el_freddo
  1. I doubt its possible. It's pretty tight in there as it is! Best fix I've done for these is the EJ conversion - but I won't side track you on that one. The lifter tick is not detrimental to the operation of your EA82, just a pain in the arse! Replacing the oil pump seal, shaft, rotor and matching pump gear can do wonders for the oil pressure as it is basically a new oil pump without the cost of a complete unit. One thing that kills the lifters is letting them continually tick without regular oil changes - the gritty oil wears out the cylinders that fill with oil that allows the "piston" end to compress the oil. These cylinders can leak oil out allowing the lifter to compress and thus make the ticking sound you hear when you run your EA82. I pulled a set apart to make some solid units (note: don't do this with MPFI units, not good before 4000rpm, after that it goes off like a frog in a sock!), some were really sloppy and others were pretty tight. Also if you do the solid units, they're a PITA to get the right clearances to make it run right without ticking... Cheers Bennie
  2. 36mm socket, 1/2 inch drive breaker bar and my 82kg's bouncing up and down on the other end until it doesn't move anymore. This has worked front and rear for me without issues! As for specific torque settings I believe it would be the same as previously posted ~196nM but without a bar that can read that far it's hard to gauge exactly And I agree with the rear disc conversion being the best brake upgrade besides an xt6 or crossbred conversion. IMO its a must before dropping an EJ in! Cheers Bennie
  3. G'day all. I'm looking at new front (and rear, later) half shafts/drive shafts. I have used a company called GSR I think, anyway they were made in china, copped a flogging for about 20 months but have now given up the ghost - too noisy for my liking. After then fitting a second hand set I had in the shed and getting a weird vibration, I worked out that it was the drive shafts that was causing it. I now have another second hand set, history unknown, going well, eliminated the vibration but they click when crawling on the street in traffic (in a straight line), while cornering and anything under 45 miles an hour. So with all of that I'm considering a new set of shafts but don't want anything made from china as that seems to be all we can get over here I've looked on Rockauto.com and have found EMPI but no details as to where they're made. I'm keen for something that's made in america or canada as I would say that they will be far superior to anything from china. If anyone here can suggest brands or specific items that have served you well, I'll be keen to know about them. My search for parts pretty much stops at rockauto when looking OS. Cheers Bennie
  4. Holy crap Loyale! I can't believe how much rust you're fighting there!! I thought I'd seen some bad rust in L's but this one is unfortunately the worst You do an amazing job to keep your L going! It certainly makes what I'm dealing with an easy task, mainly body fatigue after a good 440k kms with some hard 4wd'n since I've had her at 293k km Cheers Bennie
  5. That is a tough question! I personally would stick with the diff lock, but the advantage of the 4.11 diff ratio is very appealing too. With this in mind, some fellas over here have been "building" the best of both worlds. With some ingenuity and good welding skills they've created a 4.11 ratio pinion shaft that will fit the RX AWD tranny with locking centre diff. Here are some pics of the one that is destined for my AWD L box build: ^ Note the weld about a 2 inches from the pinion gear. I'm not sure if this was made from two EJ AWD pinion shafts, one being the 4.11 gear or if an RX AWD pinion shaft was cut and shut. I currently don't have an EJ pinion shaft handy to compare I'm sorry. Food for thought, sorry I didn't actually give you an answer to your question! Yeah you were!! Classic. Totally agree! The thing looks wild with no lift and the large tyres! Keep up the good work - can't wait for some pics on the tracks! Cheers Bennie
  6. Fixed the bent moustache bar that the EJ, 27s and an open rear diff managed to twist. I took a straight one I had on the welded diff (ironic isn't it?) and went to a mates place with the open diff and parts needed to put it back in once done. Using the bent bar, I tried to straighten it, not entirely successful or a wasted effort either. The bent unit was cut up to be welded to the straight bar. This is what they looked like: With the two units mounted to the diff and clamped together I got to work: ^ Not the cleanest welding (MIG) like pauls but it will do the job. The bar has been stitch welded top and bottom as well as welded at each end. The nuts for the diff stubs have enough bite to allow the two bars to be directly welded together which is what I wanted to do. Here's the bar fitted up after painting Should go well. Now to see what bends next. Hopefully nothing. Cheers Bennie
