simbey1982
Everything posted by simbey1982
  1. is it just under braking...or acceleration as well?? If you have an auto beware torque bind:banana:
  2. well behind exhaust heavy cars that will happen... if it is doing it all the time.....i would check two things exhaust leak: check your exhast around the headers and catalytic converters for cracks or leaks that may be blowing exhaust out prematurely. Also if this is happening you will start to get sick so i would check this pretty quick Oil leak. THere may be an oil leak that is leaking down on your exhaust and burning off as it gets hot....see if there is any fresh oil on your exhaust... hope this helps Cory
  3. autos are more problimatic than 5MT....try to drive before buying....if you can, get up to highway speeds see if you notice a clunking sound or see if the tranny slips like the devil....anyway sounds like a great price.....wonder why??
  4. Have a few questions for some of you who might know, i recently got my hands on a 2002 RS 5MT this is the hydraulic setup. it will go into my 97 impreza Here are my questions 1. Can the hydraulic setup be replaced with a cable setup ( i havent got to look at the subaru hydraluic setup before) via a new fork etc? 2. Will my shift linkage, work the same? 3. Are the transmission length dimensions the same? i have a 5MT out of a 91 legacy in my impreza at present and am wondering if the driveline will work.... 4. Also any good leads on hydro pedals and cylinders would be good...thanks Cory
  5. if you totally remove the driveshaft on the transmission side and jack it up too far it will leak out the shaft in the rear....be careful
  6. yeah dissconnect negative lead, have autozone or someone pull your codes
  7. bump anyone with a part lookup that knows the gear ratio?? Cork
  8. hmm...dont know...thanks for the info josh can anyone look up the part num for me?
  9. Need a drive ratio for a 5mt from a 2002 RS Part # 32000AF560 other random numbers 4X-TY754VFBBA Any help would be appreciated Cory
  10. From what i have heard and seen, Yes you can USE them and it will WORK...but it wont take advantage of any ugraded injectors or anything if there is any......hope this helps
  11. anyone know if struts are interchangable between models....impreza, legacy, wrx
  12. well you could get a pirated scanned one on ebay for cheap...service manual But i didnt send you.... Cory
  13. i must say thats a good deal for a new bar... and we do have a plethora of nice subies in yards... i wouldnt call them rusted out though....:-p Best wishes from Dead subaru land.....:cool: Cory
  14. air air air....bleed them until they work....and if they dont...get a new master cylinder and bleed them until it works its a pain..i know
  15. not to step on toes....but if your cheap (like me:lol: ) you could get a beefier sway bar from a 90ish legacy out of a yard...they fit the impreza's...with some creativity Cory
  16. Well looking to do some suspension upgrades to my impreza Found some good STI springs on the board (Thanks WJM) just confirming they will fit.... Also looking at struts Im looking at KYB GR-2 struts...and caveats??? Im having trouble finding these "specifically" for the impreza of my year....would the legacy or WRX ones fit?? THanks for all of your help Cory
