Everything posted by AWD TURBO!
no boost at all
well 10 psi is ok but the wastegate line only needs to go from the turbo to the wastegate with out using the solenoid or the wastegate control thingy...
Ea82 Turbo Disty questions
why?
1987 rx 4x4
i like the look of this one but i have a 2 door that i plan on lifting [ATTACH]7419[/ATTACH]
no boost at all
what do you have for exhaust?
no boost at all
I'm happy its working for you enjoy your trip i do have a intercooler that is a bolt in subaru top mount with the iac line on the boost tube with a bov ill get pictures [ATTACH]7421[/ATTACH]
Short block brat brumby
all right i need to find a good ea82 block really cheep or just use one out of the pile in my yard. while looking on e bay i found this one but its not worth it not even shipping it but worth looking at it http://cgi.ebay.com/ebaymotors/SUBARU-EA-82-EA82-ENGINE-MOTOR-SHORT-BLOCK-BRAT-BRUMBY_W0QQcmdZViewItemQQhashZitem3efd3e96acQQitemZ270536709804QQptZMotorcyclesQ5fPartsQ5fAccessories
Sandlake trip photos & video
air down or have your foot into it all the time love the pictures!
Sand Lake run in february?
was it wet? i wish i could have gone
oil psi?
kool so i had oil psi the block just gave it up :-\ it ran good for the day on cheep oil that i will never use again have all ways ran Castrol GTX but not this time...
cookie in the field so i am happy it did it now but all so would have Ben fun to do it in the sand... & dont get to work on it tell i get the auto trans out of my sisters mx6 doing a 5 speed swap:confused:
ea-82, head/Cam-tower o-ring part number, ANSWERED
OK but witch part number it the reinforced o-rings?
oil psi?
well it does 5 psi wow i gees its a subaru but i don't think its an oil psi loss it sounds like a rod just stuck together to go play at sand lake looking in to an EJ swap but don't have the $ to do it
well if you want to keep oil in the cams & no lifter problems call subaru! subaru only the o-rings are cheep if you cant get them for under 13 dollars ill get them for you
oil psi?
OK well got my rx going 2nd Jen heads with a block that did have under 50k on it but the question is why does the oil psi gage say 75 80 win i start it then falls on its face to 0 at all times? does this sound like a rod?
pop cans are not going to help :-\ cant go bad rod :banghead::banghead::banghead::banghead::banghead::banghead::banghead:
well the rx is on the road still needs work but trying to find gas money:-\
Need more power at same boost
- no boost at all
:-\ a welder TD04 flange a drill with something to cut with then its a bolt in. i do have a few good turbo's left i don't need any more- no boost at all
try to get a TD04 with an intercooler for best use- White RX w/ 5-lug conversion in Kirkland, WA
like this one? [ATTACH]7375[/ATTACH]- witch is best ea81T or ea82T
seen this & was thinking of finding an older car [ATTACH]7371[/ATTACH]- Seven year storage GL10 turbo ideas
yep something you should do :-\- WJM - RX Turbo
[ATTACH]7370[/ATTACH] no not this one but i did get this one http://boise.craigslist.org/cto/1581642229.html don't know why its still up but it is one of his old Rx's- WJM - RX Turbo
i have the black one from the private seller was a piece of s**t so lots of work to be Finished- Sand Lake run in february?
map quest the meet point so every one that wants to convoy knows ware to go & what time - no boost at all
