Everything posted by Scoobywagon
Anyone here speak diesel?
I'm replacing the fuel return lines in my 86 F250. ONe of the injector caps in the kit is defective. Well, either that or there's a bad o-ring in there. I was thinking of using an o-ring from my collection, but those are for AC, not fuel. I just don't want the fuel to shred the o-ring and then have the inject suck in bits of shredded o-ring.
first post from Australia: Forester towing
For the usage you're talking about, the Forester may not be a bad choice. You're quite right, though. It's going to be a tad light in the torque dept. As has been said, Subaru's are a poor choice for towing duties. However, your towing appears to be intermittent, though borderline insofar as weight goes. If I was sort of pinned down to one vehicle, I'd probably go ahead and get the Forester. I would then save up to purchase a more appropriate tow rig. Given the loads specified, it wouldn't even have to be much of a tow rig and therefore should be doable on the cheap. In the mean time, just take it easy and don't plan on being in a hurry. The Forester is going to be slow off the line. Just accept that and be courteous about it. If you're on a 2-lane road and 3-4 cars are backed up behind you because you're slow at the lights, then pull over and let them by. A little common sense goes a long way and everyone is happy.
One LONG drive
Few weeks ago, my wife and I drove from our place to Oklahoma City to Dallas to Lubbock to Moab to Salt Lake and back home. I've forgotten what the total was but it was something like 4200 miles in 10 days.
sub radio/cd needs programming?
Scoobywagon replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs John said, that won't apply to you. Subaru never did that. Probably just his standard disclaimer.
one step forward three steps back in engineering changing a stop light bulb old vs ne
Scoobywagon replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTell ya what, you can bring the car to my shop and we'll do an HID upgrade for $200 + tax. Longer bulb life and more light to boot.
Annual Hatch Patrol Xmas Tree run
One way or another, there WILL be chainsaws. Oh, yes. There WILL BE chainsaws.zzz
Leaking front windshield ea81
It is not a suitable sealant for a windshield. Silicone is generally not UV stable (though there are variants that are). Silicone lacks the appropriate shear strength for a windshield. Silicone will contaminate the glass surface, making your windshield unsuitable for proper installation later. That fact will also ensure that you cannot properly seal your windshield. Appropriate adhesives include urethane and bedding compound. Bedding compound is the appropriate sealant for a gasket mount windshield. Urethane is the appropriate sealant for a urethane set windshield.
DO NOT use silicone! For any reason. Ever. At least, not on a windshield. Give me a call at work tomorrow. I'll see what we can do for you. (360) 377-0769
Tire chain size question
Those tire chains MIGHT fit, but be aware that if they do, then the cable leader (that part that lets you adjust their size) will be fairly long and will likely try to shred your fender. Frankly, I wouldn't worry about it. Get yourself a second set of wheels and put some good winter tires on them and forget about chains. And if you REALLY want to have some fun, you put really good winter tires on the front and all-seasons on the back. That combo makes them REALLY tail-happy.
EA81 Alternator ( plane )
Early EA81's were externally regulated, but the later ones were internal. The 2 alternators in question are interchangeable. 11.45 @ 3200 indicates a problem. SInce this is an aircraft application, I'll bet that it it internally regulated. That means there's a dead alternator. Time for a new alt. Maybe time for an upgrade, too.
Another Subaru guy from WA!!!
Howdy to both of ya's. Welcome aboard....get it? Its "a board".
95 legacy tranny no traction after flood waters
Scoobywagon replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa know...if you're in a pinch, FWD is MUCH better than NWD (No Wheels to Drive).
AC Compressor Locked Up
Strap wrench should go on the pulley directly. In other words, pull the belt off the compressor.
Yes, you can just put current to it directly from the battery. During the time it sat empty, had you left the system under vacuum? It occurs that it is possible that the rotating assembly inside the compressor could have corroded. If so, then the compressor is essentially toast.
I would apply current directly to the compressor clutch to make sure that it engages properly. Just leave the engine off and make sure that you can see or feel the clutch engaging and disengaging. If it will engage properly, then you can put a strap wrench on the pulley and try to turn it by hand. How long did it sit empty?
I'm in. Hopefully I'll have the truck sorted out, otherwise, I'll be in the Forester.
If the system is discharged, then the compressor won't run because the low-pressure switch won't let it. Did you recharge w/ R12 when you replaced the condenser?
Power Windows
You might think about getting a can of aerosol silicone spray lubricant. Excellent for lubricating window felts.
which lights will light the road better
Scoobywagon replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would go with the factory fog lights and convert them and your headlights to HID. The patterns remain the same, but you get WAY more lumens.
cruise control for 97 impreza?
Rostra Precision Controls part # 250-1176 and Rostra Precision Controls part # 250-1223 1176 is a sort of universal cruise kit and 1223 is a universal control handle. Installation is pretty straight forward and complete (useful) instructions are included. Plan on this being a half-day install if you've never done something like this before. Having said that, if you have the option of using a factory kit, do so because steering wheel controls rock.
electric impact?
My 14.4v 3/8" impact makes short work of even the most stubborn seat bolts and will happily tear the heads off the carrier bolts in an R160 diff. My 18v 1/2" impact makes short work of...well...almost everything. Darned handy for changing monster truck tires.
Window regulators/glue questions
The window regulator should go in and out in a single piece. Been a while since I was in one of those, but as I recall, its a bit of a wrestling match, but not too bad. You use urethane to attach the glass to the little nylon clips. So far as I know. the trim parts are just that...trim.
Fog light for 98 Imp OBS?
Scoobywagon replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I remember correctly, the Loyale's had glass lenses. So even if they are NASTY, you should be able to clean them right up. Either way, HIDs will be brighter. As for blinding on coming traffic, just make sure they are aimed properly.
Snow Tires: Worth it or overkill?
Scoobywagon replied to mrCharlie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSnow tires are worth EVERY penny. Where I live, I have found that I don't need studs. However, there are some areas of the country where studs could be very important. I suspect that you live in one of them. I have at least 2 sets of wheels for every vehicle I own. One set has summer tires (either all season or high performance, depending on the vehicle), while the other set has winter tires. I find that a taller, skinnier tire is the way to go for snow. I run Blizzaks, but in areas where you can reasonably expect ice buildup on the road, studs are the shizznit.
Scoobywagon replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would probably go with something that will mount in the OEM location. Usually, you add fog lights for low-visibility situations and having the lights lower to the ground will help you with increased contrast. Also, consider using HID lighting in the 3000K range for color temp. 3000K will give you a bright yellow color that will also help give you higher contrast particularly at night in the snow. The bright yellow color also means that oncoming traffic is more likely to have a better chance at spotting you than with just white driving lights. Personally, I'd check the wrecking yards to see about scoring some OEM lights. Otherwise, there are some really EXCELLENT aftermarket options available. VisionX makes some good ones as does Hella. Both of those names will cost you some coin, though. Don't just go down to the local auto parts store and pick up the little cheap lights. They look snazzy, but don't stand up very well to ANY abuse. That includes low temps and occasional encounters with heavy snow. Somehow, I suspect you'll have both of those problems in AK and that means you'll not be happy with the cheapies.
