Everything posted by AWD TURBO!
good pics
3rd Timing Belt in 10,000 miles
AWD TURBO! replied to kayakertom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
do as Markus56 posted and take your covers off it looks good with out them & a new belt will be installed in about 15 min -
i know but it was fun i plan on doing a ej22 for my Rx but yes Broken ring lands i wish i could get good photo's and i will be running 7psi in the new one
found my blow by problem the piston is bad so I'm going to use the na pistons & see how long this will last
well i was running 15 psi with out hitting fuel cut but i was using hi octane gas with no intercooler but yes from the psi side of turbo to wastegate [ATTACH]7420[/ATTACH]
well 10 psi is ok but the wastegate line only needs to go from the turbo to the wastegate with out using the solenoid or the wastegate control thingy...
Ea82 Turbo Disty questions
AWD TURBO! replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
why? -
i like the look of this one but i have a 2 door that i plan on lifting [ATTACH]7419[/ATTACH]
what do you have for exhaust?
I'm happy its working for you enjoy your trip i do have a intercooler that is a bolt in subaru top mount with the iac line on the boost tube with a bov ill get pictures [ATTACH]7421[/ATTACH]
all right i need to find a good ea82 block really cheep or just use one out of the pile in my yard. while looking on e bay i found this one but its not worth it not even shipping it but worth looking at it http://cgi.ebay.com/ebaymotors/SUBARU-EA-82-EA82-ENGINE-MOTOR-SHORT-BLOCK-BRAT-BRUMBY_W0QQcmdZViewItemQQhashZitem3efd3e96acQQitemZ270536709804QQptZMotorcyclesQ5fPartsQ5fAccessories
air down or have your foot into it all the time love the pictures!
was it wet? i wish i could have gone
kool so i had oil psi the block just gave it up :-\ it ran good for the day on cheep oil that i will never use again have all ways ran Castrol GTX but not this time...
cookie in the field so i am happy it did it now but all so would have Ben fun to do it in the sand... & dont get to work on it tell i get the auto trans out of my sisters mx6 doing a 5 speed swap:confused:
well it does 5 psi wow i gees its a subaru but i don't think its an oil psi loss it sounds like a rod just stuck together to go play at sand lake looking in to an EJ swap but don't have the $ to do it
OK well got my rx going 2nd Jen heads with a block that did have under 50k on it but the question is why does the oil psi gage say 75 80 win i start it then falls on its face to 0 at all times? does this sound like a rod?
pop cans are not going to help :-\ cant go bad rod :banghead::banghead::banghead::banghead::banghead::banghead::banghead:
well the rx is on the road still needs work but trying to find gas money:-\
Need more power at same boost
AWD TURBO! replied to vagen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
:-\ a welder TD04 flange a drill with something to cut with then its a bolt in. i do have a few good turbo's left i don't need any more
