Everything posted by tcspeer
Leaking heater core
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFeel free to bash me on the stop leak, I can take it. It has been around since the middle of last century, and I dont know of anyone that has won any judgement for damages to their engines. In fact on the new packages of bars leaks it says something to the fact, the ones used by new car manufactuers or sometime like that, I threw it in trash so I dont remember the exact words. I used engine stop leak in my 2.2 and never changed a cam seal on it, and it had 288,000 miles. However the dealer did change one when it was in warranty.The engine would still be fine if the idle pully had been changed at belt change. I will post the date if it starts leaking again. So maybe then someone else will know if it is something they may want to try.
Brake Questions??
tcspeer replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is good information Snowman but for me its two sets of pads and then new rotors. I dont even waste the time anymore to get my 24.00 mic from Harbor Freight out of the case.
Leaking heater core
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Shortlid I would like to have those directions, I took another look at my Haynes manuel last night and your right it dont look that bad, it just scared me the first time I looked. I put bars leak in it yesterday and it has stopped leaking for now. I know some here will think that is crazy but I have no problem using it.
Brake Questions??
tcspeer replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSteve you are right about the pads moving that causes the squeal, but a rotor out of round might also cause the pads to move.
Leaking heater core
My heater core is leaking and I have no desire to try to crawl under dash to work on this. Does anyone know how many hours Subaru will charge, to change this? I already have the price for the core it is nearly 200.00. It looks like a very big job from what I read in Haynes manuel.
Brake Questions??
tcspeer replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJared, I also have a 97 Legacy L wagon, mine is fixing to turn 300,000 miles most of these or stop and go miles from mail del. You will do fine with the semi metalic pads from Auto Zone and the 30.00 dollar rotors they have. You dont need the little backing plates, theirs come with the metal back just put a little anti squeal on the back of pad. The most important thing I have learned about brakes is dont waste your time turning a rotor buy a new one. I go through around two to three sets of front brakes for each rear set. Be sure to remove some brake fluid before pushing pistons back in calipers.
95 Legacy coil pack
tcspeer replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery easy to change. You dont need to change it unless it gives trouble and then you should get a code with the C.E.L.
Differential side bearing retainer problem?
tcspeer replied to ttmuench's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know how much movement you are taking about, but mine also has some movement in and out. I also dont know if it is normal, but it has been that way for years.
Headliner Rattle
tcspeer replied to sparkster58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 Legacy wagon had a rattle in it when it was new, turned out to be the top metal roof was seperated from one of the cross members. I had to go above the local dealer to get it fixed. Someone from S.O.A. from Col. ended up fixing mine.
Help Quick...
tcspeer replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe the intake gasket is blown.
question about front brake parts
tcspeer replied to PastorBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get what you need from Campbell Nelson Auto Recycling, Toll Free 1-888-337-7757, ask for Jason, he is over the Subaru parts. You can get your parts sometime in one day by express shipping. Or for less money shipping you can get them in two to three days. They are in Arlington Wa. I have been using them for years and I am well pleased with them.
need help with emergency break issue on 2000 Impreza 2.5RS
tcspeer replied to PastorBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwitch sides with the rotors and see if the rubbing moves to the other side. Could be the rotor is out of round, even if you did just put new ones on.
to all those who have a spin off tranny filter... read this
tcspeer replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlitz, well put! look for a P.M. from me.
tcspeer replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would like to let others know about rockauto.com also. Great site for looking up parts not only for Subaru but others cars also. Low prices, fast shipping. Check it out.
Half-Axle Replacement causes idle shudder....?
tcspeer replied to WANTONSOUPGUY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery interesting Midwst, I have never heard of this.
97 Legacy L, where to get key?
tcspeer replied to Flowmastered87GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the only dealer that can cut the key from the Vin number is the dealer that sold the car, they sometime make record of code number with the sell. If not you can take the trunk lock out and get the number that is on it and take it to locksmith and he will be able to cut the key by this number. You may be able to see the number on lock with out taking it out.
tcspeer replied to WANTONSOUPGUY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 Legacy does the same thing, if I put it in Park or Neutral, it will quit. Or if I kick the throtter up a little it will stop. I have not been able to get the answer for this problem here yet, but I think we will soon. I dont see how your problem could be related to the axle change, Have you tried putting it in Neutral and leaving your foot on the brake and seeing if it would stop?
Timing marks on cam sprockets (1996 2.2)
tcspeer replied to Subarunation 713's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey should be a little indentation line on the outter face of the spocket, not real easy to see, near the edge.
Aftermarket gauge selection
tcspeer replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the most under used gauge is the one we all have, the air gauge for the tires. Proper air pressue will increase gas mileage.
IAC valve, maybe ?
tcspeer replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSitting in drivers side it should be on right side of engine a little more than half way back from front of engine, temp sensor is right close to it, if I remember correct. You should be able to look at Legacy manuel and find location. It has an air hose and coolant line that goes to it.
plug gap for a 96 outback with a 2.2 liter
tcspeer replied to L67cooled's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX0.039-0.043
CV Joint removal
tcspeer replied to soobyfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt has been a while since I done it but you need to seperate the ball joint also. If you can get a hold of Haynes manuel it will give good details. The whole hub assemely needs to swing away from axle.
Exhaust sputtering on 95 Legacy
tcspeer replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you took the washer tank off to change the plug you may have got a little water down in one of the cyclinder holes when you were putting it back on. It happen to me once. After driving it you may have dried it off. Also could be one of your new wires bad.
How do I remove rear diff drain plugs?
tcspeer replied to Forester_Ranger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI remove mine with a 1/2 in. drive breaker bar. The fit is not as tight as it should be but I get it out. That is a good suggestion from Adnan about removing fill plug before drain plug.
oil burning?
tcspeer replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy opinon is different, if you are sure the oil is not leaking I think you are still good to go many miles. We have in our family a 92 Buick it has been an oil burner for over ten years and is still a very dependable car. I cant tell that is has gotten much worse then it was years ago. The other opinon about going to a heavy oil is problary a good ideal.
