Everything posted by davebugs
Bolts
davebugs replied to Sabaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPost up a pic or email someone. I have a lot of those bolts and parts here. Working on stripping a 97 2.2 now that had HG issues. Or PM me for an email to send pic to.
Hello from south central ohio
Read here about burping before you start the drain/fill.
Welcome. I don't know of anyone in your area but someone else may be able to help. If you decide to do it yourself the folks here are very helpful.
1995 legacy blown hg, OC, NY
davebugs replied to Grumble7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm thinking was never burped properly perhaps.
1996 legacy 2.2 no power
davebugs replied to boatrick1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd probably star twith knock sensor.
$100 used head or repair bent valves?
davebugs replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe used heads. GG I'm heading down your old way to pick up a TDI today Woodbridge VA
Engine removal..
davebugs replied to tidd1340's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYES - actually you can usually get the engine out with it attached, but not in. Just remove the bolt at the end/trans end.
Screwed up knuckle/spindle - options?
davebugs replied to binary visions's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI recently found out that PB is supposedly corrosive. So I wouldn't use it as a lube. Strickly as a penetrant. I found out when having work done on my car and my friend asked for WD40 to spray on some electrical connections before removal. He says PB is corrosive so to never use it on wireing connectors. And if you read the can of WD40 you know it's the opposite. I still don't think of WD40 as any kind of a penetrant though. But it worked on the wiring connectors in my car with over 200k in the rustbelt.
Issue Finding Part - Release Bearing Clip
davebugs replied to Maves230's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. ALWAYS replace them both when you're in there. I believe they are actually called Throwout Bearing clips - but not sure.
Is my 2001 Legacy 2.5 SOHC on Interference motor, or NOT?
davebugs replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea - my VW TDI is cerainly interference too and you wouldn't think so by reading that link. It my observations I'd think a blanket statement like anything made after 96/97 is LIKELY to be interference based on VW and Subaru experience mostly.
davebugs replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour friend needs a new book. Or was looking at a 96 or earlier 2.2 engine. Expensive thing to be wrong about this.
HELP! Pulley removal mission impossible
davebugs replied to methusalah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat puppy is TIGHT for a reason!! Make SURE you get it TIGHT again when you're done. I ave a tool to hold it - but so use the starter method when I have too. My long snap-on breaker bar jsut makes it to over by the battery tray.
davebugs replied to methusalah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFOr clarity what year? It's probably a bolt - and is standard threading L to loosen.
White smoke blues...
davebugs replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX7/8 srwnch or special sockets (I kinda like the box end/open wrench combo most of the time. Soak it down good, have patience - and a hammer for the wrench.
Evap Canister 2.5 to 2.2
davebugs replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've always had enough parts to make them work. SOmetimes requires an additional T or a small plug to be installed in the intake about #3. If you get stuck drop me a PM. I'm debating about parting a 97/98 (I forget but it'll be written on it) 2.2 that should have all of that on it. Actually thinking of isting the heads if they are o.k. car had HG issues(traditional HG issues not Subaru specific HG issues). I also have an intake from like a 92 here all stripped down and I cpould send you a pic of those little metal lines that hug the intake. I won't be back for several hours though
Legacy release bearing?
davebugs replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never needed a slide hammer to remove a pilot bearing. Buy yea - the scothbrite pads you got are what can be used on the flywheel. ALthough I almost always have it machined myself. A spurt of warmth heading your way, cold again tonight. Froze here overnight (first real frost) and coming again tonight.
Cold lower radiator hose?
davebugs replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI won't be around for a bit but 2 things. Did you pull the lower hose to begin with - and fill through the top rad hose as the video and burping instructions here say to do? An air pocket (the EXACT reason for following burping instructions) could be causing hths. Have you run it long enough to open the thermostat (assuming that it has one and i'ts good). Have the fans kicked on?
2.5 to 2.2 swap completion update
davebugs replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have those "flex joints" in the exhaust fixed regularly at a local INDEPENDENT shop for 40.00. Don't know about the rad. AC was somewhere between laziness and not knowing that it didn't need to be undone. I've done a lot of these swaps. I'd think the HVAC thing is mechanical (as opposed to a fuse) an dunrelated. I jsut say that after pulling a lot of those to fix the HVAC bulbs. Actually usually it's minor issues with vacuum lines and valve cocver breatehr hoses usually. I've never had one with an issue really.
Should I replace the Rear Main Seal?
davebugs replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy "high tech" rear main seal installer is a PVC coupler - just like I use for crank & cam seals with a block of wood over it to help lets say - center the blows of the hammer especially when starting the install.
davebugs replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf not getting it serviced grab some sctoch brite discs to touch up the flywheel too.
Radiator, thermostat, or worse?
davebugs replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreat advice. A lot of us here have been through this many times.
davebugs replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the lower hose from either but I find disconnecting the hose from the water pump plastic piece the easiest myself. The lower rad hose at the rad the clamp is often difficult to get at.
davebugs replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNotice that you start with the coolant DRAINED! That may be the most important step.
davebugs replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea - that video is basically what I do. Often I drive the side of the rad that has the rad cap up on ONE Rhino ramp or unlevel ground. I've had trouble with those little plastic screws in the top of the rad. Usually a 2.2 swap costs about the same as a real HG job (heads checked/resurfaced, etc). It's just that a used 2.2 if probably o.k. (they are kinda bullet proff) and a used 2.5 is likely to have the same problems as the one you already have. Again search around here. You'd want a 95 2.2 Automatic (with EGR) as first choice. 2nd choice would be a 96 (you'll need the single port Y-pipe), followed ny 97 (and you'l need it's Y-pipe). Good luck. Hope for the best, but budget for a HG job/2.2 swap. ANd the more you mess with it unsuccessfully the more the 2.2 swap is recommended.
What are the odds of this happening?
davebugs replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's always as if you were seated in the car. So the drivers side is the Left side, passenger Right side.
