Everything posted by mountaingoatgruff
progress with the hatch
mountaingoatgruff replied to mountaingoatgruff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i tried that last weekend. i finally pulled it all apart again and found the pilot bearing is crooked. i'll have to reinstall it tomorrow. i noticed while they were close, the crossmember's engine mount surfaces and the bottoms of the the mounts seem to be at different angles. anyone else noticed this before? does it make bolting them difficult? -
i'm trying to mate the ej to the 5 speed right now but i've never had this much trouble. they'll come all but the last 1/2". input shaft has engaged clutch disc splines, seems its the tip of the input shaft hanging up on the pilot bearing. taking a break before i get pissed... this flywheel and EA82 clutch set was installed on this trans with another ej and different adapter plate before so there should be no reason it wouldn't fit. i'm using an sjr adapter now because the old one was a joke. any ideas? -
Do-It-Yourself Bedliner...
mountaingoatgruff replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have a couple friends that did their tacomas at the same time. one did his bed in line-x, the other used a diy (i can't remember which but he sandblasted then primed it so i know his prep was legit). the line-x truck is still beautifull almost 2 years later. the diy job was coming off in chunks after a year and has been line-x'ed since then. they had their line-x done in manteca, was a real good price and worth the drive from merced. -
yeah, i talked to one of my mopar buddies and he strongly suggested using the p-valve. he says it may be unsafe at high speeds without the "proper" distribution of force to front/rear wheels. apples and oranges to his experience, but i think the principle carries over. i'll put a second 3-way block in there to delete the hill holder then i'm thinking i'll add the p-valve mounted to the frame rail under the booster, right before the lines separate. i'd have to cut the metal lines to add it in that way. i can grab some of those brake line nuts, but is there a way to make the ends look like they do at the other fittings after cutting them? would that be a tube flaring tool? -
i've heard folks say both ways about the need for the pro valve. i haven't actually heard of anyone who's had problems without it. guess i just need a second 3-way block then. -
i'd like to see subaru engines in an older vw transporters. ideally, an EA81 in a 78 bus. i have a buddy that was just given a 78 bus and he's getting ready to go through it to see what it needs. body's straight, interior's okay, underside looks good, engine's tired. so i'm trying to get him to stuff my SPFI EA81 in there and i need visual reference. any pics of any sube engines in transporters of that body style would be appreciated!
well, i'm taking the hill holder out and i just thought it'd be nice to fit the proportioning valve in there where the hh was. gettin it bolted in is no prob...i just need to figure out the routing of the lines to do that. -
i powder coat whenever i have time. i can get it done for the cost of powder so the time it takes is my limiting factor. i hope to do some more before i'm done. this car is gonna be my daily driver. i long-term plan is an RX full-time 3.70 setup. the brat's gonna be the wheeler. -
and here's how i'm hoping to get around the temp gauge incompatability...it's an EA81 temp sensor in a bung mounted on the coolant crossover: -
its not a crate engine, its from my wife's wrecked old legacy wagon. this whole thing hasn't cost me much at all - i already had the paint, my dad did the powdercoating (both crossmembers, control arms, radius rods and clutch fork), and i've been slowly buying suspension parts for months. i have spent lots of time cleaning crap...probably too much.... i'm trying to decide how i should install the proportioning valve for my rear discs. i'm deleteing the hill-holder and i kinda think i should bolt it in there. any ideas/pics? -
i finally got some time to work on it. i should have the motor in tonight then it'll sit for the weeks to come before i get another bit of time. i put disc's on the rear, rebuilt the suspension with new control arm and sway bushings, d/r 5 speed is in place and here's the engine:
i pulled the dash on my 97 legacy rather than hack it, start cutting with any speed and you're risking setting yourself up for a nightmare down the road. i wanted the entire vehicle harness from the doors forward without cutting any wires so i stripped everything. dash and all came out fine, pita was rushing through the evaporator and heater core without accidentally popping a/c lines.
i won't touch the "better plugs" arguement, but i'll suggest a wire-style gapping tool. the tapered gauge type can damage your plugs, especially if you have little experience and/or insist on wasting money on exotic electrodes... and NEVER twist or wedge the gapping tool in the gap to open it, use the slot provided on wire-style gappers.
i can't speak for my hatch in it's carb'ed days - i only had it a week before injecting it. it's carb was shot and missing parts from an earlier "rebuild." my average mileage with about 40% city & 60% highway driving and the d/r 4speed was up to 34mpg per tank (i did the math for every tank and it depended entirely on my driving style - i got as low as 22mpg once). it had plenty of pep and ran like a champ. only problem i ever had with it was with the egr solenoid. if you go injected, use newer nippon denso solenoids - the hitachi ones are poo. you can get the nd ones from newer subes. some folks remove those solenoids but i'm in cali and violating smog laws is not cool.
BRAT is down, Fixed it.......
mountaingoatgruff replied to TomRhere's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sorry for your luck, man. is this the brat that's gonna get injected? if so, maybe you could keep an ea82 rad in there so its easier to get upper rad hoses that fit (i don't know if that's true, just a suggestion). -
Yet another Sea Foam thread...
mountaingoatgruff replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the reason i say that i'll only use mmo in my crankcases now is that it works so much better for me. i had a 95 EJ22 sitting in my garage for months after sitting in another board member's garage for literally years. last weekend i put it in my new-to-me 97 OBS (had bad hg's). the thing ticked so loud you could hear it in the house! i put fresh oil in there during install, drained a bit and added seafom after hearing it but it had no affect. changed oil and used a qt of mmo, had it quiet 30 seconds after startup. running fresh 10-30 with no additives and its still quiet. i also used mmo in a 93 honda accord 2.2? on tuesday (stubborn, lingering tap - tried seafom before with no affect). its quiet now, too - i doubt he's changed the oil/mmo blend yet though. -
Fuel pump for 91 Loyale NA. Alternatives?
mountaingoatgruff replied to foxgap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
did you have a carb'ed model? i was planning on feeding the ej with the spfi pump i already retrofitted into my hatch and i've been wondering if it'll work well. -
i used to use seafoam in crankcases til i tried marvel mystery oil, its all i'll add to oil now. i still use seafoam as an upper cylinder cleaner though.
