45
Everything posted by carfreak85
Snowing In Cheney!!!
carfreak85 replied to PeterD's topic in Meet n' Greet. Your USMB Welcome Center
Wow, I wish we had 4 inches in Bellingham! Just 1.5 here... -
Ok is this for an EA81 or EA82 Body Style?
carfreak85 replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It looks like it belongs on an EA81. I can't think of ever seeing a factory brushguard for any EA82. -
White smoke exhaust
carfreak85 replied to myfinalcoffinx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like there is a small crack in the head that, when it gets hot, closes up and leaks less. -
WCSS8 Where will it be?
carfreak85 replied to Scott in Bellingham's topic in Meet n' Greet. Your USMB Welcome Center
If you help organize it, I guess it can be where ever you want. -
Be careful about decking the heads, if you do it too much the intake ports will be too close together for the intake manifold to bolt on. Just a thought.
EA71 1600 or EA82 SPFI pistons will raise your compression to about 9.0:1. Do some mild porting on the intake, exhaust ports and intake manifold to clean up the terrible casting flash. Other than that, a weber and exhaust work will help out a lot.
Seeking rally service crew...
carfreak85 replied to XSNRG's topic in Meet n' Greet. Your USMB Welcome Center
I could probably be persuaded to help. Just let me know when things start up, when and where to be! -
RHD brat would be cool
carfreak85 replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think it would be really cool! What do you think shipping was on all those parts? And would the new steering shaft interfere with the turbo set up at all? Pics? -
80's rice front spoiler?
carfreak85 replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, we ARE!!! Winter break is coming up fast and I need a project! -
It was pretty easy on the gen 2 car since they had them earlier. I just unbolted the bottom of the core support and cut out the top half. Drilled some holes for the top of the center lamp to bolt to and thats about it. I also had to cut the grill because the quad headlight set up came around after the cyclops had been killed. A friend of mine and I tryed putting one on his gen 1 brat and found that unless you're prepaired for some serious fabrication, it will not be an easy conversion. -
He knows the secret! Its like Qman says, one for the street, one for the woods! -
I'll second that! Yum yum! -
Sweet!!! How much did all the gear cost you and what did it take to make it work?
I finally got all the new bearings greased up along with the seals for the front wheel bearings. They are pressed into the knuckle, but now I can't get the knuckle back on the axle. I don't have the special tool that the FSM suggests using. I need this car to drive back to school tonight, so if anyone has a trick or suggestion, please lay it on me!
Thanks a lot for the advice guys! Thats why I love this board so much! I ended up using a BFH and a block of wood to beat on the end of the axle. Worked like a charm!
I'm trying to get the hubs off my wagon, and I have everything off except the disc and hub. They are still on the axle. The cone washer is stillin there and I can't seem to get it off. I don't want to pry on it too hard since I don't have too many sitting around. I need this car to be done tomorrow night so any help you can give would be great.
That thing sure looks burly!!! My Kumhos have got to go now, I need me some SWAMPERS!!!!!
Are you sure? The way I understand a viscous differential works is by shearing those long silicone molicules in half to get the desired limited slip characteristic. This would mean that the fluid would eventually break down and the diff would not work a well. Anyone have a FSM who is willing to clear this up?
Proof of the Elusive Subaru Diesel!
carfreak85 replied to robm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I LOVE MY SCHOOL, I LOVE MY SCHOOL!!!! :banana: I also have a blurry picture of a set of EA81 heads that were modified to diesel. When talking to the current prof of the VRi (the program I'm in) he said that the EA81 diesel ran like crap. -
Extra gauges with the dig. dash? optional???
carfreak85 replied to subeman90's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never, ever heard of that. Would it be possible to go back and snag those? -
Superlite Wheels
carfreak85 replied to Barry Knickerbocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would be all over these if they were 8 spoke, but I have the enkeis already, so I'll stick with those.
