16
Everything posted by Crazyeights
Another XT6 Crossmember Question
Crazyeights replied to linkthehero1234's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 92 Loyale with an EJ22 swap using a 93 legacy 5MT transmission and rear diff. For a cross-member I am using the EA82 front and rear, the EJ22 center-piece bolts right up to the EA82 cross-members. From what I recall, the XT6 should be similar to the EA82 generation. It's been a long time since I sold my XT6. I can put my Loyale up on the lift tomorrow and take a couple pictures of my franken-member if it would help. Do you have any pictures up anywhere? Do you have a source for another 6MT? -
aftermarket fuel tank for 86gl wagon?
Crazyeights replied to Groucho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have an 83 GL wagon and a 92 Loyale wagon. I EJ22 swapped both cars over 10 years ago and they both run great on the stock tanks. The fuel tanks aren't that big so I try not to run them low. -
I bought a new dual mass flywheel from Subaru for mine, but they are expensive. It'll never be right if it is resurfaced. They disintegrate easily when abused, and the shrapnel can tear up the rear side of the block. We have tried a couple of conversions to a single mass flywheel at the shop and they both had problems.
1990 BRAT EJ swap and Other stuff.... (Chilean Way)
Crazyeights replied to Rafavidmess's topic in Subaru Retrofitting
The pitch stop rod is a Must! You will break both motor mounts quickly with out it. Then the engine will open your hood for you -
Scrap that block and bring them a better one. An EJ22E that hasn't been abused shouldn't need to be bored oversize. With the cylinders laying flat, excess bore wear usually is not a problem. Even so the odds that a smaller shop has the proper equipment, knowledge, and experience to bore one of these blocks properly is slim. Find a good running used one, rebuild the heads with new exhaust valves, seal it up with new gaskets, timing belt kit, and water pump. Leave the oil pump alone but do buy a new oil pan and pickup screen. No offense but if you are asking these type of questions then don't split the shortblock open. It won't ever run right again.
4 Speed to 5 Speed Swap Kit? EJ Swap
Crazyeights replied to SaltyMike's topic in Subaru Retrofitting
I have 3 pictures of "Jerry's Kit" that I took right after getting it directly from Jerry years ago. The "Kit" is still holding the trans in my lifted '83! What is the easiest way to make 3 .jpg files available? I don't have any space here. I have lots of old notes and some other misc pictures relating to the swap if you are interested. -
Have you read the EA to EJ swap guide? It has all of the diagrams, directions, and pictures that you need. EA to EJ swap guide
Rust? ^^^
An EJ swap in an EA body makes a fun ride, it's like a whole new car. I have 2 EJ swapped Subarus right now - both with stock EJ22s in them. One is a AWD '92 Loyale and the other is an '83 GL 4wd wagon. @Subiedude.12 do you have any pictures or a thread up somewhere? @GeneralDisorderI am glad no one was hurt! "Ended up in someone's lawn narrowly missing a mailbox" - I did that in my friends moms Datsun B210 Honey Bee
Damn it's nice to hear from you Rob! I'm glad you are ok. Very nice work on your EJ - RX!
Some basic organized diagnostic procedures starting with compression AND leak-down tests should have the problem sorted out in short order. Do NOT assume that any part or system is "good, tested, or trusted" until you verify it for yourself. Especially a new or reman part. A smoke (vapor) machine can be useful in locating hard to find vacuum or boost leaks. It can be difficult to offer this type of help in an internet forum when you don't know anything about the person working on the vehicle and their skill level, not to mention the history and condition of the vehicle. The EA82T is probably one of if not THE most universally disliked engines that Subaru ever produced. That being said my 89 GL10 Turbo wagon is the only EA body vehicle I own that hasn't been swapped to an EJ and it's still one of my favorite cars. To me an EA82T with 1 and 3 (same bank) is screaming "my headgasket has been leaking for 20k and my cylinder head is cracked."
Dual Range Trans into 92 Loyale
Crazyeights replied to yblocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes it should be. I have done that swap and I don't recall anything unusual coming up. -
Congratulations on your New (to you) Subaru! In my opinion it is a very good choice for starting out. My story is very much like yours. I was young and didn't have a car or a lot of money. I figured out early on that the only way I was going to own a car at that point in my life was to start with something that didn't run. I started doing simple things in my driveway. I got a phone call one day from the owner of a Service Station where I had dropped off a job application, I had totally forgotten about it. I went in to interview for the job and the station owner asked me what I wanted to do going forward with my career. I told him that I was looking for a part time job so that I could afford to buy some tools and go to school to learn how to work on my own car. His response changed the rest of my life. He said "just give me 2 years and I'll turn you in to a certified tech"! I was so stoked! 40 years later and I have the knowledge and all of the tools I'll ever need to repair and build my own cars. I am still in the industry today, and I am currently employed as the Senior Advanced Level Master Technician in a busy 9 bay shop. I mainly do general repair and drive-ability diagnosis. The need to learn new things and acquire new and different tools never ends lol. Apologies for the long winded post, I have been stuck inside for a week fighting Covid.
Flywheel installation question on EA81
Crazyeights replied to UnorganizedMechanic's topic in Carburated Engine Tech
As far as I remember, it only installs one way due to the bolt pattern.
