Everything posted by Craven
No Accel Coils, No schucks
Craven replied to djbroadus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
(Taken from another site) MSD/Accel round coil info MSD Blaster II and III coils. They used to work well. These coils used to be manufactured at Andover Industries, Andover, Indiana, and were of superior quality. In early 2000, production of RED MSD Blaster II and III coils, p/n's 8202, 8203 and 8223, was moved from Andover to a company in Mexico, Pro-Bobbin. When this happened, I started to experience HEI module failures for no apparent reason. Others did as well, and MSD box failures when the RED Blasters were used. It was so untraceable that the problem would only be found by changing the coil. The cause was the insulation materials between the wire windings was deteroratinf and falling away from the coils, causing a layer shorting of the coils, and change of resistance/load on the module/box and failure of same. The 8200 chrome Blaster II coils remained at Andover, and had only the regular failure rates one would expect from a mass produced coil, functioned correctly. Sometime last year, production of the 8223 RED Blaster III coils with the HEI terminal,was returned to Andover. When I finally figured it all out, I switched my recommendations on coils to Accel round Super-Stock, made at Andover. Good quality coils, problems stopped, up until about a month ago. IN the last month, numerous Accel coils, 8140 and 8140C, were coming up either new defective or had operating issues like missing, erratic idle, no performance. This was traced to a move in production in the Accel coils. Accel was sold earlier this year, off the Dana Corporation, and the Accel coil production was moved form Andover to Taiwan. It was these Taiwan Accel coils that were having the issues. I have vended 19 Taiwan Accel coils in the last month, had 16 of them defective/develope problems with under 2 hours run time on them. No more Accel recommendations for me anymore. To identify different Accel round Super Stock coils: Andover Accels have segmented crimping at the top of the case to retain the top, with raised sections around the top. Taiwan Accels have a clean full crimp around the whole circumfrence of the top of the case. AVOID THE ACCEL TAIWAN COILS. Coils and their origins: MSD, 8200, and now, 8223 Blaster II, III series, Andover, good quality 8202, 8203 Blaster II series, Pro-bobbin, Mexico, avoid Accel 8140/8140C, 8145/8145C, Taiwan, avoid A good black coil with the same specs as the good Andover Accel is the NAPA IC12, same specs. AVOID the lesser cost NAPA IC12SB, Mexico made, low quality Crane PS20, PS40, Andover, quality PerTronix, NO, Taiwan, reboxed with USA logo, avoid Mallory round coils, no info Jacobs coils, overpriced Taiwan, avoid Hope this info stops someone from getting a problem coil. Craven -
subaru outboard motor?
Craven replied to Jack in Norfolk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.infoblvd.net/sah/Outboarder/1973/apr73-33.html -
This is how I mounted EA82 seats in my Brat. http://www.ultimatesubaru.org/photos/showphoto.php?photo=9826&sort=1&cat=500&page=1 Which could be adapted to any seat that would fit in the car.
A bad dream!!!
Look on ebay for a vin. Just bring up ebay-ebaymotors-Subaru, most of the cars list a vin.
I found this artical by Ray Sedman very good reading, about auto ignitions. It anwsers alot of questions about HO coils and such. He talks about Corvair ignition, but the same rules apply. http://autoxer.skiblack.com/rayignition.html Craven
Stupid Auto Parts Stores.
Craven replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/article.php?a=87 -
Like I said Check out Jegs. Accell V8 Super Stock Wires $23.99 Accel 8140 coil $27.99 -
Well said!!!Try Jegs.com They have there own HP coil at a very fair price and also have Accell wires http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4738&prmenbr=361 http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3050&prmenbr=361 -
http://www.edgeracing.com/tires/2056013/
They still make them http://coopertire.com/us/en/ProductDetails.asp?ProdType=Passenger&id=11&title=Passenger+Tires or http://mastercrafttire.com/us/en/ProductDetails.asp?ProdType=Passenger&id=84&title=Passenger+Tires
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7977695108&category=33640
Sounds like the cable is dry. You need to lub it before it breaks.
Fitting bigger rims on stock 4 bolt pattern
Craven replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The bolt circle is wrong. 3/4 and 1 ton 8 lug is 6.5" or the newer one's are 170cm. Suby is 5.5" or 139.7 cm. -
Ignition coils for the RX.
I believe 85 was the last year for the seats and steps. My 86 has neather.
If the plugs are black and wet, the car is running way RICH. Like Turbone said, Sounds like it needs a good tuneup.
80 Brat brakes works tooo good... HELP
Craven replied to Twowagons's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a car do that once, it was like the brakes wouldn't release all the way. I changed the caliper no change. Turned out to be the brake line hose that had collapsed on the inside and wouldn't let the fluid return. Since a Subuys brakes uses a X pattern, instead of a front - rear brake bias. I would make sure the hoses going to the front brakes are not twisted or in a bind. -
PM = Private Message Just left click on the persons name - (handle) that you want to send a message too and a dropdown window will open. There you will find the PM switch along with other options.
This could be a option. http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2191/base_no.91734722/str_base_no.000%2DCATALOG+RACE%2C91082200%2C91088200%2C917342%2C91734202%2C91734203%2C91734205%2C917343%2C917344%2C91734465%2C917345%2C91734700%2C91734722%2C/header_title.Race+Products%2DRadiators/page_name.prod%5Flist%5Fdisplay%2Easp/search_type.L2%7E34/search_option./deptsearch./deptSearch_id.2/dept_id.L2%7E34/dept_id_p.2/dept_name./dept_name_p.Race+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
There are a few places that sell replacment parts http://www.myautobodyparts.com/PartKeyword.cfm?model_id=353&make_id=35 http://www.2autobodyparts.com/PartKeyword.cfm?model_id=353&make_id=35 Whats kinda strange, is the prices are the same.
Are you sure these are fiberglass? I thought they were steel repops.
http://www.outlawradiator.com/radiator.php?make=subaru&submit=Go%21%21