  7. Apparently it won't work using the air suspension compressor as these are high pressure low volume comprssors. The AC compressor is the way to go, seen many setups that work well. Cheers Bennie
  8. What have you done to your subi, is it bog standard or have you tweaked a few things?? I'm not sure how to interpretate those sounds you're trying to make, did something bad happen or did the ticking lifters go quiet at 95mph? Cheers Bennie
  9. Check the stabiliser bar's mounts and the rubber inserts where they connect to the control arm. If these are all good I'd be considering new drive shafts - mine used to clunk all the time particularly when at full lock left or right, only one klunk heard each time you were moving at full lock. New drive shafts got rid of this noise for me - or you can just put up with it. Cheers Bennie
  10. Yeah sorry mate, i didn't mean to rub anything in - just that over here I seem to be one of very few with out an adaptor plate in my EJ'd L series and I don't think that its common knowledge about this modification to make it bolt in "as factory with a twist"... I forgot about this issue. I'm just used to dual range gearboxes through out the subaru models - and I'm not intending to rub it in either if you're thinking this! Can't wait to see some pics of the progress Cheers Bennie
  11. Also - an old thread to dig up to ask this question... Bennie
  12. I used a slide hammer with a hook like attachment on the end to pull the gudgeon pins out. The clips that hold them in were removed with long nosed pliers from memory. Cheers Bennie
  13. I hope he put all the little balls and spring back in the right places for the 4wd and low 4wd gear engagement mechanisms - its pretty messy in there! Need a keen eye or loads of pics for every step of the way. No kidding! Hope its just an adjustment that's needed, the other option I've mentioned would not be fun Cheers Bennie
  14. I'm still not convinced that you've spun a bearing - and I hope for your wallet that you haven't either! Might as well rebuild the engine or do an EJ conversion - they're about the same cost once you lay it out on paper if you do you're own labour on the conversion... Anyway, the only way to know if you'll need to go oversize is once you've pulled the engine down and checke that the crank is still within specification for the standard bearing - otherwise its a grind and oversized bearings. Cheers Bennie
  15. Will you be using an adaptor plate for the fitting of the RX AWD tranny or will you use the EJ front half casings with the RX gearsets fitted to make it bolt directly up to EJ engine? The advantage of the re-casing of the RX internals is that you get to retain the stock EJ clutch setup. I've done this with my L series EJ conversion. Gearbox bolts straight in as factory with the EJ - in the L series anyway (gearbox crossmember will be different in later model subi's for the Rx tranny). Looks like it will be an interesting build! Cheers Bennie
  16. So what will you be filling the rest of the engine bay with??? Sooo much room if you've only got effectively half a stock rotary in there! The gearing will be interesting to work out - really need to know how this rotary performs on the street to get any idea of whether or not the stock subaru ratios will work with this engine. As for the 4 or 5 speed question - 5 speed has a much better "step gap" to the top gear by splitting it with another gear. I've had loads with the 4 speed that bogged the EA81 going from 3rd to 4th unless you really flogged the engine to "jump" the gap in the revs between the different gears. The 5 speed is generally nicer to drive, feels better in the gear changes unless the 4 speed has new gear lever bushes installed. The L series 5 speed is basically the same as the EJ/Legacy 5 speed, well over here it is as we've got the dual range function on the EJ/legacy 5 speed gearboxes where as I believe that you missed out on this in the US. Hope this gives you something to think about/research. Cheers Bennie
  17. I had the same problem with my rear diff the first time I took it out. This is how I did it - I was able to re-use the drive shaft, its still in the subi now ^ removed the diff for a welded unit. Point and shoot offroading from then on! This is an old pic trying to show what I had done. The grey lines are the wire that was used to hold the CV in place - cable ties work well too I used an angle grinder to grind the pin down to the stub axle so I could get the CV shaft off. After this was achieved I then smashed the remaining roll pin out of the stub axle until I had it all clear again. Worked a treat and I would do it again if needed. Cheers Bennie
