Everything posted by porcupine73
Idle oil light flicker (95 legacy L)
porcupine73 replied to lilears4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could put a low range oil pressure test gauge on it to see what the oil pressure is at that point. If the oil light is flickering, the pressure is either pretty low or the pressure switch is faulty or there is a blockage in the gallery. The oil pressure switch is located under the alternator. The thread is 1/8" BSPT (british standard pipe - tapered thread). Some oil pumps had issues with the rear case cover screws backing out thus leaking oil, and sometimes pushing out the front crank seal. Do you have any leaks? If you pull the oil pump and remove the rear case cover, you can measure the rotor clearances and the rotor to case clearance. Then you can decide if you need to replace the oil pump or not...($100+). The rotor matched set can also be purchased and installed in the existing case (provided the case hasn't worn beyond service limits). I don't know what kind of ambient temps/loads you're running in, but Subaru does list some heavier engine oils, even 20W50, as acceptable in high temp/high load situations.
got car washed this weekend... had flashing brake light on the dash
porcupine73 replied to unverviking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can. Erratic Warning Light Operation (EndWrench.com) When diagnosing a vehicle with erratic operation (flashing, dim illumination, etc.) of the handbrake/brake fluid warning lights, check the charging system and the charge light system. The charge light system (which receives a ground through the alternator field when the alternator is not charging) is used to check the bulbs of the handbrake/brake fluid warning lights (and some other warning lights on select vehicles).
2002 Legacy Outback Stalls At Stops
porcupine73 replied to DOORSTOP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if this helps, but I saw this on EndWrench: A rough engine idle condition may occur when the vehicle’s battery is disconnected for less than 30 minutes on some 2001 and later Subaru vehicles, up to and including the 2003 Legacy and Baja. The rough idle condition only affects four cylinder, non-turbo vehicles. 2004 model year vehicles may also be affected. Clearing the memory with the Select Monitor will correct this condition. Also, the ECU will most likely clear itself if the battery is allowed to remain disconnected for more than 30 minutes.
97 obw AC recharge?
Yes, you really need an a/c manifold gauge set to do it right. These can be had for maybe $35 from Harbor Freight on sale, and to me it looks exactly like those sold for $200+ other places. If you go to http://www.endwrench.com click archives, and search for 'a/c', you'll find tons of articles on Subaru a/c service. Here's a pretty good one: A/C Maintenance and Service: Keep 'em Cool AFIAK, you only need to recover the 'freon' on the old R12 systems. Heck, R134a is even used in those computer air dusters and freeze sprays.
Codes P0451 P0453
porcupine73 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor 2.5L ('00obw): DTC P0451 - EVAPORATIVE EMISSION CONTROL SYSTEM PRESSURE SENSOR RANGE/PERFORMANCE PROBLEM DTC DETECTING CONDITION: Two consecutive driving cycles with fault The service procedure has you check all the gas cap, fuel tank hoses, filler pipe, etc., and if those are good replace fuel tank pressure sensor. DTC P0453 - EVAPORATIVE EMISSION CONTROL SYSTEM PRESSURE SENSOR HIGH INPUT DTC DETECTING CONDITION: Immediately at fault recognition The service procedure basically has you check all the connections for shorts/opens/etc, and if all those are good replace the fuel tank pressure sensor. At least on this '00obw, it shows only a couple bolts/connectors to replace the fuel tank pressure sensor?
Code 22 - Knock Sensor Oddity
porcupine73 replied to mtnwater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be; the ECU wants to see a certain impedance presented by the knock sensor; there could be a wiring issue elsewhere. Is the new knock sensor to block mating surface clean, and is the bolt torqued properly?
93 Legacy: Dead A/C Compressor! HELP!!!
porcupine73 replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's the Subaru retrofit instructions from EndWrench, in case you're interested. I've used a few of those conversion kits. One on an '88 lincoln, it seemed to work just fine. I also used it on an '87 Ford F-250, but within a short time it started leaking oil from the a/c compressor and other areas...not sure if that's because of the kit or not...
porcupine73 replied to DOORSTOP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow's the fuel pressures and fuel pressure regulator and fuel filter? Also, while idling with the air filter out of the way, a shot of throttle body cleaner aimed up at the IACV intake just before and above the throttle butterfly, might be a quick easy thing to try... I think there was something on EndWrench that said to make sure the negative battery cable was clean and securely connected in cases of poor idle.
Mobil 1 - 0/40?
porcupine73 replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool, is this a new oil? It's hard to tell on some of the high viscosity spread oils is whether they contain a lot of VII's (viscosity index improvers). These can shear back over time. Synthetics generally have good VI's to begin with and don't need a lot of VII's. Someone said this 0W-40 provides more shearing abilities then the 20/50. I didn't see a 20W50 on Mobil's Web site, but other brand 20W50 oils have much higher HTHS (high temp/high shear) scores than the 0W-40.
