Everything posted by Numbchux
Build My Brat
the best advice I can give is to be patient. drive the car a lot and find out what you don't like about it for your own uses. Subaru's can be pretty much anything, and how you build it depends on your personal preference and your uses. don't get too excited and drop a ton of money into a setup that someone else said they liked, it might be a good combination, but it just as easily might not.... that said, don't just slap a turbo on your stock motor. you're not going to see enough benefits without seriously jeapordizing the reliability of the motor... no, you won't need longer shocks with a lift. but with an ea81 (what your brat is), longer rear shocks can drastically help your travel. the EJ22 (legacy/impreza 2.2l) is an awesome swap for almost any use. no turbo lag, tons of torque low in the rpm range, extremely reliable, and extremely easy to get your hands on.
fan...bearing?
heck, when it makes the noise, pop the hood and see if you can identify where it's coming from. I had the bearing in the electric fan go out on one of my '88s. I had it manually switched, so it was pretty obvious where the noise was coming from. and it was a pretty loud shreaking sound that would go away once it had been run awhile.
suspension travel mods?
no. the strut-to-knuckle hardware is extremely unique. you won't find a longer travel setup that will work without extreme modifications. and while the strut is the limiting factor, there are numerous other parts that need to be upgraded in order to do it reliably. increasing your travel in the front won't happen without some pretty serious investment.
axle shear :)
AND, that also means that that side's suspension is compressed, which means that the CVs aren't at an extreme angle.
- i want to know more (ej22 carbed)
IIRC, megasquirt can't decipher the Crank Angle Sensor signal. so something else has to be used. be it a distributer, or a sensor on the crank pulley...- Cheapest Catalytic Converter Solution
I can't speak for everywhere, but all the junkyards I've ever been to, they cut the cats out of the Y-pipe before putting the car in the yard. if it's the cat in the Y, if you can't find a junkyard one, don't even think about replacing the whole thing. your options there are OEM from a dealer (think many hundreds of dollars, at least), or custom. use a long screwdriver, or piece of rebar to knock up the remains of the cat and let them fall out of the cat. then, if you really want to have that cat in there, cut a piece of the pipe out further back, and clamp in an aftermarket one (which still won't be cheap at all). besides, assuming by your screen name that this is a 90 loyale, you've already got 2 in there.....- spfi swap... code 13 with 2 distys
snowman wrote it for EA82s years ago. GD wrote one specific to EA81s just within the last 6 months or so. if you test pin 47 with a test light to ground, it will light. it doesn't supply power to the ECU, but if it's connected to a ground, it will complete the circuit (which will activate the fuel pump circuit). I'm looking at a FSM diagram right now, the wire gets power from the other side of the relay. as for the no spark issue. double check your ignition timing. it's real easy to have your disty rotor 180* off, lining up with TDC of the wrong stroke. or are you getting no spark at all? check for trouble codes, it could be the crank angle sensor (which will throw a code).- 6 vs. 6 and a half
I think you're referring to where the valves float, which is mostly dependent on the condition of the valve springs, my better-running '88 could easily hit 7200 before the valves would float. the red-line is what's marked on the tach, the ECU on the newer cars will actually cut fuel to prevent you from exceeding the redline, as the valvetrain is much stronger and would probably rev well beyond the marked limit. I think it's carbed vs FI. my buddy's '86 and my old '85 carbed EA82s both have 6k rpm redlines (although I didn't realize it on mine until long after I junked the car and found the old gauge cluster, I swapped the cluster for one from an '88 with a 6.5k redline within a few weeks of buying the car) both my '88s, and my '92 are marked at 6500.- spfi swap... code 13 with 2 distys
pin 47 is the wire that allows the ECU to turn on the fuel pump. with the ECU unplugged, plug in the fuel pump relay, and turn the ignition on. now take a small piece of wire, stick it in pin 47, and touch it to ground. if the fuel pump relay (and therefore the pump itself) comes on, it's wired correctly.- Are there any Loyale people close to Waukesha WI?
