987687
Everything posted by 987687
  1. Oh, well... I was going based off a stock 90hp engine. Quite a different story there..
  2. They shouldn't warp after a year. Check that your parking brake isn't dragging. Maybe buy a different brand. There's no reason to treat your discs, high performance whatever etc with these cars. There just isn't. Get whatever is cheap.
  3. So that way when one breaks, the other one can break at the same time! Of course...
  4. Interesting. I should test mine. I've had some corroded wires in my car causing high resistance.
  5. Or move close enough to your job that you can walk or bicycle. Cars suck.
  6. Go on rock auto, get rotors and pads. I got front rotors, pads, and an 02 sensor for about $45. It's all been holding up fine for a while now. And I don't exactly drive easy on my car.
  7. My car has done this for the three years I've owned it. Is your idle too low? Do you have sufficient voltage from the alt at idle? Your volt gauge probably bounces a little too.
  8. If you have slop in your steering (tie rods), you should replace those too. Slop up and down can also be ball joints, check that. Really not something you want to fail on you.
  9. You can buy my old assemblies and computer ... they work fine.
  10. My 89GL HAD those. Stupid things, they weren't even broken, and I ditched them.
  11. I've had knocking issues because bad axles, bad wheel bearings, and bad cone washers. Bonus points if it's more than two
  12. 987687 replied to 987687's topic in Off Road
    I'm going from ME to NC at some point this summer... 2nd gen what parts? I have a pile of 2nd gen stuff, and I can get GL stuff.
  13. That's a really good idea on the wheel. Makes sense, maybe someday I'll give it a try I have an old GL wheel. I had to customize seat rails to get impreza seats in my GL. Just cut and welded.
  14. http://www.cars101.com/impreza_archive93_96.html#1995 impreza I trust cars101 over other sources online.
  15. I don't know what shopkey is, but I think it's wrong...
  16. Does the EJ wheel just directly bolt up? Since I doubt it... what mods did you do to make that work? That's pretty awesome. If I didn't have a grant I'd be putting a leather legacy GT wheel in mine.
  17. Well, if the trans computer can't get a speed signal, how is it supposed to know you're going fast enough to shift into 2nd gear? Check for trans codes and see if it's complaining about VSS.
  18. Did that without a floor jack. Fun indeed...
  19. Do all Loyales not have a volt or oil pressure gauge?
  20. It has a 15.9 gallon tank. Until around 2005 all the EJs had a 15.9 gal tank. The fuel gauge doesn't read very well. After the gauge in my 98 legacy sits on the low peg I can still drive over 100 miles before it starts crapping out on accel... And even then I can drive enough 7 miles to a gas station. < ask me how I figured that out.... I put 15.8 gallons in it. Also, look on cars101 at specs if you don't believe me.
  21. Ya, probably not worth changing it then. As long as it doesn't sound like using an egg beater in a pot of rocks (bad bearings), the tranny is gonna be fine.
