Everything posted by Craven
Then you would have a Land Cruiser.
Thanks Glenn
What is the site?
Attn photoshop guys!a small request please
Craven replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump -
I tried. -
[urgent help needed] rear diff disassembly
Craven replied to stinky's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1/4" drive E10 torx socket -
http://www.ultimatesubaru.org/forum/showthread.php?t=19156&highlight=rearend+torx+socket -
a wagon wheel of a different color
Craven replied to karinvail's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's what I was talking about (stainless steel). But for something a little different, the center caps from a Mazda pickup truck, spoke style steel wheel will fit. If you want to see one, I'll shoot a pic. tomarrow. Craven -
Experiences painting Subarus with exotic paints?
Craven replied to Bratenstein's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Doing a flip flop paint job. First you do your basic prep. work, primer, sealer. Then you spray 3 coats of Black. Over the black you spray the flip flop It would take less than a qt. for a brat. Then 3 coats of clear over that. Check this place out. They have flip flop powder that you add to clear or a candy color to get that effect $26.00. http://www.thetuulshed.com/ -
You must also disconnect and plug the vacuum line going to the Dis.
It would look realy good with the SS center cap. -
Start with a small dia. piece of pipe and roll the car ahead with it between the tire and fender, keep increaseing the dia. until you get the gap you want.
matching paint for touch-ups? And sticker removal?
WD40 will take off most stickers. -
Mastercraft tire has a 195/70/13 that would give you more height, width and would work for you I do believe. Check it out. http://mastercrafttire.com/us/en/ProductDetails.asp?ProdType=Passenger&id=84&title=Passenger+Tires
Here's a neat deal to compare tire size. http://www.csgnetwork.com/multirpmtirecalc.html
New coil, Mallory Promaster
Craven replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
True, thats one of the reasons to run a bigger coil. -
185/70/13= 23.40 195/60/14=23.40 deppending on the tire company. Check it out. http://www.miata.net/garage/tirecalc.html
$74.67 for 1 header gasket!
Craven replied to Vanislru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did they serve VASSOLINE with that. -
195/60/14" is the same height as the stock Suby 185/70/13"
Here is a few good deals, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7962071826&rd=1 or http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7963295219&rd=1 and it looks like the adapter would work also. Get a carb rebuild kit and you would be set to go. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33551&item=7963224586&rd=1 There are a lot of webers on ebay right now.
This is the reply I got from Accel about using a ballist ressisitor with the 140001 Accel Super Coil, which is the Accell version of the Mallory promaster. http://go.mrgasket.com/AskTechResults.aspx?BrandID=1&ID=117190 -
LSD Q? do i need the trans also??
Craven replied to gunslinger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It is listed by McBrat but it has Qman's name on it. http://www.ultimatesubaru.org/forum/article.php?a=36 -
After more research it depends on what Dis. you are running. If the ignition module is inside the Dis. it appears you don't need the extra resisitor. If your running points or some of the early electronic ignitions with the module mouted by the coil, you need it.