MN. you know, big port city on Lake Superior...- 911 Wiring Madness!
it very easily could be the radio wiring. the auto seatbelts get their power on the same circuit as the radio memory, dash clock memory, horn, and hazard lights (I had the clock/horn/hazard fuse blow, and the radio wouldn't remember anything, and the auto seatbelts wouldn't work). pulling the radio isn't too tough, pull it out and check the wiring. especially the memory wire, if it's shorted out somewhere, I imagine it could do a number of funky things.- Are there any Loyale people close to Waukesha WI?
not sure where Waukesha is...but I'm up in Duluth. there are probably 8-10 loyales that live in town here. I love passing them in the tunnels- ER-27 from XT6 into GL10 Wagon
I believe just the EZ30R does. the older EZ30D did not (and also didn't have AVLS or AVCS).- How many converts here?
did you convert it to SFA? I thought it was IFS when you bought it. I too am a convert. bought the cleanest 1st gen 4Runner I've ever seen in MN. got a deal on it cause it was run out of oil. it's an '87 Turbo, and the lack of oil took it's toll on the motor, and just when I got things fixed, the turbo goes. so after I get new suspension for the loyale, the yota will get swapped to a plain ol' 22RE. bone stock, on 31s and ugly wheels, for now:- SVX swap wiring Q's
the wiring harness is from a '92. and all the diagrams and stuff are for '92. it's OBD I. nope, it's a totally separate thing. it appears that the plug for the VSS comes out near the O2 sensors. so it very easily could be on the tranny.- it Refuses to Start!
yep, it's either the switch, or one of the relays between there. like GLoyale said, hotwire it. run a wire straight from the + battery terminal to the little tab on the top of the starter. if it starts right up, it's something up under the dash. in which case, I'd wire a whole new circuit to a button....just to keep it simple. if it still has trouble turning over, it's the relay inside the starter. in which case....new starter.- SVX swap wiring Q's
I'm working on an EG33 swap harness for a local guy (into a '95 impreza wagon ). I've got 2 small questions. 1. Fuel pump modulator. What is it. there's a fuel pump signal wire from the ECU. can we just connect this to trip the pump relay. according to my pinout, it just grounds that wire to activate the pump. but according to the diagrams, it goes through this modulator first. AND, again according to the pinout, there's a fuel pump discharge flow control wire which goes to the modulator aswell. it looks like it tells the modulator how much fuel pressure to give.... 2. Vehicle speed sensor. it appears that this sensor is a completely external thing. it's got a 3 wire connector (I wasn't been involved in the removal of the harness...so I don't know where it was plugged into). I appears to have a power wire, a ground, and a signal (which goes to the ECU). can I connect the signal wire to a signal wire in the imp harness....and have it work?- ER-27 from XT6 into GL10 Wagon
an EZ 6-cyl is not heavier than any of the other listed options. it's the same external size as a 4-cyl, and uses a plastic intake mani... but, would cost many times more to get ahold of, and get running.- suspension travel mods?
you'll be hard-pressed to get 15-20" per corner out of a solid axle rig....- EA82 front brakes on EA81
yep. it's just the wagon wheels.- EA82 front brakes on EA81
that's very definitely true.- ER-27 from XT6 into GL10 Wagon
The motor is substantially longer. so the radiator will need to be moved forward a bunch. also, IIRC there is a 3rd motor mount in front. so you'll need to address that. then there's the wiring issue....but that's not a huge deal. it's more than possible. and there are a handfull of people who have done it.- suspension travel mods?
define a lot of travel...the method I mentioned above will allow for 12" PER SIDE. which is waaayyyy more than the stock axles can handle. for the front, the struts are the limiting factor (physically limiting travel, however, the axle joints will become a problem if you get longer travel struts). and since they're in integrated part of the suspension and steering geometry, substantial modification will be required to replace them. maybe design a simple A-arm to attach to the top of the knuckle to maintain camber, and then a basic coilover shock could be used. I haven't the faintest idea how you might be able to get a longer travel CV shaft to mate with the subaru tranny or steering knuckle. however you go about it, you're looking at A LOT of custom work- Chromoly Stub Shafts
I don't know, that part wasn't my idea....I just know that if you replace the double offset joint on the inside with a second constant velocity joint, you'll need to add a slip joint. the whole point of having a double offset in there is so it'll telescope. the stub's retaining bolt is in the center of the stub shaft. - i want to know more (ej22 carbed)
