Everything posted by tcspeer
'99 OBW Front Struts
tcspeer replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had Midas do mine with the lifetime warranty, and have already got one set free since then. It cost right at 500.00 for parts and labor the first time.
hmm, now what do i do? gas fuel door
tcspeer replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter rereading your first post I see you had already tried what I thought would work. Have you tried looking from under the car up? Maybe someone here has run into this before, The only thing I have messed up back there is the fuel door itself by walking into it and bending it while it was open.
tcspeer replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXForget the paper clip I just looked at mine, looks like you will need to open door all the way and then take the cap and inner cover off, maybe the little holder just turned and backed out of the hole. It looks like you should be able to reach it with the cover off.
tcspeer replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have room to unfold a paper clip and get in behind it?
engine misfire is it bad?
tcspeer replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was taking about the one in Oregon, but I would not base my opinion on a company because of what one person that works for them says. And maybe he was trying to say it would be better to get a new flywheel then to cut one down. I agree with this on brake rotors but I dont know about the flywheel being I have an Automatic. I was just trying to tell you where you could save money.
tcspeer replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, buy your Subaru parts from some of the places mentioned here on the board one is 1st Subaru parts or the one I like which is Lithia Subaru # 1-866-717-2512, these places will save you lots of money. You can check your old wires by spraying a light mist of water on them after dark to look for fire jumping ( Do this only when the engine is cold ) you can also check the wires with a multi meter. \\
95 Legacy Wagon Hesitating and Popping
tcspeer replied to ekimyerac's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with Strat, sounds like the coil pact. You can check it with a Multi Meter and the instrustions out of the Haynes manual, for Subaru. The coil pact dont cost a lot and is very easy to change.
ECU failure???
tcspeer replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the car wont rev. up there is a chance the inside of the muffler has collapsed. Check the tail pipe and make sure someone has not stuck something in it.
Engine Retirement?
tcspeer replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont give up on the back, when I had the disc done in my neck it took a while to heal. I am sure you know this but just in case you dont you can have the valve stem seals fixed for very little money. I think you just remove the valve cover and fill the cyclinder with air. I am not sure on the details but I am sure someone here is. I had some done this way on a 305 chev. engine years back.
Check Engine Light
tcspeer replied to halston2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is very good OB99W, I asked the local mechanic about the details of how the noid light works and you have nailed it.
Check Engine Light
tcspeer replied to halston2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think he said he replaced the coil pact, is that the same as the spark pack? When my # 3 misfire showed up, I took the cheap in line spark tester and was able to see the fire was getting there so no further test was need on the elc. side of the misfire. I dont know if he has done this, but it also would be a good ideal. I agree with you I think the gas suggestion is a bit crazy.
1998 outback wagon all door lock not working with key
tcspeer replied to bluebird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 97 wagon, but when I unlock the drivers door I then unlock the rest with the button on the inside, if their is someway to unlock all four with the key, then I have not known it for the ten years I have had mine.
2001 Outback cig lighter removal
tcspeer replied to PennyWeiss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine is a 97 and it had two wires to unplug and then you screw the outer shell off and the inner part will pull out of the front. But you will most likely have to take the bottom center panel off first. The details are in the Haynes manual. Yours may not be the same as mine but on the 97 remove the cup holder then the two screws on the ends, and then they are two right above the ashtray. Be careful putting it back together because the plastic will break easy.
New rear brakes on 98 Leg. O.B. Ltd. Wgn.
tcspeer replied to Low Budget's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo it is not normal, do you know if it is coming from one wheel or both?
'95 Legacy rear rotors
tcspeer replied to SeanC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was indeed a great call Legacy 777
Check Engine Light
tcspeer replied to halston2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put the noid light to the injector plug and found it would not light, so I checked the other three and they would. So someone here on the board told me to check and see if current was coming to the connector so I checked that and found 12 volts. ( I think it was 12 volts ) The noid light dont light from the current from the battery it flashes with the signal from the E.C.U. if I remember right. So I had current going to the plug but it was not getting the information from the E.C.U. to do what it was suppose to. That is why it became the suspect. But dont forget I came here asking for help with this and had many lead me to the final answer so I am sure someone here can better answer your question than me. (
93 Legacy Wagon driveshaft center bearing
tcspeer replied to ekmissal98SUS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCall a good wrecking yard, they have that information at hand, if you need the name and number of a good yard try sales@findusedparts.com or tollfree at 1-888-337-7757 they have lots of Subaru parts with fast shipping.
Check Engine Light
tcspeer replied to halston2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a cyclinder # 3 misfire that turned out to be the E.C.U. unit. If you will buy a set of noid lights you can check your injectors connectors with them, and they are very cheap at most auto stores. If the light dont work on # 4 (and it did not light on my #3) check and see if you have current to the wire that goes to that injector, if you have current then you will be where I was and the E.C.U. fixed my problem.
New rotors/pads making big noise while braking, what gives?
tcspeer replied to BlueSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid your mechanic clean the new rotors with brake cleaner? If not your pads may be contaminated, this will usually make a groaning noise when stopping. The new rotors have an oil on them to keep then from rusting. Also you need to find out if it is just one or both making the noise, if it is just one it may be out of round even if it is new. I have had to take new ones back that were bad.
Buzzing noise in rear
tcspeer replied to DeSubiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny failure with the A.B.S. is not suppose to do anything to change the normal breaking operation, it is always overrode and then works just like a car that has no A.B.S. or that is what is claimed by the makers of the systems.
tcspeer replied to DeSubiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have A.B.S. sensors on the rear brakes?
Difficult Hot-start after injector cleaning
tcspeer replied to itzik93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would not have a lot of faith in this suggestion, but if you have not done it , I think I would undo the battery for around 30 min. to reset the computer, it may help and is very little work.
RHD '97 Legacy Outback at pnp in SE PA
tcspeer replied to Rob Kuhlman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe right hand drive Subaru's were sold to rural mail carriers from the early 90's untill around 2000. I have a 1997 right hand drive that now has 310,000 miles. You will see a lot of them around post office's in the rural towns. As for as the parts nearly everything will exchange with the left hand drive, except the steering links on the front and the heater core. I am sure they are some other things also, but that is all I have found so far.
2.2L 1990 Subaru Legacy Timing Belt
tcspeer replied to 1990sub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes look for the little line mark on the tab of the crank spocket. they should be a little line mark on the cover behind the cam spocket also.
How much for Wheel Bearings?
tcspeer replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say around 300.00 for each side. If you take the spindle and hub off you can take it to a small shop and they will press them in for around 20.00 each.
