86subaru
Everything posted by 86subaru
thats what i am going to have to do , and then go from there with fixing it ,thanks to all
Ohio...go Buckeyes!!!
86subaru replied to baggyshorts's topic in Meet n' Greet. Your USMB Welcome Center
closer to time pm me and i might be around columbus or depends on your route of travel stop on by -
Tranny Cooler
86subaru replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
i added a tranny cooler to my 88 a/t turbo wagon + new 2 row radiator , temp gauge 1/4 way up , on a real hot day with ac on it might go up to 1/2 up -
real nice
same problem here , if the waste gate is stuck open is there a way to break it free
wife called dealer , they did nothing to the turbo , ok, will it hurt anything else if the car is driven ? can't get it in until next week ,car seems to running better today ,wondering if i got a bad tank of gas?
plugs good , timing set , after 50mph it seems to do ok , but before it is a real dog , with the exhaust leak at the head it had more power than what it does now , this is what my wife says and she drives it, and the turbo light came on and plenty of boost, trying to think of anyhing the dealer may have done
i was thinking the same thing about the rag deal, because they did not pop the hood at all , reason i say this is because i left a small pry bar by the alt, a rag in the pipe would do it , i will check the timing .20 ,my wife will call the dealer tomorrow , thanks
dealer 45min away, soooooooooo i guess drive it until she blows or rent a car until it gets fixed, checked vacuum lines at turbo all good, , check all wire connections all good, ,another trip to the dealer , wife has to stay with my boy , i have to work aleast 10-12 hr days , the rest of the week ,thing is the turbo was working before i took it to the dealer , plenty of boost
before exhaust studs were fixed i had boost , now i think no boost , but cars runs fine , and mpg is good , before i took it to the dealer the turbo light came on , the dealer retapped and put different bolts in + oem gasket , passanger side, with a can of carb cleaner i sprayed all vacuum lines no difference while car was running, ok, wife says something wrong,
where is the pressure switch for the turbo ?
well i drove the car aleast 60 miles from the dealer home , i checked all vacuum lines last night all seem good, but one could be bad , there is a orange power light on the dash that does work when you really get on the gas from a dead stop , mpg are good, today i will check other things as suggested, this might be a dumb question but i have been running a heavier weight oil lately to slow the oil leak, [ 2 qt 15-40 - 2 qt 20-w50 ]
ok, but i am not use to driving it, and it is a/t 4speed also , or i could have by mistake gotton part of a gasket in it , thanks
ok, will check out all vacuum lines , it just seems a real dog , but my wife drives it , i will ask her to drive it , seems like it has gotton slower as time goes on , is the pressure switch easy to change ? any pic of it , etc...
it's my 88 turbo , the light on the dash always came on , now it does not , power seems alittle low , like from a dead stop , runs fine after getting it back from the dealer [ 47.35 bill] very quiet , if the turbo has gone bad will it hurt anything ? , reason it was at the dealer was exhaust bolts were bad , they put new ones in , i have a spare ea82 turbo off a xt are they the same ?
yes using the power washer would be the best way to find oil leaks, my opinioin is rear main, + cam cover gaskets, and oil pump seal, while in there check out the timing belts, and water pump, i would also replace the oil pan gasket
Another Stupid Exhaust Question
86subaru replied to 4WDFrenzy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
did the same thing here on my 88 turbo a/t wagon, no cat 2-1/2 pipe back , + air box mod , but problem here is the exhaust bolts at the head are stripped , but getting it fixed at the dealer , i am sure they will see the cat-less pipe -
I want new seats in my '85 BRAT
86subaru replied to DaBrizat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have a nice set of tan ea81 seats , not cloth -
88 turbo a/t cross over pipe question
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok, will find out thursday, update, mechanic can not get to it until monday , sooooooooo may take it to the dealer , heck with it -
if the pipe is warped what would the easy way to fix it ? -
ordered both sides turbo exhaust gaskets , going to take it my mechanic , he also asked if there was a coolant leak ? is he thinking there might be a a crack in the heads ? what would the exhaust gaskets have to do with the heads ? -
helicoil is not tight enough , because i can slide a gasket right past it, the gaskets i have been using are napa, or carquest, i had a few with the metal rings, + back side of the timing belt is starting to melt -
decided to take a look at it again, gaskets is blown out again , in fact i can easily slide a new gasket in , right past the helicoil , also noticed the back side of the timing cover begaining to melt mpg down , + power -
ok, thanks will try oem gasket first , also look for crank in pipe
