Everything posted by ivantruckman
Ignition left on, engine not running, damage?
if the battery is discharged it could be frozen, try to bring it indoors, in Mi we have been just below frezing, do know about Mo
FI eatin gas like crazy
is your C E L on ?, it could be a number of things, like o2 sensor, dirty throttle body, maby even a plugged up cat? is it running slower than the regular slow?
good manual for a loyale? or exploded diagrams?
http://www.finleyweb.net/JonsStuff/SubaruDocumentation/tabid/54/Default.aspx try this link , they work good for me
Shifter slack!
the rubber block can come loose from its mount too, you can use some good zip ties and some epoxy, works great. ill try to get some pics tomorrow when i get back to the shop
EA82 vs. EA82T Tensioner Pulley
i beleive there the same. i have been able in the past to get an off the shelf bearing and press it in, i would save the old one and rebuild it, for a spare
cut fenders how to?
because of the rust i had little choice, i also needed to trim the lower rear door, im using a flat camo sceme for paint too, its alot more forgiving than a normal paint job
cut fenders how to?
i was able to get 27 inch tires under it with no lift kit. and no bottoming at all
cut fenders how to?
some pics of my cut job... http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=fendercut.jpg i made a cut along the upper fender arch line, leaving enough material to weld to, about 1/4 inch ..do not cut thru the inner fender , you will need this later to curl upwards , and to weld together, you can use a pnumatic muffler tool. harbor freight has them for under 20 bucks http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=fendercut2.jpg you can use the material from the inner fender , hammering it upward http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=fenderhamer.jpg then tack weld it, grind it down ,than putty it in http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=PICT0033.jpg i did the front too but theirs no inner fender to weld too. i just used a peice of 1/2 inch round stock and hammered it around, and streched it a little http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=frontfender.jpg
14" steel pugs @ Foster
plane ticket 800 bucks, sweet steel pugs 28 bucks, 828 bucks :-\ sucks to live out east somtimes
Timing Belt Kit...ebay?
my kit has 20 k and still going
some more pics....
this is an eastern subie, in the rust belt of mid michigan http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=fendercut.jpg
What's the toughest, stickiest primer spray?
most of the problem is surface prep. what grit paper did you use and did you use a surface prep solvent just before you primed ??? oils from sanding and your hands can affect adhesion. if you have bare metal you can try an acid etch primer, and wet sanding between coats with 600 grit wet paper, even if you grind all visiable traces of rust it almost always comes back.
i tried the search...
they used different distys for 4 wd and 2 wd as well
Left headlight burns out, explodes in lens
the sealant between the lens ant the housing can fail. i clean it with a wire brush and then use silicone around it, also check for stone chips, you can silicone them as well. you can use a hair dryer to remove the moisture before you seal it up
Towing a justy
4wd, auto,yikes i would trailer it
Ad in local paper, '92 Loyale -Opinions?
my 3at loyale does about 4000 rpm at 55 mph, other than that its a great city car
92 loyale starting issues?
check all the engine ground wires for corrosion, my 91 loyale did the same thing
3AT question
is your fluid dark, i think you would find out alot if you drop the pan. look for shavings either steel or bronze or copper flake. the dark fluid is from worn friction material, any shavinngs are from hard parts, either one isnt good
Need Honest Opinion....Reality Check
this is gunuine east coast rust http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=rust4.jpg i had to uthenize this ole girl, it was a sad day
6inch lift kit home build
hey scott ..the pipes are 4 1/4 od .125 wall i cut the flanges with a plasma cutter, i cut out a template out of wood , and use a drag sheild. still a lot of work to do. and steel prices have gone up big time, i used drop peices at the local steel shop, but i still have about 100 bucks in small peices of steel.. http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=blockinstall.jpg
Bacon Fat on underside of oil filler cap??
my guess would be oil and water, the condensation inside of the engine heats to steam and rises to the top of the engine and cools slightly on the cooler under surface of the oil filler cap
i wanted to do my own lift kit, im a stubborn cuss.. i found out why others get the money they are asking. these kits like scotts are actually very reasonably priced when you consider the time involved in fabracating, but i have to prove that i can do it, but im considering buying the next one. day one http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=strutower.jpg http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=6inchblocks.jpg http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=liftkit1.jpg
Re-seal: EA81 Pwr steering rack input
i remember being able to get a seal from advanced auto, but that was for the ea82
Building rear EA82 Lift.
the rear are shocks, on my 86 and 85 ea82
My $100 brat
hell thats cheaper than the scrap value, and a free set of pugs
