Everything posted by Nug
TDI's can twist up to like 5 grand. But you want cruising rpm lower, or you will lose that delicious economy. You could probably make up for it with larger diameter tires.
my wagon caught fire!!!!!!!!!!
Nug replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
****er. Happy April 1st. -
Latest mod.... at LEAST 50hp :)
Nug replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fixed -
has anybody put an ej22 into a 84 hatchback
Nug replied to scrapdaddytatum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What gave you this idea? -
using GM alt question?
Nug replied to dragonwingsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This type is sensitive to things like jumpstarting and such. They are easy to burn out. I'd avoid these. -
Valve JOB
Nug replied to tfarm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you want to do more testing yourself, do a compression test, then a leakdown test, like The Dude recommended. Here's a link about leakdown testing. -
I wouldn't worry too much about the leak between the engine and trans. There is something on the back of the engine that likes to leak, but I'm not aware of leaks in that location really smellin' everything up. Yeah, subarus can leak a lot when they get some miles on them. When you get your timing belt replaced, also replace the front crank seal, and the two cam seals. These seem to be major culprits. Finally, inspect the inner CV joint boots. They split and slop grease all over the exhaust.
The EJ is fairly difficult to wire up. I have not wired a MPFI EA engine, so I can't compare the two. I have a EJ22 in the back of a '74 standard beetle. The engine is preloaded against the body via a brace bolted to the bottom of the engine. This is absolutely necessary if the car is going to be driven agressively at all. I had bracing on there with the stock vw engine. I have not had any problems (yet) with a stock vw tranny filled with synthetic gear oil. I did shatter a cv joint, but that was without the engine brace, and I had a lot of shudder when accelerating agressively from a stop. No problems right now. You might want to figure out a method of cushioning the engine brace against the body, otherwise a lot of noise and vibration will be transmitted to the inside of the car. The ej isn't significantly heavier. Ground clearance may be an issue. Mine is armored. Finally, the EJ's are some of subaru's best engines, and they will run hard for a long time.
Keep in mind the ea82 is much, much wider than the EJ. You may have clearance problems. I vote EJ.
The isuzu engine out of the P'up model is perfect in every way.
Some ea82t questions (VW swap)
Nug replied to dneufeld's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't put it in the back of a bug. It is too wide, and you have to cut too much stuff. Seriously. Opt for EJXX or EA81 instead. -
1995 Impreza
Nug replied to skittleson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Camshaft position sensor replacement: Unplug connector Remove bolt Remove sensor. Installation is the opposite of reverse. -
Alliance Meet head count (for planning purposes)
Nug replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
Mmm, showing up looks a little brighter, I'll be in the RX if I still have it. -
:-p I have no idea.
I welded a pan on a K-car that had a gouge and was leaking actively. Shop vac is duct taped to oil fill, keeps oil from leaking out. I used a mig welder, but a quick little zap from an arc welder shouldn't hurt anything.
the gl-10 rx wagon goes CRUNCH
Wow man, that totally sucks. It was on the road for what? Two weeks? Bastards. -
Fan resistor pack. They burn out a lot.