Cooling fans not turning on- 1990 legacy
porcupine73 replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you power the fans directly at the their connector to make sure they both work?
Relocating knock sensor
porcupine73 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool. I pulled mine completely, wrapped it in bubble wrap, and grounded the bolt hole. Didn't notice any difference, but I wasn't having issues before I did it either. Been that way for 6 months. Maybe I'll put it back in now.
porcupine73 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the KS is faulty/going faulty (i.e. giving knock sensor codes), relocating it won't help. Fuel economy/power may increase if ECU was pulling timing due to detecting knock and now after relocation it is not detecting knock. If KS is functioning properly and engine is not knocking and ECU is not pulling timing based on KS signal, then relocating it will make 0 difference.
differential breather hose leaking?
porcupine73 replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, I'd suction or drain to the full mark. If it's overly full, it's probably churning up in there real good and maybe sloshing up and out the breather hose. Is it ATF or gear oil coming out?
4EAT More Confusion from Subaru
porcupine73 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen it a few places. About $6 a quart. It's Idemitsu ATF-HP. Idemitsu is a pretty big player (in Japan!) http://www.subaruparts.com/catalog/?section=366 I do not necessarily agree with the 'lifetime' lube on any fluid. It also depends what they mean by 'lifetime'. Some manufacturers mean the length of the warranty. This fluid has different frictional characteristics than the Dexron III. I think there is an article on EndWrench about it. Anyone know if those 5eats are made by Jatco ? I think nissan and some others are using the jatco boxes, which I believe take that same fluid. edit: if you buy some, pick up a few extra quarts so you can keep it in your vehicle emergency kit.
Fluid Chnage ?
porcupine73 replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnother option, if you don't want to attempt to pull the plug, is shoot the plug and the area right around it with brake cleaner. Get it clean. Then just smear some permatex ultra grey or something where the plug meets the pan. Not a lot, just enough to seal it. That should hold it until you pull the plug again.
Rear camber adjustable '00 obw?
Hi, is rear camber adjustable on '00obw? I don't know what this suspension type is called. The right rear appears to be right around 0'. The left rear appears to be about -40'.
'95 LOBW - Mysterious Noises While Braking...ABS?
Hi, not sure if this is helpful but here it is: ABS System Check (EndWrench) The ABS Electronic Control Unit checks all system components, including the Hydraulic Control Unit, each time the vehicle is started. When the Hydraulic Control Unit is operating during this checking period, the owner/technician may hear a noise/buzzing coming from the engine compartment. They may also feel the brake pedal pulsating slightly if their foot is on the brake pedal. This pulsating of the brake pedal may be more noticeable when backing down a slight grade (sloping driveway). It may also be felt when moving forward. The check is not performed until a speed sensor input is received by the ABS Electronic Control Unit. This is a normal function and no repairs should be attempted.
Lifting the idle on an EJ22
porcupine73 replied to SuBaRiNo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes the PS pumps have a pressure switch, one of the things I think it does is bump up the rpms if there is enough load on the PS pump. If you have that maybe you could wire into it to cause the idle bump up whenever you want.
Finally a cure:..Lubgaurd added to the PS fluid
porcupine73 replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's cool. I've heard good things about the Lubegard additives. I would have used an ATF additive since these units don't use PS fluid.
not good
Do you have an AT or MT? I've heard using wooden clothes pins can be helpful in holding the belt in various places while lining it up. Maybe you need a new tensioner? I think EndWrench said it should take least 3 minutes and maybe as long as ten to compress the tensioner slooowllllyyy.
Anyone Else's Throttle Touchy??
porcupine73 replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool! I had this touchiness too in '00obw. (Although it is an AT, you had to get on it slow or it would jump kind of). With engine off, I held the throttle wide open and sprayed valvoline throttle body cleaner all over the place up in there and cleaned the butterfly real good. Then held throttle at about 1/4 and fired it up. After it was done coughing and sputtering I let it return to idle. (Yes, watch out for smokescreen - suggest not doing this in the garage). Then I got up there and gave 1/4 second shots of the valvoline in the intake up where the IACV intake is. It would sputter again for a second. Did that about 12 times. Did seem to help quite a bit and the idle rpm doesn't seem to shift around as much anymore.
not good
Step 1 is make sure all maintenance has been performed, plugs, wires, filters, etc. OEM plug wires should be used. Make sure coil contacts where they plug onto the spark plugs aren't erroded.
porcupine73 replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...okay, well if neither fan is even coming on with the A/C then I think you should maybe backtrack from the fans themselves. Do the fans work if you unplug their harness and power them directly like with (fused) jumper wires? If that works, then may need a wiring diagram. Maybe the fan relays are bad, or there's a wiring issue, or the ground is bad, etc.
not good
Uh...could be just about anything. Is the vehicle in proper tune? You know, fresh filters, plugs, wires, etc.?
porcupine73 replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo any fans come on if you engage the a/c (if it has it)? How do you know the temp is hot enough for them to come on?
