Everything posted by Nug
I sunk my car
Where's your sense of adventure?
anyone tried running a 4bbl on their soob?
They got old VWs to run with twin Weber 48mm IDA's. Anything is possible.
Just saying Hi
Nug replied to Bajabev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are kinda like dirtbikes. You get one, and soon enough, there are four hanging out in your garage.
Engine RPMs - 96 Legacy OBW w/MT, 2.2l eng.
Nug replied to paulandirene's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can twist it up all day long and not hurt anything. They like to rev.
If you had 10 psi of boost running through that carb and into your engine, it would work out well. Or if you were twisting it up to 10,000 rpm. It would look cool, though.
My baby is gone, but I'm alive to tell about it.....
Nug replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy mom got railed by a fullsize pickup. She was waiting to turn, he had fallen asleep. Rearended her at 55 mph. She walked away. '95 legacy wagon.
EJ22 swap done........motor wont start........
http://www.paeco.com has clutches. You will have a heart attack when you figure out how much they are, though.
I sunk my car
And condense on the sides of the transmission case, and return to the oil. Change it. Water is a crappy lubricant.
Compression test results
Historically, compression numbers are supposed to be within a 10% difference of each other. Of course, after I say that, I think it's 20%. I forget. Anyway, those numbers seem acceptable.
Maby I shouldn't have gone through that puddle
Good Lord man, that avatar is hideous. I laugh whenever I see it.
99' OB engine tore down tonight ARRG!!
Nug replied to Meeky Moose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI''ve got a machinist I trust. Want me to give him a call?
Nug replied to Meeky Moose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChesterfield auto parts in Richmond. Any engine in yard, $100 plus $25 core. Can it be sleeved?
Help ME!!!!!!!!!!!!!!!!!!!!!!!!!!!
Rust is really abrasive. While the engine would certainly run, and the rings would remove it in seconds, it does nothing for the life of the engine. The correct thing to do would be to disassemble the engine, hone the rust out, clean, and reassemble. What you actually do you can take to the grave, if you don't want to admit it. The engine will run either way.
Burnt valves
Nug replied to Tom Dunn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf a valve (especially exhaust) does not seat correctly (due to valve guide wear) or fully (due to incorrect lash adjustment) it will overheat. Overheat warps it. Superheated exhaust gas leaks by, like an inefficient cutting torch. Eventually, a pie slice-shape is missing from the tulip of the valve=no compression=sucks.
Engine block/case gasket
W3rd. I like Cummins RTV also, it's thicker than regular ultra grey. Hondabond *gasp* is awesome, also.
The RX needs a paint job
The interior is black, its got the checkerboard seats and seatbelts.
Ok, whos car did I see?
Five o-clockish, southbound 95, slow lane. A lifted, first-gen wagon, yellow, "tonka" word and graphics on the sides. Bush '04 sticker on back. Dude wearing sunglasses. <----Purple tacoma swerving into your lane while attempting to take camera phone pics. Sorry 'bout that.
I wonder if Meeky Moose has a pic of it. You all know how timely I am about taking pictures.
update: pb blaster didnt work :( Best penetrating oil for rusted screws?
Impact driver much?
Yep, the 85 RX has some nice oxidation going on. I'm not sure what color it's supposed to be, it's a dark gray/black with a little metallic. Anyway, anyone have suggestions for what color it should be? Photoshopped examples would be appreciated. Also, is there a source anywhere for fresh decals? The stockers look horrid. Should I peel them off and forget it?
Subaru vs. Jaguar
The british did a damn fine job of making a 5000lb (?) car handle really, really good. You could push it waaay over the edge, and a quick check of the wheel brought her right back. A fine car, with worthless oil seals, a penchant for rust, and terrible electrics.
Tips on disconecting engine from auto.
Nug replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are two dowel pins aligning the engine and tranny. You might need to smack these with a pin punch and hammer to disturb them, corrosion can make them hold very, very tight.
Subaru vs. Jaguar
I took mine on a 1000 mile trip. It used 12 quarts of 60 weight. Granted, we (my sister and I) were pushing it, cruising all day at 80-85 mph. The car had over 200k.
Columbus, Oh meet???
If I go, I plan on breaking mine while I'm up there, then trying to drive it home like that. I contemplated driving the subaru bug up there last year, but I was afraid it was gonna break. I thought about packing my mig welder in the back. I ended up towing it.
So the fuel pump comes on when you turn on the key, and stays on while cranking, right? And it has spark? Are your injectors firing?
