Everything posted by SoobGoob
thanks, i was reading about the accord springs but i dont want my suspension stressed. just stiffer
for my loyale. thinking of a 3.5 lift and replacing the struts at the same time i want something stiff anyone have any experience in this matter?
i know it is getting fuel forsure. and to answer. the pump was bad to begin with because it did not pump. it did not prep it did not do anything even when out of the tank and i had it wired straight to the pump. the new pump works and preps. i get gas to the engine and it works. so lets have no more talk about the old pump. new one is in and working. it will not work even when the throttle is open at any amount. i am at a loss and have not felt like working on it for a few days. ill get around to it when im tired of taking the bus. someone help me before i get a jeep!
ok so i bought a new fuel pump and have a bad sender still. but all i want is it running first. so with the new pump my engine is all plugged in and is getting spark and fuel. shocked myself to make sure it wont start!! it turns over and is very close. also are these 0 clearence engines? i dont want to bend my valves if the timing is off but im pretty sure its not. any ideas as to why its not firing up? how do i reset my ecu? is that a possibility since i replaced my fuel pump i have heard of cars having to get the ecu reset after that part replaced. hope this makes sense and someone can help
so i have a bad pump and sending unit in my 91 sport sedan. to buy everything new is 350$ yikes dont have that much. so what are my other options as far as replacing it with a 99obs fuel pump. or other things like that. i know if all else fails im going to the bone yard to grab one. as long as the pumps arent different between the sportsedans and the non turbos if someone to clarify that. thanks guys
obviously a short but does anyone have any light on the subject? where harness runs where it might not be protected. where i should look. thanks!
talk to 86ruguy hes lookin to set up a bbq on laborday in tacoma
i am in dire need of a engine hoist and a engine stand for a couple days. can anyone lend me one??? pleaseeee
ej22t HG's
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
sounds very dangerous -
ej22t HG's
alsohow do i take the exhaust off??? i cant find the bolts. do i have to remove the heat sheild?? -
ej22t HG's
haha yes i have done head gaskets before but on ea82's so cam tower o rings, intake manifold gaskets exhaust manifold gaskets, head gaskets, does that sound right? and is there a way to lock the crank so i can take the bolt out of the drive pully? without buying the special tool
