Everything posted by AWD TURBO!
na block with turbo heads
got the car like this but thank you MilesFox. can i use the na pistons in the turbo block?
well i have a 87 rx turbo with an n\a block with turbo heads it has a bad hg win i got the heads off i found a crack in the ridge of the cinder[ATTACH]7363[/ATTACH] i don't know if this is going to be a problem or not
Sand Lake run in february?
well gl has a bad hg. going to take the rx so building the 18t dont know if i will use the na block with turbo heads or fix the one in the gl put in the rx go have hg's just need to do it convoy sounds good
Hill Holder Removal? '87 Brat
i have one from a 88 gl if that works
Driving with drive shaft removed
no i did in my gl10 with the diff lock on
Transmission is on its way \ going to get an 87 Rx :banana:
EA82T Rear main seal install problem
use lock tite and a subaru Rear main seal ...
87 EA82T Ignition Troubles
mine did the same thing pop the disty apart & replace the cam pick up unit it was bad while your in there make shore that your baring is good
I made my first roof rack!!!
just if he had a tent as well
Propane Brat Conversion
good job enjoy the clean burn
some time in Feb sounds good i think i have 3 others going as well 2 gl10 turbo's & just may be a wrx if he does not mess it up.
EA82T head issues
OK do it! I want to see it I'm now interested
my yellow top went dead again think i need 100A gm power
Saftey Wire
- Saftey Wire
- Let's see your LIFTED Soob off roader 2010 edition.
[ATTACH]7294[/ATTACH] it old its rusty but its my subaru- Sand Lake trip?
as soon as i get 350 but yes i did- Sand Lake trip?
yes- EA82T head issues
[attach]7281[/attach] this help:)- how do I ?
35" what is the biggest lift that has Ben dun?- how do I ?
- Overheating and no heat issues... please help!
.... http://www.ultimatesubaru.org/forum/showthread.php?t=66707- fuel problems!
you still got my jump box- Overheating and no heat issues... please help!
you would think so but he does not think its the leaking radiator lol- Overheating and no heat issues... please help!
did you try? yes the actual bleeder is the cap you start your car & run it with out the cap on add coolant don't put the cap on tell you stick your finger in the coolant & it is HOT & looks like it is flowing... - Saftey Wire
