SubPar
Everything posted by SubPar
From the Fumoto site: "Warning! For users under extreme conditions: If you are using the Engine Oil Drain Valve on off-road vehicles such as farm tractors and logging equipment under extreme environment (i.e. corn fields, brush areas), it is recommended that a hose clip as shown below be used for extra safety and security. The hose clip, which can be purchased at any hardware stores, will firmly keep the lever in the locked position at all times." The hose clip size is 5/8". Between the locking mechanism, and the hose clip, the valve isn't going to open. If you hit something hard enough to break the valve off, chances are the oil pan is going to get wrecked too.
Nissan 720 bench seats have a cutout for the 4WD lever, but I doubt it would line up.
Check out my avatar. That's my 02 Outback Sport. I made sure to clean all the oil out of the spark plug well before removing the plugs.The plugs were fine, no oil had leaked past the threads. I replaced the plugs (NGK) and wires (Rallitek) anyway, as that's what I was doing when I discovered the leaks. I added a can of Stop Leak additive to my next oil change, and I've been very careful to not overfill when changing the oil. 8,000 miles later, I checked the seals, and no more leakage.
Were do I put the cherry?
SubPar replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1. Cut a hole in your hood. 2. Fabricate custom header. 3. Cherry Bomb pokes through hole in hood, like a diesel stack. -
When it's done, I want it to look like this: http://4wheeldrive.about.com/library/uc/ucAzza.htm I finished stripping the sound deadening out of the interior last night. This weekend, I hope to have the floor pan painted/bedlinered, and get the 1 bucket seat I have cleaned up and installed. After that, the next step is to make cardboard templates for the aluminum dash. More photos soon.
Ea82 turbo 911 'SOLVED' thanx everyone!!!!!
SubPar replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I opened up this thread expecting to find a pictures of a Porsche 911 Turbo engine in an EA82. I'm so disappointed. -
Yeah, the "snow finder" center lights are really rare. They only work when it's snowing, and they emit a special type of light that allows you to see through snowflakes, even in a blizzard. I heard there were only 15 made, and I've only ever seen one.
moving to Wisconsin, who's there?
SubPar replied to Spiffy's topic in Meet n' Greet. Your USMB Welcome Center
Portland housing prices are just f'n ridiculous. Thanks California! Good luck in Wisconsin. -
My new project. It runs and drives, but needs a lot of work. http://www.cardomain.com/ride/3156092 Eventually, SAS, a bobbed bed, full cage and some lights. Right now, I need to finish the interior, and get some new tires.
http://www.sjrlift.com/
And another lifted wagon... http://www.yotatech.com/f5/crazy-off-road-datsun-square-back-pics-60408/
http://www.turbobricks.com/mods.php?content=art0023
Maybe this has been posted before, but just in case it hasn't... http://www.cardomain.com/ride/792800
OBD 1 or 2? With wiring harness or without? $250 is a steal no matter what the answers are to these questions.
One month later, and not much has changed. I sold the WRX LSD after I was sent front WRX sedan axles rather than rear WRX wagon axles by a vendor on NASIOC. I just got tired of trying to cobble some used parts together that may or may not be compatible with my car. I took the car to Wentworth Subaru, as they are two blocks from where I work. They replaced the right rear wheel bearing, and then said the noise was coming from the rear differential. So, I had them replace the rear diferential with a brand new one from SOA. Big $$$$$. I picked the car up yesterday, and the original noise/vibration is still there. Took it back to them this afternoon, and I was told to come back Monday, and they would take care of it. I've paid almost $2000 to have them throw parts at the problem, and nothing has been fixed. Hopefully, this problem will be resolved, as I just bought the car there last November, and I have only put 8,000 miles on it, mainly commuting and short trips on the weekend.
If you still have the factory spark plug wires on it, they should be marked 1-4, or at least they are on my EJ25.
Documented: The 1970 FF-1 Project car...
SubPar replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Nice! Looks like the stripper did a great job. What are the plans for the roll cage? -
My 02 Impreza has the exact same problem you described, except it's an auto rather than manual. The idle is rough and inconsistent, and fluctuates 750-1000. The problem improved after I installed the air filter correctly, with all of the clamps on the air box properly latched. You think buying a used Subaru from an established dealership, they would check these kind of things... But then again, it came with 2 of the 4 tires having small punctures and nails in them, as well as a blown front strut, and a bad rear diff. My solution is to tell your girlfriend she doesn't need AC. It's Oregon, not Florida. That, or go to the dealership, and do what I did with my tires full of nails. Don't leave until they make things right, even if it means having an arguement with the manager right on the sales floor on a busy day. It's not what I wanted to do, but what I had to do.
Deathhatch... http://s36.photobucket.com/albums/e40/jessicas_man/subie/
