Everything posted by 86subaru
replace 86 GL10 turbo 1.8 w/newer - worth it?
like northwet said a/t are ok, my wife driver a 88 full time 4wd turbo wagon , 22-23 mpg city , running ac , 4speed a/t
a/t question / flush
it is a a/t turbo full time 4wd wagon, 106,000mi , shifts good, my question is should i service the tranny and change out the fluid ? or just not do it ? because i was told it could harm it than help it ,thanks
soobie died,need help !!!!
yes your right , been a long day ,heat must be getting to me
but there is still no spark , would a broken drivers side timing belt cause no spark , i changed the coil to oem , both miles and i put new timing belts on 25,000mi ago
Turbo vs Non-turbo radiators
if i remember i had to change the clutch fan from what was on there and put on a clutch fan from a xt , one extra blade and fits alot better
2005 Outback Turbo, which type of oil?
86subaru replied to Lone Ranger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXroyale purple or amsoil , running these change every 12,000mi ,change filter every 6,000mi
so for a 122 bucks you are getting a 2 row radiator ? what is shipping charge? so this should fit my 88 turbo a/t wagon ?
accell coil gone bad
just like title says, only after 9,000mi , DO NOT BUY
ac question
yes it has been changed over from r-12 to r-134 , if it is freezing up then why after you let it set over night and turn on the ac it does not blow cold air?+ when i put a gauge on it ,it reads low
The west is the best
when are you going to indiana ? maybe tom+ alleyboy can meet here and you can come down here
Coolant leaking from somewhere below Turbo? 90 Loyale
when you replace the coolant line also replace the oil line
ac question
on my wife's 88 turbo full time 4wd a/t wagon, she says a white fog comes out the vents and then shortly after the ac will not blow cold air, twice now i have added , is there a easy fix ? it is r-134
towed a freebie home today.. bragging rights.. :)
looks good,
Burnt oil, no pressure. HELP
there is a coolant line [passanger side along with oil line ] that goes from steel line to rubber hose ,underneith the turbo , this could need replacing ,mine did
The Advance Auto near my house is worthless.
good luck at mine, they had my ball joints + wheel bearing seals in stock ,on a sunday :cool:, but it is 15 miles away
To synthetic or not synthetic
86subaru replied to kahequ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere is my opinion , i run amsoil in my 88 5sp d/r wagon 189,000mi , 5-10 lbs more oil pressure , + have only added 1 qt at 5,000mi , i am going to change the filter at 6,000mi and change the oil at 12,000mi , i am thinking about using royale purple in my 88 TURBO a/t full time 4wd wagon , you can go longer between oil changes
catless exhaust spfi
ok, it will be loud , i did it to a fwd wagon , temp gauge was cooler, mpg went up , noticed some hp gain , thanks
a few weeks ago there was a board member , saying he could get a y-pipe made with 02 drilled in , just woundering how it turned out + cost + can you get anymore made ? what about the loud noise ? any major benfits ? hp,mpg, temp,
AT Oil Temp light on intermittently
86subaru replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine also comes on , 88 turbo a/t full time 4wd wagon , but running 75mph + temp gauge 3/4 way up , hows your radiator ? or tranny fluid ? tranny flush, or radiator going bad
Improved gas mileage? anyone heard of this?
86subaru replied to JaySun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnow i did put very little into my riding mower , 2 gal tank ,and yes it did run better ,
Too much oil?
a few times i have gotton oil onto the exhaust after changing the oil, if it is 4wd i always remove the skid plate first , quick lube places may not , munch easier to get to drain plug + less messy
disapointment.. oil leaks?
86subaru replied to n16ht5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis may not mean anything ,but what weight of oil are you using ? if your using a light weight oil it may leak more , i have found this out
86subaru replied to JaySun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have tried it ,no mpg gain ,but increase in hp on my 88 5sp , and did ask a chemist and he said the long term may damage the seals around the injectors ,but the same thing is put into fuel injector cleaner , 1 time a year is ok,
Need opinions on this Brat.
pretty far for me to go after it , all the way across the state of indiana
Filters?
86subaru replied to derekho55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfram is made very cheap and are junk also stp
