136
Seems to me that you should have 3 U joints? The Viscous coupler part of the diff is completely sealed from the rest of the differential similar to the center differential of the manual transmissions. It could be possible that it is damaged inside, but highly unlikely. And you wold only notice it when turning, or if one wheel is significantly larger than the other. If the gears and bearings are good, then the diff is fine. What condition are the tires in on this car? How about the axles? Any ripped boots? Any that look like they've been replaced recently?
Does the connector on your car look like the one in the 96 manual? I don't have the entire manual, there's a section missing I'm sure. I did download it online but I couldn't figure out where to tell you to get it from. I think it's gone now. I can email it to you if you want. I'll warn you though, it's a little out of order.
Yeah, I figured it would be kind a shady. The PP said Valeo on it, but the disc had nothing, the bearings that came with it said made in japan, but it looked like it was just kinda thrown together. From a few parts bins. Did you happen to look at the disc and see it it had any markings on it? A real Exedy disc would have the Daikin logo stamped or inked on it somewhere. Another thought... You did install the disc facing the correct direction right? The springs/hub should be towards the transmission.
There should be two nuts on the back side of the pin on the release lever. One larger than the other, the small one is used as a lock nut to just hold the larger one in place. Those are threaded onto the end of the cable which is fed through the hole in the center of the pin on the release lever. I tried to take a picture of mine but it there's not enough room to get a camera in there for a decent shot.
Correcto! Honestly, I'm not to worried about the NVH, unless theres a really huge difference. This thing shakes and vibrates enough already, A little more won't bother me as long as it is fixing a current problem. So the 5 speed is different. Do you know the PN for the 5 speed part? Or is that the one? I figure I might as well go for the harder one since it's about half the cost of the normal one.
You will always have a small amount of consumption. If there were NO consumption the rings would wear out in nothing flat. Low consumption is great. Less oil in the cylinder creates a more stable fuel burn, giving more power and better mileage (more efficient). It is using a bit, but just not enough to notice on the stick, which is really the ideal rate of consumption. I wouldn't worry about it.
A lot of people say new brakes, new clutch that kind of thing when they sell a car, but how old is "new" is the question. "New" might be a year ago. You don't really know unless you watched them do it. You also don't know what was actually replaced. They might have just put a new disc in it and left it at that. Test the clutch by driving down a road at about 40-45mph in 4th gear. Push the pedal in, put the gas on the floor, and rip the pedal back out. Engine speed should come right back to where it was before within a half second or so and the car should jerk and throw you around for a second. If the engine speed rides back down over the course of a few seconds, the clutch is worn or not in good shape and you'll probably want a new one. The hill holder cable is easier to re-attach if you disconnect it from the release lever first. You can get at the cable end on the lever easier from the passenger side of the car, it may sound weird but there IS more room that way.
I'd have the cylinder bored over a hair (.010) and use an oversized ring on that one. You can try honing the cylinder and putting in a new set of rings, but honing doesn't make the cylinder round. It may not fix the problem. Couple extra bucks for a bore and hone at a machine shop ensures no cylinder wall damage or out of round, and new rings properly broken in will do the trick. Be sure to double check all other cylinders for wear before jumping into this too far. You might even decide to do all 4 cylinders so you get even compression. That would cost a bit more, but may be worth it in the long run if you decide you want to keep this car/engine for a long period of time. Or you might decide that it's not worth it and want to drop a whole new engine in. 2.2s are cheap, and bullet proof (no HG problems).
Junkyard for under $100, and maybe 3 hours work if doing it for the first time. Just have to match the ratio of the trans. How do you figure that the rear diff is bad? What symptoms? What have you done to determine that it has a problem? And no, just putting the FWD fuse in will not help if indeed the rear diff is toast.
Shouldn't be hard at all. You remove the tail shaft housing of the transmission (8 bolts) and the center diff pulls right out. Disassembling it is probably more difficult than getting it out. But you can find the instructions for how to do so in any FSM from like 90 - 2004 Legacy or Impreza. You do have to remove the exhaust system, and the drive shaft, but the transmission does not need to come completely out to remove/modify/change, the center diff.
