Everything posted by Craven
new buggie project
Then you would have a Land Cruiser.
new buggie project
Thanks Glenn
new buggie project
What is the site?
Attn photoshop guys!a small request please
bump
I tried.
[urgent help needed] rear diff disassembly
1/4" drive E10 torx socket
http://www.ultimatesubaru.org/forum/showthread.php?t=19156&highlight=rearend+torx+socket
a wagon wheel of a different color
That's what I was talking about (stainless steel). But for something a little different, the center caps from a Mazda pickup truck, spoke style steel wheel will fit. If you want to see one, I'll shoot a pic. tomarrow. Craven
Experiences painting Subarus with exotic paints?
Doing a flip flop paint job. First you do your basic prep. work, primer, sealer. Then you spray 3 coats of Black. Over the black you spray the flip flop It would take less than a qt. for a brat. Then 3 coats of clear over that. Check this place out. They have flip flop powder that you add to clear or a candy color to get that effect $26.00. http://www.thetuulshed.com/
another timing question
You must also disconnect and plug the vacuum line going to the Dis.
It would look realy good with the SS center cap.
rolling a fender
Start with a small dia. piece of pipe and roll the car ahead with it between the tire and fender, keep increaseing the dia. until you get the gap you want.
matching paint for touch-ups? And sticker removal?
WD40 will take off most stickers.
Gen1 brat tires
Mastercraft tire has a 195/70/13 that would give you more height, width and would work for you I do believe. Check it out. http://mastercrafttire.com/us/en/ProductDetails.asp?ProdType=Passenger&id=84&title=Passenger+Tires
Gen1 brat tires
Here's a neat deal to compare tire size. http://www.csgnetwork.com/multirpmtirecalc.html
New coil, Mallory Promaster
True, thats one of the reasons to run a bigger coil.
Gen1 brat tires
185/70/13= 23.40 195/60/14=23.40 deppending on the tire company. Check it out. http://www.miata.net/garage/tirecalc.html
$74.67 for 1 header gasket!
Did they serve VASSOLINE with that.
- Ignition
Gen1 brat tires
195/60/14" is the same height as the stock Suby 185/70/13"
Need carb for EA-82
Here is a few good deals, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7962071826&rd=1 or http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7963295219&rd=1 and it looks like the adapter would work also. Get a carb rebuild kit and you would be set to go. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33551&item=7963224586&rd=1 There are a lot of webers on ebay right now.
This is the reply I got from Accel about using a ballist ressisitor with the 140001 Accel Super Coil, which is the Accell version of the Mallory promaster. http://go.mrgasket.com/AskTechResults.aspx?BrandID=1&ID=117190
Changed distributor, now car won't start! It's running, I'm not an idiot!
Ya I'd say that would make it run mighty ugly.
LSD Q? do i need the trans also??
It is listed by McBrat but it has Qman's name on it. http://www.ultimatesubaru.org/forum/article.php?a=36
After more research it depends on what Dis. you are running. If the ignition module is inside the Dis. it appears you don't need the extra resisitor. If your running points or some of the early electronic ignitions with the module mouted by the coil, you need it.
