AWD TURBO!
Everything posted by AWD TURBO!
  1. did you lube the cable? i had the same problem with my new cable lubed it works good now
  2. well i made it to Lowes but forgot my wallet so i missed out
  3. well I have A high-comp EA82T in my rx with other moods & i love it :burnout: :burnout:
  4. well i'm not lifted but i'll be there in my rx Home Depot in Delta Park@ 5:30. sounds good but whats the Admission cost?
  5. yep leave the timing belt covers off stuff will not hurt them i weel mine & never had a problem
  6. or you can drill a hole on the turbo to fit the ea & for the down pipe you'll need to use a 5 bolt flange
  7. really bad shifter bushing but is good now so no hitting 3rd instead of 5th :-\
  8. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350221020892&viewitem=&sspagename=STRK%3AMEWAX%3AIT i got mine from here
  9. i had a bad rod Bering in my ea82 i have a new moter in now but the turbo is bad i had rod Bering flakes go threw it but gd i would go bigger but i have no need I'm only at 5 psi now & i have had lots of the oem turbo's go bad :-\
  10. tdo4 is done now im looking at rebuilding or buying a new one.. can i get some input on this im told by some ppl "that its a waste of time it will just go out again" and im also told i will need to balance it. but if i just replace the bushings why would i need to re-balance it? can some one clear this up for me be greatly appreciated thanks!
  11. i put my RX on the road i hope to have a year out of the ea82t i have na pistions with TD04 off a 2002 wrx at 5 psi 2 1\2 mandrel exhaust 3rd jen heads with new barrings road's & man's
  12. do as Markus56 posted and take your covers off it looks good with out them & a new belt will be installed in about 15 min
  13. this is my Speed Hole but thats some good looking s 10 parts
  14. i know but it was fun i plan on doing a ej22 for my Rx but yes Broken ring lands i wish i could get good photo's and i will be running 7psi in the new one
  15. found my blow by problem the piston is bad so I'm going to use the na pistons & see how long this will last
  16. well i was running 15 psi with out hitting fuel cut but i was using hi octane gas with no intercooler but yes from the psi side of turbo to wastegate [ATTACH]7420[/ATTACH]