  18. G'day all! I ran with the stock L series exhaust modified to fit to the factory EJ22 Y pipe on my '88 L wagon. Before heading to the snow last year I "lashed out" on a new exhaust setup that also tucked up where it should be with the three inch lift. Here's some pics of the setup - 2.25 inch cat back with resonator and new rear muffler "to release the subi burble" which the exhaust shop got right. A nice note, not really refined but still sounds the goods! Pics: ^ I was hoping for a hotdog style resonator but this is what I got - beggers can't be choosers! And a flexi joint is a must to stop vibration through the exhaust system. And a video of the note while climbing Mt Hotham from Harrietville in Victoria Australia - gets a little repetitive! Love the note and the perceived performance gain if there's actually any there. I know she loves to rev easier! Well worth the money for such a "small" mod! I really enjoy my subi a pot load more since the exhaust - plus the tucking it up under the vehicle again has been very valuable offroading Cheers Bennie
  19. ... and where can I find out about the BYB and/or hatch patrol? Cheers Bennie
  20. I'm sure I've spoken to the same guy as well - got the same response. I'd love to win some money from the lottery to get this happening... Just need to win the lottery as this will be the only way I personally could get this moving. I have contacted some diff locker manufacturers with the following responses: ARB flat out said it can't be done the first time around. Last time I emailed them they said the diff would not be able to with stand such forces. I have emailed them back about the auto unlocker I know of and have not recieved a reply as of yet... TJM are starting up a manual locker production. I've emailed them as well. Their response was a long the lines of "we're focusing on the well known brands and models used in offroading, once we have sucessfully established this we may look into the R160 diff design" or something of the like. So at the very least if it does happen with this mob it will be a few years at the least before something is available. I have also contacted some chinese diff locker producers that I found on google. I don't know how legit they are or what not, but I've not had a response from any of them. They could be learing english but who knows... 1) been there done that, back with this setup now for snow travel in winter 2) did this mod and it was the best offroad mod I've done to my subi - "point and shoot" was the motto with a welded rear. Got my subi into places it shouldn't have without lift or larger tyres! More on why I want a manual locker later in this thread. 3) Not an option. Love my subi and love showing others what my modified subaru can do in the scrub. Because those of us who are truly after one are hoping that someone/something/this group and discussion result in a suitable manual locking rear setup for our subi's. B, maybe you kept breaking your subi because you asked way too much of it OR you didn't know how to drive your subi in rough terrain while also preserving the mechanical health of your vehicle. Why do I want a manual diff locker?? I'm building my subi for a purpose. A hard core offroader - not rock crawler (even the big rigs can't do this unless its very heavily modifed to comp truck level IMO) - that is also a great tourer and daily driver. What I have now is EJ22 stock L series gearbox, 3.7 ratio diffs and 27 inch tyres. That is a great setup for a subi, an LSD even better, but I'm going one further - the gearbox is going to be swapped out for one of the dual range L series AWD centre diff locking gearbox with 4.11 ratio diffs. THIS is the reason why I want the manual diff locker. A welded diff and removing a drive shaft with AWD will not work for me, nor would the same setup with a free wheeling hub or the like. An auto unlocker isn't great in the rear or front for that matter (not that there are front units out there) with AWD - a friend of mine has an auto unlocker in an r160 diff housing of his subaru MY, it goes amazingly well! I've been mentally designing a locker in my head at work when I can, then physically looking at an R160 diff to see if it could possibly work, when it doesn't its back to the drawing board, fun fun. I might get there one day but like many others I don't have the skills or knowledge to