Everything posted by Nug
Columbus, Oh meet???
Where would we baja?
TWE Information *ARRIVED*
W3rd. 1stsubaruparts doesn't have pictures. I like pictures.
New Member Clutch and Timing Belt/Chain Questions
Nug replied to PastorPaul's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut a water pump on it too, while it's apart. Take a look at cam and crank seals, too.
Emission time again...
What were the numbers?
Does the choke on a carbed engine rob power while it is choking?
For the first few minutes of operation, the engine likes a richer a/f ratio. Power levels are expected to be lower. You CAN adjust the choke, but full throttle while the engine is cold isn't recommended either way, so my advice is to let it warm up some with the choke at the current setting, THEN rag on it.
What's a good vaccum level for ea82t?
17-20 is considered normal at idle for almost all cars.
My car is a "steamer" now.........what is the cheapest fix?
I think you're gonna catch hell trying to find that tap.
overheating and no cabin heat
Nug replied to AaronCarol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXImpeller detached from water pump? Hey, it happens.
Anyone have a busted motor for me?
I have a Jaguar longblock you can play with if you want. Free. It's supposed to run.
Subaru VS. ELk
Colt Vista? They're fun 'til you rip the splines out of the torque converter. It's not like I did that twice or anything.
clutch for modified EA82T
I'd go with a 4 puck. Three puck engagement tends to be violent. You will stall or break stuff.
Coolant losing color?
Nug replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI meant the additives already in the coolant. If you ph is way off, then I guess it needs to be changed regardless.
Mayonaise in crankcase! Where is water coming from?
Don't worry about it.
Doing ej22 swap.....need fuel pump
I used a MSD inline pump for fuel injection. I got it used off eBay. No part#. I bet that helps a lot.
What Subaru models have 2.2 interference engines?
Nug replied to jodihodg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Jodihodg, guess who I am! Well, there you have it. ccrinc rebuilds these things, so I would have to agree with her. Also, the solid-lifter cars need a valve adjustment periodically, but it's something like every 105k (not sure). I still say if it doesn't pop head gaskets like the phase I 2.5, then you are good to go.
Nug replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEthelyne glycol is clear, so I guess the dye is on its way out. Other coolant additives too, perhaps?
why me god, why always me?!?
Ahem... Put my plates on, and take my registration, and problem solved. Drive it on down. Just don't get pulled over. Simple.
Take the tags off of my RX and drive it down to me.
Cleaning cyclinder block, head, camshaft etc
Nug replied to bearbalu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. There should be crosshatch still visible, with no scratches going up and down the length of the cylinder. There should be no/almost no ring groove at the top of the cylinder. 2.I would scrape the carbon ring off with a razor blade. Same with piston face, just bring it to TDC. try not to get this stuff all over the cylinder walls. 3. I would just try not to get it everywhere. If it lands in a cylinder, wipe it out with a clean rag. Keep rags in the cylinders to block things from falling in there. 4. Since you are replacing a head gasket, I'd send the head to a machine shop and have it checked to make sure it is flat. They can disassemble the head and soak it in a solution which will get all the crud off of it. m They can do a valve job too, if you desire. 5. Simple green or another strong solution that won't etch aluminum can be used. You can rinse with water if you dont get it anywhere but on the outside of the engine. 6. I don't see why not. Just dont clean the block/head mating surfaces with it. 7. I don't know where you are going to find the tp, but if you can get ahold of one, i'd do it. Insurance and all. 8. In the head? Let the machine shop clean the head, inside and out. If you choose to do it, I'd use brake cleaner, then compressed air.
I'm putting a roof on my house. Actually, for the last 4 days, I've been on a ladder. You could always bring it to me, and I'll let you know when it's done.
I got a turbo shortblock sittin' around here somewhere...
Possibly maybe. PM me if something goes down, I'll never think to check this thread again.
RX ignition question
'85 RX When I turn the key off, it sometimes continues running for a couple more seconds. Not dieseling, but running normally. The tach jumps around some, too. Also, as I was working on the horn today, I turned the ignition on. The tach jumped a few times, the was a faint clicking sound, and the engine jumped, like the ignition coil just fired a bunch of times and the engine had turned some. Does this happen to anyone else? Any ideas?
Any ideas?
I'm glad it finally worked out. I find that when I'm on a deadline, something always goes wrong and I miss it.
EJ22 swap-o-rama!!!
I used an ECU and harness out of an automatic car for my bug.
