86subaru
Everything posted by 86subaru
  1. i sent you a private message with my phone # , i am in western ,ohio , right along I-75 , 100 miles south of toledo ,ohio, [ ANNA,OHIO] give me a call if you are going this way and stop on by , july 30th and aug 1st i will be gone
  2. no coolant leak etc.. , seems the other iac was bad , but still back to the same problem as before i started
  3. make sure the parts store is looking up for the right size motor , there should be adjustment left after you put the new belt on
  4. this i what i did , the problem may have been is i used another one ,that looked good and cleaned it good , put it on and no go , sooooo i cleaned the old one and put it back on , still idles like before , but aleast i can drive it :-\the other iac was from a same year car ? either it is bad or something else
  5. cleaned the IAC and now car will not stay running ? it is a 88 spfi 5sp d/r wagon,all vacuum lines hooked up ,all wires pluged in , it runs good as long as you hold the gas pedal down
  6. got it ,thanks skip and everyone else
  7. thanks skip ,did a search did not find cleaning ,
  8. if you remember it will take either 1-3 ozs , i tried 3oz then 1 oz no major improvement ,but i think it is pretty good enjector cleaner
  9. looked at it very quickly tonight, heard a ticking around the acell coil, all wires good ,ngk plugs, new cap, rotor, ??
  10. a question here, i removered the big fat cat on my 88 turbo wagon , but i still have the o-2 sensor in place ,really no difference in power , should i unplug the 0-2 sensor ? or leave it pluged in ?
  11. after the cars sits over night it starts right up and idles fine, drive it 5-6 miles shut it off for 2-3 minutes ,start it back up it will idle way down and some time even stall , but does not do this all the time , recent tune up, cap,rotor, wires,plugs, fuel filter , acell coil still good, no codes flashing , car has 189,000mi , mpg is 25-26 with ac on, any suggestions ? thanks
  12. my 88 5sp might get that if i do not run the ac ,w/189,000mi on it , yours is doing really good i think ,
  13. i also have 88 turbo awd a/t turbo wagon, it will start to over heat if your running 80-85 mph with the ac on. but 65 -68 runs normal ,and i have a 2 row , but i live where it is very flat , my problem is the fins on the outside may not let enough air into the radiator
  14. i can say i have the most in my area, 2- 84 brat, 1-88 dual range wagon, 1- 88 turbo awd wagon ,+ alot of parts in my garage
  15. i run amsoil oil ,and i like it, i do not have to change the oil but every 12,000mi i,and change the filter every 6,000 mi ,
  16. the weber was not hooked up at all, and the vacuum lines were crossed , oil was going into the weber, , but it was running fine , i decided to change coils and go with a acell coil and this is how it all started
  17. no big deal, when ever you take your grandson back ,stop on by
  18. set top dead center, set timming to .8 , major back firing , surging , so i bumped up timming to .12 , alittle less backing firing , if i really get on the gas is when it back fires , what should i look at next ?
  19. that is what i was thinking , my books say something about 3 marks , thanks
  20. when setting timming marks, which marks do you set the pointer at ? , i cranked the motor by hand , and turned it to A and left it there , i do not mean when turning the dist that is .8 , what mark is top dead center ?this is on a 84 brat with a weber ,thanks
  21. start with 1oz per 10 gal ,if no improvement go to 2oz . up to 3oz , what i have been reading each car can be different,
