Everything posted by EVOthis
ive actually got the gaskets your talking about on my WRX..I believe they are Hondata brand...http://cgi.ebay.ca/HONDATA-INTAKE-MANIFOLD-GASKET-SUBARU-IMPREZA-WRX-EJ20_W0QQitemZ170284548292QQcmdZViewItem ...I have no idea how much they give you in terms of HP gains but they seemed to do more good for the engine than the stock ones...
check out http://www.cars101.com that might be of some assistance in helping you make an educated decision on which subaru to buy..I will give you my opinion...Personally I like the Phase 1 EJ22 (most people do)...with the exception they are a little underpowered they are a phenominal engine in terms of life and condition not to mention very few problems when compared to the slew of different EJ25's over the years...I have over 200,000 on mine and it still runs like a top....If I were you I would find something with a Phase 1 EJ22...good engine and old enough car to be a decent price...
http://endwrench.com/images/pdfs/2.2SingleOverWin01.pdf ...this might be of some help to you... http://cgi.ebay.com/ebaymotors/1997-2001-SUBARU-LEGACY-2-2-TIMING-BELT-KIT_W0QQitemZ220393429210QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item220393429210&_trksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12|39%3A1|240%3A1318 here is one of the kits...however this doesnt come with H20 pump and such...I have seen kits that have it all cam/crank seals, H20 pump, t-belt, tensioner, idlers, and H20 pump gasket all for like $300 so do some searching youll def. find something...
Well i cant really answer to much of your questions but....where I work...to replace the shortblock (EJ25, SOHC&DOHC) it pays us around 8-11 hours...which i think is terrible...that is pulling the engine, striping it down, bolting everything on the new shortblock and dropping it back in...I do know that there is quite a bit more involved in splitting the case halves...hidden o-rings and bolts and such...If you where to get in there and end up replacing the rods and bearings I would definately go to the dealership for those parts...It would be a phenominal learning experience (ive yet to spit the case halves also) however i tend to think of the labor and parts it might just be cheaper to buy a used, known good shortblock...
Did you replace them with New Subaru OEM axles or aftermarket (NAPA etc..) axles? Did you double check everything was tight (axle nut, spring pin inserted all the way? etc...) If the shuddering wasnt there before you installed the axle and it is present now than its either something you detached or the axle itself...how exactly did you replace the axle...(unbolt the strut?, undo the castle nut on the ball joint/sway bar link bolt? undo the LCA mounts?)
there really not that bad to replace...im guessing the reason they quoted you 2.5-3 hrs. labor is because that is book time...im sure they can get it done in under 3 hrs....If you do decide to tackle the job yourself be careful because alot of things rust under there especially for being 13+ years old and hoses get brittle...
wow...an outback with an EJ22...good find....How many miles are on the car?...Personally I would check for things like torque bind (yes this does happen to the manual trans too)(do a search here youll find tons), recent maintaince, and pretty much do an inspection of the car...lights,boots,brakes,tires,suspension,exhaust etc.. im sure others will chime in....good luck
There are conditioners in the ATF...It doesn't really matter....Subaru's PS racks are compatible with either fluid ( I know Subaru recommends ATF though)....or at least all the ones ive ever seen....I believe the system takes about .75 qt...so 1 quart should be enough to properly bleed the system and top her off....
