jarl
Everything posted by jarl
Those look nice... trust me The first thing you need is new pads, but before I would check whether the sliding surfaces on the caliper are badly rusted. The tolerances on between the pads and the guides (covered with the stainless steel shims) are very tight, and any rust underneath the shims can prevent the pads from moving freely. I would use Evaporust on my calipers but I don't think they will come out without a fight. Then you want to make sure that the pins are moving freely, and that the rubber boots on the pin and the piston are in good shape. If you need to overhaul too much, it may be cheaper to buy some rebuilt calipers. As for the disks... well. The easiest thing to do is just replace them. I didn't do it with my car, though. I just wore them down with the brakes I'll replace the rotors when my bank balance recovers a little bit from all the stuff I have thrown at this car. Edit: forgot to mention: start soaking all the bolts with a good penetrating oil!
You can find Evaporust at a lot of local stores. And yes, it's a wonderful product, specally because it's environmentally safe. You can touch it without fears. Just one comment: In their literature they say it's designed to remove any iron molecule not firmly attached to it's substrate (like rust). But this also means the parts will be stripped of ANY protective coating they may have (i.e. this thing strips the coating from zinc plated bolts). Keep an eye on any exposed metal you may find after cleaning it using Evaporust.
Amazing, isn't it? And it looks like the engine bay was designed for it
I'm glad to say you are somewhat off... Personally, I'm of the opinion the FSM is worth every penny of it's price. The "diagnostics" section of the FSM has plenty of information, it's just not included with most of the copies of the FSM you find around. For people checking their CPS, the FSM for my '99 OBW mentions between 1 and 4 kOhms between terminals with the sensor off the car. This value may change if you measure the sensor without removing it, though...
By all means, don't feed the eBay manual sellers. All the information they have to offer -save very few of them- is all available through the web. The Subaru manuals are available through the "My Subaru" page: http://www.subaru.com/my-subaru/index.html You have access to 50 docs an hour for three days for $34 or so. Or just ask the right questions and you may get the right answers
Now what?
jarl replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
1. Sound like a vacuum leak. Specifically, I had the same problem a few days ago when the hose that goes to the IAC was disconnected accidentally when I checked the air filter 2. You checked voltages, but what about the ground? Can you try to measure the voltage present at the ground pin at the blower connector with the motor connected and the blower on? My guess is that the blower is getting grounded through the deicer. -
Yep... sounds like a battery terminal/cable with too much resistence. Try measuring to see if there's a voltage drop between the alternator (+) terminal and the (+) terminal at the battery, and do the same between the engine block and the (-) terminal at the battery. You should get a reading of 0V in both cases,
Oxygen Sensor
jarl replied to shimshim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If the splicing is the reason for going OEM, Rockauto offer several that include the connector. The only issue is deciding which one to buy (BTW: which brand is OEM?) Can anyone offer feedback about the brands they offer? For my OBW I can see: APWI Ultrapower NTK Standard Motor Products (connector?) Denso Delphi Bosch Beck/Arnley Airtex AC Delco
