no power to one front wheel...
Fairtax4me replied to michaelbteam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOver filling wouldn't cause the stubs to feel loose. A new axle has new grease in it. New grease is thicker than old grease, therefore you get more drag (resistance) when trying to turn the new axle than trying to turn the old one. The front diff is "open", so one wheel can be completely stopped, while the other spins about twice as fast due to the ratio change that happens when the differential spins. You might not feel this difference in drag, but the effect is that one wheel is basically held in place almost like the brake is on. The other side (lower drag) is able to spin freely because of the action of the differential. Give the non spinning wheel a nudge by hand and see how it reacts. Lots of things can cause vibration. What is happening with the car when you notice the vibration?
92 Leg L Wag VCG
Fairtax4me replied to mountainchef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou shouldn't need to. But it will be fine to use a few small dabs of silicone sealer in the corners or a quick shot of copper gasket spray if necessary.
Idling a tad Rough? '96 Legacy
Fairtax4me replied to excalibur5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the rough idle use a can of Seafoam in the intake, and make sure all of the vacuum hoses are in good shape.
Oil Leak. Making me crazy.
Fairtax4me replied to rrryyyaaannn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis sounds all good in theory. But high pressure water spraying all over the engine bay can force water, and dirt, past the rubber seals used to keep water and dirt OUT of electronic connectors. Water invites corrosion, not to mention short circuits.
legacy mpg is terrible
Fairtax4me replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBuy a Bosch one for half the price it'll last just as long.
Dummy Question: Car's temp guage goes up with no AC, stays level with AC.
Fairtax4me replied to kirbykirb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a bad engine cooling fan relay.
Seafoam!!!
Fairtax4me replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou did realize this thread is 4 years old right? But since we're on this topic. I use about a two foot section of 3/16" i.d. vacuum hose connected to the evap purge line nipple right on top of the intake manifold right by the throttle body. It's the easiest one to get to, and if you come prepared with your own extra length of hose you can put the can on top of the radiator and dip the hose into the can just enough to slurp up the seafoam, while you balance the throttle speed with your free hand so the engine doesn't stall. Do a half can, and kill it, then watch the smoke show. Just be sure to face the front of the car upwind from the exhaust.
Still White Smoke After Head Gaskets/Lifter Ticking
Fairtax4me replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a leak down test.
Strange Noise around timing belt area?
Fairtax4me replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell there's an adjuster in there for the valve lash. That would probably make a good bit of racket all the time if it was out of whack though. As far as the tensioner. Could be possible, but I think the only way to find out for sure would be to pull the covers off and start the engine. Do you have a mechanics stethoscope? Those are helpful when hunting around for strange sounds. edit: It should have been MMO. Marvels Mystery Oil.
Fairtax4me replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly one potential problem with the lifter theory... Your engine might not have hydraulic lifters. Somebody who knows a bit more about the changes in the EJ22 across the years will have to chip in and confirm. Marvels Mystery Oil. Typo, my bad. The high mileage stuff has extra detergents in it and some other additives that help prevent things like sticking or collapsed lifters. It's the next best thing besides switching to full Synthetic.
Fairtax4me replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCollapsed, sticking, dirty. Some MMM and an oil change should shut it up. Do you use the high mileage mix or plain old GTX?
Fairtax4me replied to rrryyyaaannn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's by the axles it's probably differential oil. Get some non corrosive degreaser (purple power works good) and spray down the area then hit it with a water hose, try not to use too much pressure. Do that a couple times to be sure you get all the grease out of there. Drive the car a mile or so and then look and see if there is a new trail of oil that will lead you to the source of the leak. Probably going to be the axle seal since that's the only thing in that area.
Fairtax4me replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be lifter noise. When was the last oil change? What brand of filter do you use?
Up a Creek with a Mystery Motor - 1997 OBI
Fairtax4me replied to Balewolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is brilliant advice. I was picturing someone digging through wiring diagrams for hours trying to match up which wire goes where and then soldering and heat shrink wrapping a gajillion leads under the hood. It's laughable how simple you just made that. Is there any power difference between the 1.8 and the 2.2?
What the hell?
Fairtax4me replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhats the average life span of an Optima battery?
Weird modification to heads
Fairtax4me replied to sean56a's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDunno what you're looking at really. But if its the two half circles, that's normal.
What would make a transmission die like this?
Fairtax4me replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomebody grinding gears constantly. Throwing shifts too quick and wearing out the synchros then grinding the dog teeth down to points. Probably never changed the fluid either. Doesn't really matter what or how it happened, it's shot now. Open it up and see what you find for gits and shiggles.
Fuel pump not coming on - ECU?
Fairtax4me replied to Bruski's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure it's possible. One bad transistor is all it takes.
Strange Oil leak.
Fairtax4me replied to timfreddo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll third the cam seal. Do both, and the crank seal while you're in there.
Legacy rear trunk assist spring/bar
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're not easy I'll tell you that much. Never done one on a Subaru, but I've replaced a few torsion rods on other cars and it's not easy at all. Keep your self clear of the rod when you;re trying to get it into the adjusting hook, if you lose your grip you might lose something else too.
Fairtax4me replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCars generally only had one O2 sensor until OBD2 came around.
Fairtax4me replied to Bruski's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it would pretty much have to be a bad ECU if the relay is not grounding. You're absolutely sure the relay is getting power from the fuse block?
Tire Question - 2000 Forester
Fairtax4me replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo on both. The wider footprint and larger diameter will both work against you for the fuel mileage. Ask someone with a pickup on 32" mud tires how their mileage is compared to their old stock tires. And while the wider tire may hold an extra centimeter of road underneath it, the taller sidewall will fold more, and negate any desirable effect the added width might produce. Not only that, larger tires generally cost more. You're probably looking at an average of $5 more per tire for that size compared to stock. If you want better handling, you get a larger wheel with a shorter profile tire to reduce sidewall flex. If you want better fuel economy, you get a skinnier tire. The thinner foot print means less friction on the road, which means it rolls easier. But it will also be harder to stop.
Coolan Smell
Fairtax4me replied to jamiea98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was under the impression that it needed to be pulled because of clearance issues. My mistake.
engine hesitation
Fairtax4me replied to redovermind's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's about 9.25kpl, or 22mpg, which should be normal for "city" driving. Stop and go traffic, that kinda thing. If that's your highway mileage, cruising ~ 100kph, then something is probably wrong.
