bobaru
Everything posted by bobaru
Still need help with wheel noise
bobaru replied to buzzcon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
buzz if you need the big socket to get the 36mm nut off I got one Im right off the jordon rd 3or4 miles from subway -
you will be happy Bill does good work
Oh no It's contagious it got it from Blooser remedy give her 2 aspirin, wash and wax (buff if needed) and vacuum, park in garage and most of all don't let here play with blooser
WHAT I READ IS it over heated and blew a head gasket when the heater hose blew no flushing or burping is going to help
in order to get your power brakes you can use a 12 volt vacuum pump like these http://biodiesel.infopop.cc/eve/forums/a/tpc/f/919605551/m/7331015712 http://www.instructables.com/id/convert-a-tire-inflator-type-air-compressor-into-a/ http://motors.shop.ebay.com/items/?_nkw=12+volt+vacuum+pump&_armrs=1&_from=&_ipg=&_newu=1&_sop=1 http://www.autoanything.com/brakes/69A3151A0A0.aspx Ive seen the fourth one or like used on heavyly camed motors with little to no vacuum
Attn Bobaru: The blue car lives on!!!
bobaru replied to one eye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dont forget it has TOD that noise will drive you to drinkin P.S. since i got the 83 EA-81 my beer money has been piling up so I can buy the best of the single grains:grin: -
ALRIGHT glad it worked out for you. those tires must have been a PITA in this heat and all your flying friends (mosquitos) -
Hi neighor from what I understand is the 88 front seat is 2 inches wider that the 84 and the rear will not fit
I like it, two motors cool, IRS if its a 69 or newer, lots more head room than my 83 GL thats real nice, a heater that works warm. only thing I see wrong is where do you store the spare tire for the VW. they are stored under the front deck lid. Like a suby
I was at a P.A.P today there was 83 or 84 GL wagon there. It had a C.C knob on the right side of steering wheel in that blank spot on yours below the wiper control. It could be the wrong knob for that control. I trust GD more than a car in the PAP
Removing Upholstery foam/glue
bobaru replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like a sand paper job--------- 36 grit its just glue, youre going to coat it later -
87 gl wagon carburated. how do i get more power?
bobaru replied to przao1157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check your carb cable it could be stretched -
my neighbor has a 87 Brat the fuel sending unit is shot (gas tank part) local sube dealer no help does it interchange with any other suby or any body got a idea where to get one thank you
can i swap in front drive axles ?
^^^ I 2nd that ^^^^ and 3rd that -
alright on the brakes seats oh well F.I. = fuel injection:confused: there both carb cars weber on the G.2 stock on the G.1
sweet ride
I got a 87 ea-82 4x4 wagon bad timing belts, wiring shot, TOD so loud it hurts my ears. So now is a parts car. picked up a 84 ea-81 4x4 wagon run great not a parts car will be daily driver what parts interchange I'll ask one part at a time. rear brakes y or n front & rear seats others to come
Bill that looks good:clap::clap::clap::clap:
Sucker King & Will thank you very much Ill be swaping parts from 3rd to 2nd gens and its easyer typin gens than all that other info
wow glade I asked I thought my 82 hatch & 83 wagon were 2nd Gs my 87 wag 3rd G
Cool and Ouch
thank you McBrat I knew a little bit about the rear. now I guess ill check out the fronts again thank you
what does this mean? bottom of page in the mechanical section http://www.indysworld.com/80s/general/literature/brochures/1983-l.jpg
