Everything posted by rweddy
The studs out are not and issue, the same as if you lost them by driving. These are the tires I have set on my wife’s Honda. Great tires, a little bit loud but great in the snow,ice,etc. Before we could not get the Honda up the driveway unless I was to completely shovel it, now no problem. These tires are also great on the road and have helped handling and braking also.
Here is the link to the Subaru Site 5 spd = Continuous Auto = Active http://www.subaru.com/allwheeldrive/ver2005/index.jsp I would not say it is a problem with the automatic, just the awd system on the 5 spd is Viscous-Coupling which is superior to the set up used in the Auto. The Auto system still works very well. http://auto.howstuffworks.com/differential9.htm IMO a turbo auto is ok but a manual would be my choice!!
Hate to burst your bubble but the AWD system is different between Manual and Auto. Automatic-equipped Subarus use a computer-controlled hydraulic clutch pack, similar to those found in an automatic transmission, to transfer torque to the rear axle when the sensors detect a 20% difference in axle rotation speeds between the front and rear axles. Normally torque is split 90 front/10 rear. Not really all that different from most of the other AWD systems. Manual-equipped Subarus use a viscous coupling, similar to a limited slip differential (and certain full-time 4WD transfer cases) where under normal, dry circumstances the torque is split 50/50 until the physical difference of the rotational speeds of the axles causes the hydraulic fluid in the coupling to heat up to the point where it acts as a clutch, forcing the two axles to turn at the same speed. It's basically the sameas full-time 4WD without the extra low gear. It can transfer torque front and back almost 100/0 or 0/100 if necessary.
Nothing leaks like an ea82! You can see from my signature how many I have owned so I know first hand how much leaking a ea82 does. The ej22 is imo the 2nd best engine subaru has ever made. (ej22t best) The only issues the ej22 usually have is cam seals and occasionally oil pumps, but unlike the ea82 pump, the ej22 has a simple o-ring that can be replaced and it will go for a long time. I like the 5spd better but the autos are fine.
