AWD TURBO!
Everything posted by AWD TURBO!
  1. fuel pressure regulator is the return line
  2. good point but that was with the motor i pulled out of the gl that threw a rod while i was playing in the mud that same day i'm not drifting the rx unless off road i got 14k on this motor the bad fuel pump only burnt the valves
  3. a tuned EA82T drifting awd is more fun then rwd
  4. well fuel pump went out motor went with it going to be fixed & in tonight
  5. hahaha i like the the way you mounted it looks good
  6. the z injectors are the same as ea Subaru's
  7. well i'm going to use some turbo 280z injectors that i found at pick & pull wasn't looking a z but i found one still plan on new injectors but this was really cheep Steve W. what where you running your boost at? did you do anything with the pistons na or turbo? and is it still on the road? going to an EJ requires money but i love the car http://wordpress.suberdave.com/wp-content/gallery/the-build/88gl1.jpg what do you think just so you guys know i'm only at 10psi boost nothing more
  8. for the + and the 4 ground's go to the ecu i think now i want to know
  9. hey don't get me wrong Presslab if you can explain what your trying to tell me it would help knowledge is power and i don't know every thing but what i do know is with a fpr and 180 cc injectors there still too small
  10. welder time mandrel bent pipe and more time but here are some pix of the build
  11. btw my car is modded hi compression pistons 03 TD04 big intercooler ported heads cams msd Street Fire Ignition Blaster 2 Coil and so on
  12. dude the question was what is the OEM injector cc's.... so i can add 25% + cc's for the e85 and a walbro 255 & an fpr is going to be added at the same time
  13. ok so there 180-185 cc kool i plan on running an e85 + pump 92 to keep from Detonation and Pre-Ignition and the 330 cc Datsun Performance Fuel Injectors from http://osidetiger.com/Datsun1.aspx i think he wanted 120 for a set of 4
  14. what cc injectors does the stock 87 rx turbo have?
  15. I'm paying too much to keep this thing really good i thinking about doing 92 octane from 76 and part mix E85 and bigger injectors
  16. how did you do your timing (with the cam timing marks!!) and is it TDC with the rotor pointing to #1?
  17. well this is my jack stands [attach]8087[/attach]
  18. why do you say that? but you can do as you want i just post this from experience of the problems i've had with new thermostats that just did not work right
  19. ware did you get your thermostat? i get mine from the dealer for a good reason others don't work right they over heat your car!
  20. can you use the TD04 turbo? because the stock turbo's are junk & it will not work well with the FMIC. stand alone and water inj will help lots ive found a link for a How to MegaSquirt your Subaru RX Turbo http://www.diyautotune.com/tech_articles/how_to_megasquirt_your_subaru_rx_turbo.htm and new injectors from http://osidetiger.com/Datsun1.aspx for a 280 datsun but only ordering 4 should bring that thing to life
  21. he is stuck with the Ea82T unless he moves to a modified class:Flame:
