				Posts5926
				Days Won5
Everything posted by Caboobaroo
	OK I get it now Shawn but why not to the Retrofit forum? It clearly states in the description of the "Transplant" forum that its a Subaru drivetrain into something thats not a Subaru body or frame of some sort....
	  A Hack on the old front grillCaboobaroo replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales... If you want a 3-door grille, since all RX coupes had the same grille as a 3-door, you're going to need to do a bit of other work to the front of the car in order to get it to fit. What I mean is the wagon/sedan have different headlight buckets and mounts then the 3-doors. So in order for a 3-door grille to be a direct bolt in, you're also going to need to find a set of headlight buckets and mounts for a 3-door as well. Headlight glass is all the same, just the parts I mentioned. Don't ask me why Subaru decided to do it this way, but I found out the hard way and had to spend an extra couple hours swapping hardware after I had installed my "new" headlights...
	  Denver: Friday Pull n Save ScoutingCaboobaroo replied to patkennedy78's topic in Old Gen.: 80's GL/DL/XT/Loyales... Any 3-door EA82 coupes. I need in the tanish/grey RX interior color, the piece that goes over the driver side rear wheel well which also has a grating for the speaker which sits under it. Also, a passenger side rear quarter glass for the same car, and a driver side tail light. Oh and a slim EA81 AC fan....
	As for the bolt difference on the control arm, Calebz is right. All the 5-lug conversions I've done, I've had to drill out the hole with a 1/2" drillbit, then mount the control arm in there using the original bolt for the EA82 control arm but with washers on either side on the outside of the control arm, then welding them in place at the bottom of the hole. Works great and the wagon I've done it on prior to my RX, has taken a few trips from Wyoming to Oregon, a couple rallycrosses, and has been done for about 2 1/2 years now.
	  De-powerizing the steering?Caboobaroo replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales... any EA82 I believe....
	  EA81T PowerSteering PulleyCaboobaroo replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales... I got one from an EA82 turbosedan.....
	there's a few things that could eat up one side. Check for tightness of engine/tranny mounts, check for deteriorated mounts, and check for play in the tranny as far as side to side movement at the tailshaft
	  Brake Bleeder Kit (pneumatic)Caboobaroo replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales... it should go about 1/4 to 1/2 down without the car running and will be very stiff. If it goes to the floor, that means you have air/water in the lines and they need to be bled. Another thing a lot of auto owners don't know is that the brake fluid should be changed every other year to keep the yellowish clear look to it. If not, it'll get water in the system, make the brakes spongy, and will turn the brake fluid more brown. It will also deteriorate the metal brake lines and wheel cylinder/calipers if not replaced with new fluid. Cheaper to do it once every couple years then have to go through and replace rusted brake lines, frozen calipers and wheel cylinders.
	pics would help dearly my friend. I have like, a million intakes from NA MPFIs and turbo MPFIs so I can help ID something if need be, without you pulling it all apart on your car.
	Who moved this to the "transplant" forum? He's taking an engine from one Subaru and putting it into another. the Historic forum is the perfect place for this.....
	  New Toy... (56k < ej20)Caboobaroo replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales... <-- is freaking out OMG dude!!! I've loved thatc ar since I first saw pics of it when Corky owned it. Glad to see it finally running and driving. Also glad to see that the new owner is going to be keeping this car no matter what (I hope). Its soooo hawt!
	  5lug swap done.. legacy spring thoughts *pics* 56k bewareCaboobaroo replied to rllywgn's topic in Subaru Retrofitting Lookin hawt my friend! Welcome to the 5-lug group. I myself have also gone basically the same route as you did but my front end stuff was off of a '95 Imp wagon. Did you change out the tophats for the stock EA82 tophats? Now you can go ahead and do major upgrades to the brakes as far as aftermarket parts. Enjoy the various wheel combos you can use now!
	  Finally Finished with my lift! **With Wheels!!!**Caboobaroo replied to TheSubaruJunkie's topic in Off Road awww how cute! Still smaller then my Bronco:grin: But you get waaaaay better gas mileage then my 351M:rolleyes: Looks good buddy, keep up the good work! It'll be worth losing 15 pounds of water weight eventually. Or you'll just die of dehydration...
	  Have fuel injector questions, AGAIN!!!Caboobaroo replied to 4WDFrenzy's topic in Old Gen.: 80's GL/DL/XT/Loyales... Patrick my friend, I have just the thing for you. On ebay, if you search for "Nissan 280ZX turbo injector" usually, you'll come up with a couple finds. ONe of them however, sells brand new, set of 6 injectors. A couple months ago, I sent him a message asking him if he would be willing to do sets of 4 since they are a direct swap in for our Subarus. He said he could! Including shipping, I believe they came out to roughly $140 clams for 4 injectors. His ebay name is Dr. Injector. Here's the thread I made when I found them... http://www.ultimatesubaru.org/forum/showthread.php?t=58559&highlight=Nissan+280ZX+turbo+injectors Good luck my friend!
	is it still in the car? You might want to get a flush kit which would allow you to run the car and then flush the coolant system through one of the heater hoses. If its not in the car, your best bet might be a radiator shop.
	  GAS TANK/difference between FI/carbCaboobaroo replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales... There is no difference in the tanks for any EA82 wagon/sedan/coupe. I had to replace the gastank in my RX since the junkyard had punched a hole in it, and I used one from a carb'd wagon. Had no issues.
	  Engine reseal or replace?Caboobaroo replied to Alex GL-10's topic in Old Gen.: 80's GL/DL/XT/Loyales... ok for cost wise, you're looking at about 200 bucks for everything, maybe less. Go to Schucks/Checker/Kragens cause they should have the Fel-Pro gaskets, at least my Checker in Laramie did. 80k miles eh? Reseal it since thats pretty low mileage for that engine and probably doesn't have too many things worn out on it. I agree with GD on the timing belt covers, PITA. I run the backs to help deflect any debris but the fornts I leave off usually but I do like to put them on when I go to shows, which will be in like 10 years when my RX is done:rolleyes:
	ouch man. Get it fixed by the Redrocks meet on the 13th or else you will die! Hopefully nothing like that happens to my RX on the way down there. That would sux0r!
	  Engine Installaton q'sCaboobaroo replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales... too bad you're not closer to me. I just did a couple EA81s recently and one was a feedback carb. Did you swap intakes from the old engine to the new one? If not, you're in a world of hurt cause the computer for the feedback carb is going to go nuts and it won't run right. I swapped intakes from the old engine (bad rod bearing) to a 83k EA81 which had a regular Hitachi on it. Runs like a champ! Let me know if you need pics and "Where does this &^%$&^^%&^ go???" answered and I'll be all ears;)
	  Fuel savings with 4WD fuse removed??Caboobaroo replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales... +1 There is a fuse located on the firewall, can't remember which side, but I do believe it doesn't have anything to do with the tranny......
	Depths is right!
	There's another fellow here on the USMB with an EJ22'd bug. Its only rwd too but he says it plain moves. I believe his board name is "Nug"
	Yes they are! In a week I'll be doing them again with more compression:banana:
