Everything posted by AWD TURBO!
parked next to my buddies ford with 33 with my 27" on my Subaru and i got more ground clearance [ATTACH]7269[/ATTACH]
effing alternators
do you have pictures of your GM 100a alternator in your ea82 Subaru?
EA82 head porting?
well i know ware not to grind now good picks
Overheating and no heat issues... please help!
OK so its in the teens do you have something in front of the rater to keep the car worm so the thrums stat stays open at temp? if its too cold out the water in the radiator is getting too cold making the stat closed! moter is hot! water is ice cold make since?
Ea71 mod advice... HELP!!!
[ATTACH]7264[/ATTACH] this looks cool
It finally goes
really like your hi\lo lever think I'm going to do the same.
why is so hard to find a dual range full tine 4wd
i was looking but in e bay / cl listing
:banana::banana:thank you
iam looking can you help?
so i am trying to find a transmission but don't know ware to look all the jy Ive Benn to does not have them
Sand Lake run January 17th or 24th???
I'm out 2 gear went out unless i can find a full time 4wd hi lo with the diff lock in time
TDO4 or TDO5 on my EA 82 T ?
TDO4 just fished mine & love it
td04 on a ea82t
with me having the boost gauge connected I'm doing 14 psi max & 12 on the dot no fluctuating. going to put it back on the intake i will have vac
td04 on a ea82t
yes its the boost gauge i just wanted to know what psi was off the turbo was
EA82 TURBO DIE's FROM AN IDLE WHEN I TAKE OFF THE OIL CAP???
yea i was just thinking of that. going to put a new pcv in
so the vacuum from the intake is not going to work.
[ATTACH]7243[/ATTACH] [ATTACH]7244[/ATTACH] just the pcv off the intake plugged
96 Outback swap from hell
AWD TURBO! replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno not all ways pull it down & look if you cant see threw it or if it looks melted you'll know if it is good
I'm going to try i really miss sand lake
what would happen if i did not use The PCV valve & plugged it?
td04 on a ea82t
ran out of argon used (NOS) :Flame:ran out of .035 wire so had to use the flux core wire it looks like bird turd so flux core with (nos) going to make a another up pipe but this will work for now
td04 on a ea82t
well i fished my TD04 install set at 12 psi [ATTACH]7239[/ATTACH] [ATTACH]7240[/ATTACH] [ATTACH]7241[/ATTACH] [ATTACH]7242[/ATTACH]
AWD TURBO! replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid the cat go bad?
Uh Oh, I got an intercooler!
[ATTACH]7232[/ATTACH] this help?
but runs with the oil fill cap on?
