pic to several work mates the first thing they say is WTF???and their general opinion is that guy is crazy
16" WRX Wheels on 1999 Outback?
camosuba replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou will be going 2.5% slower than your indicated speed with the new tyres/wheels i've seen several outbacks with wrx wheels so i cant imagine you'll have any problems abs sensors dont go on the wheel they're on the hub, and we have outbacks here in OZ with 16's as std equipment regards camo
Gen 1 Legacy - that little switch on the steering column
camosuba replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy understanding is you can turn the park lights on without turning the ign. on as most of us know the headlights dont come on unless the car ign. is on and thus lets you leave the car locked up in the dark with parkers on if need be. But its a pita if you accidentally switch it on while cleaning during the day :-\ then discover it later
Rx Turbo Header pipe EA82T
Has anyone had trouble with the header pipe cracking under the turbo and has anyone found or know of places that make aftermarket headers ? regards Camo
why is my impreza so slow?
camosuba replied to rugbyben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2.2 Liberty Awd 5sp sedan does 18.11 over the qtr mile, btw i got hosed by my sons rx turbo its a bit heavier i think 1360 kilos without me in it:) its done 270 000 k's so its not as quick as a lower mileage one i suppose
SVX coil pack?
camosuba replied to camosuba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo they go bad much? much my brothers is playing up a little and the dealer changed one for him and it is still a little sick so they think its another one gone off :-\ is there a aftermarket replacement for them? regards camo
SVX coil pack?
do these have individual coils for each plug or one for all?
"spy" pics of new 05 outbacks! and i got to drive it!
camosuba replied to Ratty2Austin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso what does the 04 look like? over there? cause i think we've aready got that one!
SAABaru
camosuba replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare you saying you don't like it ?:-\
- lift kits
Mmmm... fan question?
camosuba replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes they are running the car is smart, but the a/c can't tell if you are moving so they take the safe route and assume you're not.
What is a GT...
camosuba replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is sex on wheels i've seen one in emerald green it was beautiful but i still love my subaru
