86subaru
Everything posted by 86subaru
  1. if i am right , there is a rubber cover on the timing belt cover , remove it and stick your finger inside and you should feel the timing belt it self
  2. another part to change is the water pump o-ring, gasket, if the car is leaking oil , change the front seal, crank seal, cam cover seals,
  3. if any 1 coming to the meet could bring rear disc brakes both sides for a ea82 , heater resistor pks, gray cargo covers [2] rear wagon lens,
  4. only 1 problem i have no compressor , is the drier a special item to order ? or 1 size fits all
  5. can i clean out the system my self ? where can i get a drier at ? o rings ?
  6. my 88 turbo full time 4wd a/t ,the ac does not work, i am going to switch the compressor from the square 1 to the working round 1 , my question is wal-mart has a kit for 35 bucks and it says will convert from r12 to r134 , just follow the directions , will this work? or should i take it some where to get it done ?
  7. also run accell super coil, ngk plugs, 8mm wires, k-n filter, or cone
  8. be carefull not to mess up the threads on the axle where the axle nut goes on ,like i did
  9. well you could always sell it to me , the 15-17th a few of us are getting togather at my place to do some work, putting a dual range 4wd into a dl 5sp wagon . come on down , send me a private email and i will tell you how to get here .from cleveland about 4hr drive
  10. you can find seaform at napa ,i use the injector cleaner from gm ,the engine cleaner stuff
  11. i tried to email you miles , are you guys still coming down the 15th -17th of may ?
  12. this may or may not help, but i had a fuel leak on my 88 spfi gl 4wd wagon, it was the fuel damper which is right at the fuel pump, about the size of a quarter and fatter , i was told is is like a check valve ,and to put 1 back in it's place ,
  13. take your battery to any parts store and they will check it for free , and then go from there
  14. also is he bring back any subaru's ? i think next year me and the wife are going
  15. so where is the fox and crew ? hows his car running ? last i heard was that his clutch was gone and motor smoking badly
  16. 219,000 mi on my dl fwd manual wagon ,which i just bought
  17. i think chief tim is coming over there for 4months , get in touch with him , he is from south dakota i think
  18. could they be broke down some where between the mud and your place ? and by the way things look , out in the middle of no where
  19. if every board member would give 1 dollar that would be close to 3700 , please post a address so i can send $$$$$$$$
  20. are there any paved roads ? i guess at night it really gets dark out ,
