136
Might be in limp mode with the O2 sensor unplugged. I suppose you could replace it but I'd recommend testing it first. There is a wire for the ECU that breaks off somewhere along the line from the starter solenoid wire that comes from the inhibitor switch (the small wire that trips the solenoid). I would assume that it uses this wire to determine when the starter motor is engaged, and changes something... Maybe somebody who knows what it's supposed to do for sure will splain it fer us. I worked on a BMW once that had a bad starter, I roll started it and it ran like crap. I thought a fuel injector was stuck wide open. But with the new starter on it, it ran perfect. Figured out later on that it had a similar type of circuit. Try to dig up an FSM for your year and find out exactly which pin and what color wire it is so you can check it for 12v when the ignition switch is turned to start. It may even come right from the connector on the starter solenoid. edit: good lord, I must be tired...
I've used Rockauto a number of times and have always been completely satisfied. Low prices, shipping can be a bear if you order a lot of stuff (some parts coming from different warehouses they charge shipping for each shipment) but most of the time it's still cheaper and better parts than what you get at the local Autozone or whatever, and they ship out fast. Every now and then you find closeout deals on some parts. I got a Beck Arnley clutch kit for my truck, normally a $150 kit, for $50 with shipping.
I know there is someone here with a copy of the FSM for 92 posted online for people to download. Can't remember their username though. If you do a search you should be able to find it. Starter switch is usually the ignition switch (the one you put the key in). Is there something wrong with the car? Does it start and run OK besides having the CEL on?
Then the caps must be machined while bolted to the head, and as such can only be sold with the head. Otherwise they won't fit. I suppose you'll have to try and get it as close to flat as you can, and get a new bolt(assuming Subaru will sell the bolts separate). I wonder if a machine shop would be able to cut it down perfectly flat?
Several of us posted suggestions for your issue. Suggestions to which we received no reply other than "BTT" which implies, to me at least, that you paid no attention to, or simply ignored, said suggestions. Some of us don't particularly enjoy being ignored. I'll accept your thanks for my suggestions. But I may still recommend you find a new vehicle, as the cost of having a shop install a used transmission, if it comes to that, will likely be greater than the value of the vehicle, despite it's aesthetic or mechanical conditions. For your sake I do hope it's a simple linkage problem, not something more serious such as a bent or broken shift fork. Good luck getting your car fixed.
Yeah I'm looking at the wiring diagram in the FSM for 95 and I don't see anything that would make it work on defrost, but not work if the button is pressed. The line from the mode control panel joins with the line from the switch, and then goes through an evaporation thermo switch, and the pressure switch before going to the AC clutch relay. I'd kinda suspect the switch to be honest. But a break in the wire somewhere between the switch and where it meets with the wiring from the control module is a possibility as well. Perhaps the connector on the switch is loose?
My god what were you doing trying to put that much torque on that poor little bolt? For future reference... they don't have to be THAT tight. A torque wrench might do you some good. I'd call some junkyards and see if you can track down a replacement. Tell them you want all the bolts for it as well. If you can't find one, order it from the dealer. They used the same part all the way back to 99, so finding a used replacement should be easy.
Diff oil is 75w90 gear oil, if you use ATF you'll destroy it in a heartbeat. Dead center under the front differential (I assume it's the front you're asking about since the rear is pretty straight forward) there is a large drain plug. It is pretty much right between where the exhaust pipes Y together from the heads. I don't recall the size but you can figure it out. Get a new aluminum washer for it from the dealer (it's like $1) before you go draining it. Anyway, remove the drain plug, let the oil drain out. Should only be about 1.5 - 2 quarts. Fill with 75 or 80w90 gear oil through the dipstick hole on the passenger side of the transmission. The dipstick is short and yellow. (probably dirty as hell but it's there) You'll need a transmission fluid funnel, or funnel with a long hose. Dipstick has marks on it or the fluid level, anywhere in the middle is fine. Pic of the dipstick location.
That's pretty much standard protocol at any dealer. They will check the heads, and if they come up within spec they put them back on. As a matter of fact I think you wold be hard pressed to find ANY shop that will have the heads milled if they are in spec, unless you specifically ask them to. Being such a short time later, one would hope that the dealer will be willing to at least help pay for the needed repairs. Just keep patient when you deal with them and they should be much more willing.
Had been running Castrol (plain) 5-30 in mine until it developed a tic on startup that would go away sometimes in 10 seconds other times it took 10 minutes. Switched to Valvoline max life 5-30 and it stopped immediately. I'll see if it returns when it's time to change again in 2000 miles. I run plain Purolator filters. With everything sealed up there isn't any need to be concerned with switching to synthetic at 100k+ miles. The main reason for not switching is because leaks tend to develop with old seals when the detergents wash the varnish away that was holding them together. If you're not comfortable with it because of what you might have read, stick with dino or synthetic blend oil and motor away.
Sounds like you bottomed out the springs. I think you need a 4x4 transmission, transfer case, and front and rear solid axle conversion with a 6 inch suspension lift and 30x9.5x15 tires. Just kidding, get some new struts. Yes, once they have been bent, they are softened, and will continue to bend. What year and model is this?
Goes to the Evap purge solenoid. Which is normally well hidden under the passenger intake runners. You don't need anything else, you have everything you need right there. You might have to steal the solenoid from your 25 if it's not under there, but that's about it. The line off to the left side of the 22 pic with the yellowish plastic thing connects to the switching solenoid on the passenger strut tower. If you're worried about looks, most of that grey corrosion on the intake and TB should come off with a wire brush. Shoot it with some good silver high temp paint after that to seal it and prevent further corrosion.
