Everything posted by AWD TURBO!
87.5 ea82t (ecu controlled wastegate actator) and manual boost controllers?
well the home made boost controller is junk :-\ but does work
td04 on a ea82t
i have less then 2500 over the last 3 years 2 wagons 4 moters 1 transmission & lots of 13 inch tyres. I think I'm doing OK because i can afford 3 to 400 every three to four mounts & have fun but i would love to do a EJ20 turbo engine swap
td04 on a ea82t
not well sorry
does a 2002 wrx have a oem egt?
td04 on a ea82t
Hello, does anyone have pictures of a TD04 turbo on their EA82? I just got a new turbo because the old one was bad.
copper head-gaskets i n a ea82t
got to work on the Subaru the turbo is bad it is putting water in the oil didn’t get much but it’s on the oil fill cap so time 4 a new turbo & a flush:-\ gd thank you I have a few ea82t sitting on the floor in my shop one with bad block.. think i will talk to my ex gf's dad if the block will fit on the bridge port do all of the ea82t have a Closed deck block? but i think after i get a new turbo a megga squrt and Datsun Z 300cc fuel injectors from http://osidetiger.com/reconditionedinjectors.aspx with fel-pro hg ill be dun with the ea and do a ej 20t
i know thats why i'm asking so much about them very odd size studs $600 sumthing if i rember right how do i O-ring the block?
so has aney one used the copper head gaskets?
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think i an going to get the copper head gaskets and bild me a moter use the fel-pro on the moter that is in it now i do have a temp gun now:rolleyes:
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was using the Permatex but now i will get the Loctite! But yes the ea82 has problems with the heads being too hot & cracking Do you think it will make a difference in the temp of the head in a water cooled engine?
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall right so its going to be the fel-pro
so has aney one used the copper head gaskets? I'm going to use them in my ea82t knowing that thay r used in the ej's trying to find sombutty to tell me the + & - of using the copper head gaskets i know it's like but its still fun
if your doing the heads just pull the moter:-\
ok so has aney one used the copper head gaskets? going to get the copper head gaskets 4 the same price of the Fel-Pro. good advice! (Done right the engine will only be limited by you, your maintenance and care of the engine. Don't let it overheat, over boost, monitor EGT's, etc.)
ok but i have benn told that oem hg are beter then Fel-Pro & yes all ways use the copper spray
ok so i am going to put the copper head-gaskets in soon mine just went out going to use the 3rd jen heads with a Closed deck block o ring how do you know if it needs one or not? yes i know ej it.... dont want to head studs! I want them but is it worth it? & ware do i find them:-\
wipres quit
was in the mud trying to wash the the mud off going to run power to th moter & see if it works... I'm thinking its the switch we will find out
wipres quit
need help the Winchell wipers stoped working looked at the fuse box no bad fusees washer stop working at the same time this would be on a 8 gl10 turbo relay? switch? wiper moter? hmm going to look in to it in the morning any help in the mean time would be grate
So I Got the Old Axle Out And.........
well i used to get real jdm ( Subaru Loyal Fort wheel BEARING kit ) off ebay for 13.00 bucks 2 barning 2 seals but cant find it
well we like the turbo it gets its s**t wound up & goes like a rocket but the 92 is like 2.99 southing round here & i don't mind paying 4 it. I don't look I give them 35 bucks go on my marry way 4 the next 200 miles then its hi ho 76 premium gasoline
gl 10 turbo
[ATTACH]7125[/ATTACH] [ATTACH]7126[/ATTACH] so i was in need of new rubber didn't want to put 13' on & i had the 6 lug ready to go in so all i neead to do was lift it
the one on the bottom? but yes it looks that way
1983 GL wagon key box
whats the car look like?
exhaust parts for older Subarus
well i got a hand full them i would be from 98684 & 15 4 the up pipe
look at this
http://www.vidoemo.com/yvideo.php?i=YzJucVBBcWuRpU3hXZWs&build-a-monster-truck-in-4-hours
ware do i find copper head-gaskets 4 a ea82t?
ware do i find copper head-gaskets 4 a ea82t do you know??