machine parts, let alone the hardware to do it... This is my subi, I'm rather proud of where its been (literally) and where its at in its build that continues. The outback was a good comparison: If a welded diff can take the forces of locked offroading - I'm sure a manual locker could do the same with the same strength. Just need to nut out a mechanism that locks the spider gears. A mate of mine said it would be easy to do with some time, a little bit of money (initially) and the right equipment. Basically the go would be to buy a readily available off the shelf diff locker and "map" with CRC techniques (I think its CRC) then down size all the components to a size that will fit in the R160 rear diff. Next step would be to find suitable manufacturers of the components and then assemble and sell. I'm also after a manual locker for the later model subarus to be able to use as well as the older subarus too - the R160 diff has not changed a great deal from the early 80's MYs through till now. The datsun racing fraternity could also be interested in a device such as this. I live in hope and want to work towards something that will hopefully one day end up in the back of my (and other's) subi's. I have little time for those who just stamp this idea with the "get a toyota"/"put your money where your mouth is"... Cheers Bennie
  21. Got some pics for ya From this: ^ 3 inch lift + honda civic front springs in the rear (I've only just put these in and are very happy with the result) and the stock 23 inch tyre diametre for correct gearing and offset. To this: Scorpion Subaru 14 inch rims for the 4 stud hubs with 27 inch tyres. The bee's knees! Love these rims and its a shame they don't make them anymore! They really compliment the L's shape better than I could ever imagine - and the 27's tuck neatly under the guards which is what I was after. I've been hunting for a set of these for ages, ironically now I have two sets plus a spare - so one set for offroad tread, the other for primarily blacktop commuting... Now to get the gearbox sorted so that I have the proper ratios to drive these things. I'm feeling VERY tall once again! I'm thinking of sorting out a set of adjustable radius rods sooner rather than later then sourcing some new chains to run these tyres in the snow for the winter season - no swapping off the 23's to head into the bush... Plans - we'll see where they head! Cheers Bennie
  22. Sounds like a good project with a lot of potential! I'd recommend looking at an AWD gearbox, this way you've got maximum traction to get all the power to the road without the wheel spin. To change the gear ratios in the gearbox for the best low 1st gear can be a bit of fun if you're up for the task... The only issue is that with this method your 2nd, 3rd and 4th gears also become "shorter" thus requires the engine to rev faster to maintain the same speeds as it would have before any modifications. 5th gear is independant of 1st - 4th gearsets so you can find your desired ratio and fit that for highway cruising. Best bet would be the 3.7 diff ratio'd AWD gearbox that would be found in most bog standard legacy's (liberty in Oz). Find one of these then go hunting for either another gearbox or just the ring and pinion for a 4.11 or 4.44 (hard to find in Oz, dunno about the US though), fit this to your 1st gearbox that was 3.7 diff ratio standard and you'll have effectively lowered your 1st gear's ratio for a better take off. Run a legacy size tyre diametre and you'll be apples. Someone will be able to shed more light on this I'm sure. Cheers Bennie
  23. Keep up the coolant and oil - do the usual regular oil and filter changes and your subi should be sweet! I know in km's that subarus are good for well over 300k kms over here, so I'm sure they'll do the same in the equivalent miles over there if you maintain it well Happy subi motoring! Cheers Bennie
  24. No, quite the opposite, they were "custom shaped" on top for the best seating possible. Much better than any jack stand I could find - plus they were cheap! Found them in the wood stack Also, I'm waiting for some 14 inch scorpion rims to arrive I'm sure these were only made by a local australian company that no longer produce them, reasons not known to me - either way I've finally got hold of a pair, once they get here... The Scorpion rim: And the set of five rims en route: Standard offset and for me a better alternative to pug rims that are not as "easy on the eye" as I find these rims to be More pics of that later... Cheers Bennie
  25. G'day all I'm after some info/pics of how to fit EJ series (legacy, foz etc) seats into an L series. Any info would be a great help. Cheers Bennie
