Mugs
Everything posted by Mugs
  1. Mugs replied to Mugs's topic in Off Road
    Hey thats a good thought. I might just have to do that. Don't want to have to yank the engine just to remove the alternator. Then it would be like a friken Fierro or porche, or, or , or, any other piece of crap like that.
  2. Trust me dude I can relate. Do you know how hard it is for me to a see a dirty and flash rusted undercarriage with all new stuff holding it up. If I could have I would have spent a month putting my lift in I would have. I would have taken one peice out, clean paint and re-install. Then I would under coat the whole thing. Which I still may end up doing any way. But I had to jump on the oportunity. I mean just look what I did with the engine. And I know you have seen my tool box I have after all I do have obessive compulsive personality, and borderline personalty. But the point remains, that when you come out of the box, you have to do out of the box things. You came out of the box when you lifted the suby, therefore don't try and put it back in the box, or make a box that will fit it. Just go with it. But if your dead set on getting that sway bar back in there, we can take a look at it.
  3. Be a MAN... Take it off and leave it off. If you want conereing then get a conering car. When it comes to cars you get one or the other, but not both. Either it cruises or it zips. This is due to the nature and physics required for the fields of play to be met.
  4. I suggest getting a hold of "The Beast I Drive" he is the brat king and master lift maker. They are military tank quality and have all the correct camber angles. But keep in mind you will have some camber with a lift that big, it is just a fact of life. Either deal with or go back to mamby pamby stock.
  5. Mugs replied to Mugs's topic in Off Road
    I don't think I am going to make it to EC in the "stomperu" but I might just show up for it. I can drive my 96 lego over there. I am not sure one way or the other.
  6. Never seen that one, but man I sure would like to have it. Maybe I will do that to mine when I get tired of it. Oh wait I never get tired of subarus.
  7. Srictly offroad. In fact you will want to have one fo the rear axles pulled out if running on the street. You will scrub tires like crazy and have all sorts of binding issues, from what I understand.
  8. Mugs replied to Mugs's topic in Off Road
    Ok well I finally got the engine clean enough to start puting it all back together. The exhaust valves and ports were uber coked up so I soaked them with acid and power hosed them as well. They're a lot better and mostly free of carbon. Plus I figure I will run a couple cans of sea foam through it on initial start up. I did the same for the intakes but they weren't as bad. First I started with the oil pan. Took it off and put it in the parts washer. Wire wheeled all the bolts and got them all ready as well. Then replaced the pick up tube o-ring and ultra-grey'ed the pan and put on the new flat o-ring that goes between the block and the pan. Next I went after the oil pump and water pump. When I pulled off the oil pump two of the screws were some what un-threaded. So took it all apart cleaned everything and checked for clearances. Everything was ok so I put it back together wire wheeled the bolts, ultra-grey'ed the sealing surface, put on the block o-ring, and installed the new crank seal. I might add that I have never seen as hard and or cracked seals (all of them) on any suby until this one. I am sure they have never been replaced and have gotten super hot in the past. After the oil pump I did the water pump, pretty much same process but used the a suby metal gasket (instead of that cheezy paper one they give you with the GMB pump) aircraft gasket sealer on the gasket and liquid pvc silicone on the bolt threads. Then came the cam seals, install the back t-cover plastic with the new rubber seals. and put on the cam gears. Next I installed the new rollers, idlers, tensioner and t-belt. Then replaced ALL the rubber seals on the rest of the t-belt covers and installed them. OK so next came putting on the brackets for the PS pump and alternator. Of course those went in the parts washer too. If it could be put in the parts washer, or solvent tank or wire wheeled, or cleaned in any way shape or form it got done (TO ANYTHING !!!!) This engine was one big grease pile when I got a hold of it and my anal/meticulous/professional mechanic nature would not allow for it to go in the car that way, even if I am going to get it all muddy, I still plan on keeping it clean as possible. And the best way to do that s start out clean. Sorry for the digression, now back to the post. OK I installed the PS pump and bracket. But I did not like the huge steal alt/ac bracket so I pulled the spare one off of my blown 96 EJ22 motor and bolted it on. It fit perfectly and is so much lighter and nicer looking. Plus I like the design better. I am not going to use the ac any way and will end up making a custom bracket for the additional alternator so I figured why not. However one of the two problems I ran into was that the back corner of the bracket hit the intake where the bolt hole for one of the throttle cable mounts go to. So I ground away enough on each piece to make it fit, once it was all bolted down. Second was the alternator. The bushing/shim on the inside was giving me clearance problems so I ground it flat. So now I could at least get it into position. But next was the tab on the tensioner side of the alternator was to big to allow for a full fulcrum swing in the mount, so I ground that off a bit as well until I had a full swing. Once I had that all worked out I took off the pump and alt so I could then proceed with the intake intstall. So the inside of the intake was all cruddy as well and there was a lot of carbon around the injector areas...out with the brake clean, rags and a blow gun I went. The vacuum lines were all hard and cracked so replaced those as well. After installing the intake I then prceeded to connect everything. All the electrical connectors got di-electric grease applied before being connected and the various hoses got lubed as well. The PCV/Separator plate tube assembly was completely cracked and ruined so I used the one off the 96 as well. It actually fits better, and the way the piping is run has a cleaner look; so that made me happy Once everything was all hooked up I took the motor off the engine stand and replaced the rear main. Then pulled off the seperator plate and cleaned it all up and re-seal/re-torqued it down. Its getting closer to having phase one done (phase one, being a driving car). Next week the flywheel goes to the machine shop. And don't worry guys the Fram filter won't be on it when I install it. A nice new suby one will be put on
  9. Mugs replied to jayare12's topic in Off Road
    Chevy, Toyota, Isuzu, and Mistubishi six lug 15x6 or 15x7 will work also, but your gonna have to do some drilling on either the rim or the hubs to get the other two lugs to fit.
  10. ...Or Yellow, something like the blue ones or maby a dark gey would be nice. But no bright colors please
  11. Get the car in the air (and supported )and wiggle the tires from side to side and top to bottom. Have some one under the car looking for any "play" in the tie rods, bushings, struts, rack, knukles, etc, or you look while they wiggle. Next take a beefy (two foot or more) pry bar and lift up on the susbension and ball joint points of the car, try prying this way and that to see if anything gives. Pry on various connected suspension and steering items. Look for shiney or worn areas on or around rubber bushings and sealed greased areas. If you still can't find or determine anything either wait till it gets worse or give it a tire rotation and see if it goes away. If it does it may have been out of balanced tires, I would then reccomened a tire balance and alignment check.
  12. Mugs replied to Mugs's topic in Off Road
    Thanks Bill. Maybe I will take you up on that offer. The tires that are on it now are 30x9.5x15 but they are el' toasty. I have some 225x75x15 that in a little better shape that I will probably run with until I can afford to get new ones before winter hits
  13. Mugs replied to Mugs's topic in Off Road
    Ok now for the rest of the post. I had to run earlier so I was not able to finish it. All of my parts came in the other day. The're all GMB or NSK along with alot of suby parts. The tensioner is suby oem as well. The crank seal I already installed when I redid the oil pump so you can't see that in the pic. I had to buy all the rubber seals for the front and rear timing covers as well beacuse they were so swollen with oil that they were just toast. I also had to replace all the plastic as well for the same reason but I had extras of that laying around. When I was at pull and save the other day getting some more parts for the project I saw these rims on a 90 Trooper and thought they would make a good set. But there was only three and so I hunted around and found the fourth in a car a few rows over. I sized it up against a wagon that was there and nocked out two of the studs and it bolted right up. I measured the offset and it was ubber close to the suby ones. So I bought them for 12 bucks a piece. Not a bad score if you ask me. When I go back to shop I will pull off the 30 x 9.5 x 15's and throw them in the parts washer and then paint them. I'm a thinkin flat black (the car will eventually wind up OD green and or camo, going for a military look ) But we will see. I had to hold them up against the car with a bungy cord so the placement may be off a little because of tire roll and lean out but you get the jist. Front rear
  14. Mugs replied to Mugs's topic in Off Road
    Yah man, I would have loved to keep everything in its stock location and keep the integrity of the interior but it just seemed like it would not work. Maybe in the future I can come up with something that will bring everything back into the cabin, but for right now I want to get the thing on the road. And I had to move forward.
  15. Your probly right, must be the muscle car in me talking. 4:11 were pretty "big" and I have read several threads about 4:11 suby diffs being installed in other suby rigs. So I guess I know where to go from here. Thanks again.
  16. Mugs replied to Mugs's topic in Off Road
    Well I got some more work done. Finally got the shifting all worked out So I will post some pics. What I started out doing was trying to extend everything. I cut the tubing in half and then tapped it out. It failed misseriably. I could not even shift it with the jam nuts locked down to max. So I scrapped that idea and started over again. This time with the suggestion of Monstaru and the advice of Baccaruda and looking at his car for a referance. I figured this time I would just brin the shifting down tot he trans and keep it all "stock" down there. I did some testing and R&D and this is what I came up with. I dropped the shift bracket 4inches and offset it a bit so that the stabilzer would reach the mount. Plus I notched the top part so it would clear the e-brake cable on the left side. Next I went after the 4x4 selector. At First I thought well if the shifter went down four inches then bring the selector up 4in. But when I did that the shifter was jammed against the bracketry in second and fourth and had no reverse. So I brough it down 2in and that seemed to be the sweet spot but it was hitting the tunnel and hitting the 4low switch. But I knew I was on the right path. So Went back to the junk yard and found a curved slector out of and 87 wagon, it was even worse. So I went back to the bannanna shifter. I cut off the switch mount (if you dont know your in 4 low you have a problem ) and will remount it else where. Then I clearance the tunnel to fit the slector bar and bolted it all back up. It worked much better and I had all gears and reverse. I need to bend up the slector just a wee bit and to the left at 90 to get it out of the way the tray. Plus I think I will straighten the shifter a bit as well. But for right now it all works well. I plan on bracing the bracketry in some way under the car as well because there is just a little bit to much flex when shifting or slecting. For clearance issues (because low and 2nd are really colse to another) I am just going to buy some narrow after market razoo shifter knobs. The E-brake cable going the clearanced corner. The 4in bracket for the shift assmebly. shift assembly with 2in 4x4 selector bracket. clearanced shift area. Installed 4low and 2nd gear more later
  17. I have a 4:11 Diff I pulled out of my 92 Lego parts car along with the driveline and 5spd tranny. How much is a reasonable asking price to sell it on CR or other. I hear that 4:11 are kind of a "hot" item. Also what could one get for the 5spd tranny I figure the driveline will just be a throw in or like 30 bucks or so out right. Thanks again
  18. Nice Find Bill. I know where to go to when it comes time to get one for my youngest kid. He wants a brat soooooooo bad and has almost enough saved up to get one. But I/we need to get my project done first.
  19. Aha I see. My mistake.
  20. Mugs replied to Mugs's topic in Off Road
    Well yah, I used High temp paint or was it water based house paint. I forget, the paint fumes were getting to me
  21. Mugs replied to Mugs's topic in Off Road
    Well, it has been a little hectic these past few days. My daughter is getting married this Sunday, so you can imagine the running around I have been doing doing last minute preperation things. But I did manage to get some work done on the suby. I got the shifting and 4x4 linkage all figured out and the custom bracketry built. Now I need to take it all out and clean it and then paint it. Then I will post some pics of that porportion. I took all the engine stuff to the shop and threw it in the parts washer for about an hour and man it came out sooo nice. The one thing that came out real well was the valve covers. Plus I wire wheeled them on the bench grinder and they "polished" very nicely. So I figured I would do a little experimenting with paint. This is what I came up with. Think I will do another set all black and then just do the "pin stripping" like thes ones and see how they look. Tommarrow the rest of all my parts come for my engine, so I will have that done next week. Plus today I scored some 15x6 - 6 lug Izuzu rims off a 1990 trooper that was next to the car I was yanking parts off of. I thought hey those would look good on the stomper. I quickly mearsered the offset and then popped two studs out of the front rotors and did some "tire clearing" with my hammer and they bolted right up....SCORE plus they had 30x9.5x15tires on them. Granite they are bald as crap but it gave an idea of whether or not they will fit. Well some more family just walked through the door so I will get some pics of the rims up later. Cheers
  22. OK some one clue in the clueless guy. I saw McBratt make the poll and he lives in Iowa so I assumed it was a name for his club. But it seems that it is for a the local Washington sector so if that is the case, then count my vote back in. Any way my vote was the first one for the NW Subaru Offroad Club
  23. Mugs replied to bigo1966's topic in Off Road
    Dude that is sweet. I have always wanted a sand rail. Now I know what to do with my "stomper" when it is so thrashed that there is nothing left to do but hack the body off. I figure the 6in lift and EJ22 will still be good so I can just tube it and go from there.
  24. Thats too cool Scott I would love to make one of those. Oh yah I am allready knee deep in a project.
  25. OOOPS sorry I thought we were voting for a new name on th NW Washington club, not North Western United states. Sorry there McBrat but you wil have to remove my vote for the NW Subaru offroad club... Cool name though
